Reef Angel Web Wizard
PostPosted: Mon Oct 15, 2018 1:48 pm
The release branch is quite old and hasn't been updated in a few years. As we've moved to the web wizard we can keep it up to date much easier. The RA libraries work just fine with the latest dev branch, you just get the compile errors but it does work. The bluetooth adapter just gives you a serial link over bluetooth to do the updating instead of using serial.
As far as the release branch, I was looking at it the other day and thinking it's probably a good time to update the master branch :) Overall that would be Roberto's call and will probably require re-packaging the local Arudino client which was quite a pain in the butt honestly, but I do affirm that if you download the latest and replace the libraries with the DEV branch you should be OK aside from the verbose compiler output.
PostPosted: Mon Jun 17, 2019 12:20 pm
Hi, I have a Reef Angle Star and have amended the code through the Web Wizard. The code is compiled successfully and I have also the Plug in found and connected in blue. However I cannot connect to any port. I am using the usb cable with my pc supplied. Any idea what I should do, cause I cannot upload the code on the unit.
PostPosted: Mon Jun 17, 2019 10:33 pm
Go to "Device Manager" on windows and expand "Ports (COM & LPT)"
Disconnect RA from the computer. Do you see any port disappear?
Now connect it back in. Do you see any port show up?
PostPosted: Sun Sep 27, 2020 8:38 am
rimai wrote:Go to "Device Manager" on windows and expand "Ports (COM & LPT)"
Having the same problem. The Machine sees it as com 3, but still get the can not program board.... ive tried a few times. Code compiles etc. Im jut trying to get this done so i can finish cable managing. Ill do rest remote
Previous
Return to Apps
