UApp Error - Nothing to update
• Page 2 of 2 • 1, 2
Joined: Mon Sep 17, 2012 12:41 pm Location: Lincoln Park, Chicago, IL, USA 60614 |
Will do...
BTW, do you want me to do this while I'm seeing the null value? I have updated them again from the URL, so I will need to reproduce the issue. Should be easy, but I want to check before proceeding.
Well, it was easy to get the null value back. Here is the string with the null value I'm seeing:
0f1e1500c2000f1e0a000f00525584035802340314140b030d03340333033ce402bf01001400161e00003c3c081e141e0a14323c14323c00800a0f643c0f643c0f643c0f643c0f643c0f643c780078000208c201000203f80220032a0300643c00643c00643c00643c00643c00643c00643c00643c00643c07f401c409000000000b0362645a3c00000032325702eb054e026c074e026c074e026c07ffffffffffffffff00ffffffffffffffffffffff |
That's very odd.
C2 is not a valid hour. The string represents the internal memory values starting at 200. What happens when you change to a correct number and click save? Can you post the log? Roberto.
FYI, updating the value is now causing my controller to reboot.
It seems to be rebooting every time the Uapp needs to update more than one value at a time, which the time fields do automatically. If I update a single field, it works fine. If I update two independent fields or a single time field, it reboots the controller.
Were you able to see what the console log shows when you update the value?
See attachment.
According to the log, the controller did receive the memory location 204 change to 14 and it even responded with OK.
The 205 was not acknowledged though. That's when you mentioned it rebooted and I can see that in the log too. But I can't replicate. This is what I get on my RA+ test controller using the cloud wifi attachment:
Strangely, the same change from my phone causes the same timeout, but it does not cause the reboot.
