ios app is sucking
Posted: Sat Aug 05, 2017 10:08 pm
My ios app has not worked for months. Months. I have deleted it, reloaded it, reinstalled my code, made sure ip address is correct, and my port is definitely open. Why wont this freaking thing work? I load my name from the forums, add the ip address and the port and do not enter my username or password into the app. All this info allows me to access my controller from the portal, but not from the ios app. Why not?
My code:
My code:
ReefAngel.AddHumidityExpansion(); // Humidity Expanion Module
ReefAngel.FeedingModePorts = Port1Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.ActinicLights( Port2 );
ReefAngel.DayLights( Port3 );
ReefAngel.DayLights( Port4 );
ReefAngel.SingleATOLow( Port5 );
ReefAngel.StandardFan( Port8 );
ReefAngel.Portal( "psyrob" );
ReefAngel.DDNS( "psyrob-controller1.myreefangel.com" ); // Your DDNS is psyrob-99.90.0.55.myreefangel.com
