UApp Error - Nothing to update
PostPosted: Mon Jan 07, 2019 8:35 am
Whenever I try to update the "Turn Daylights on at:" or "Turn Daylights off at:" internal memory fields in the UApp, I get the error "Alert: Nothing to update."
The fields are showing blank on in the UApp, i.e., there is no time showing in those fields.
PostPosted: Mon Jan 07, 2019 10:49 am
Try to set them manually to something through the web interface
http://your.ip.address:2000/mb244,8 // Set StdLightsOnHour to 8am
http://your.ip.address:2000/mb245,30 // Set StdLightsOnMinute to 30 minutes
http://your.ip.address:2000/mb246,20 // Set StdLightsOnHour to 8pm
http://your.ip.address:2000/mb247,30 // Set StdLightsOnHour to 30 minutes
Then it should have some values. Might not be dealing well with NULL in the original field.
PostPosted: Mon Jan 07, 2019 11:43 am
That was a good thought, but unfortunately, I still seem to be seeing blank fields in the UApp. The controller did return "OK" for each of the above calls. I tried rebooting the controller, and it still seems to show blanks.
PostPosted: Mon Jan 07, 2019 7:23 pm
Are you sure your Uapp is working properly? You have no portal key setup? or it's configured if you have one?
PostPosted: Mon Jan 07, 2019 7:24 pm
Have you tried in the portal? portal.php ?
PostPosted: Mon Jan 07, 2019 10:05 pm
I do have a portal key, which I set in my ReefAngel.Portal("sbidny", "<portal key>") call.
I am using the cloud server, and I can successfully set other internal memory fields. My Uapp is working for nearly every other function.
As for the portal, I'm not having much luck. It seems to log me out every few minutes. When I do log in, I am often greeted with a "Connection Status: Error - 500." And when it does say "Connection Status: Ready," I can't seem to update any of the internal memory fields anyway. It just says "Saving Internal Memory..." and never changes.
PostPosted: Mon Jan 07, 2019 10:09 pm
I see the problem. The memory locations you had me set were incorrect :)
Should be 204, 205, 206, and 207, not 244, 245, 246, and 247. Now I see the values again. Will try to update...
PostPosted: Mon Jan 07, 2019 10:13 pm
Now when I try to update them all, I get a "Timeout. Please try again." And the values get set to some random numbers.
Tried to update just the "Daylights on," and now it turned null again.
PostPosted: Mon Jan 07, 2019 10:28 pm
Odd. let's see what Roberto has to say. Sorry about the wrong numbers.
PostPosted: Mon Jan 07, 2019 10:54 pm
I can't replicate.
Using Chrome, enable developer tools by pressing F12.
Then select the tab console.
You should see the MQTT messages that get exchanged.
Now, go to the internal memory tab of uapp.
You should see a very long string.
Copy and paste here.
Next
Return to Apps
