Reef Angel Installer 0.9.0 released
Re: Reef Angel Installer 0.9.0 released
Curt,
Exactly, I was thinking of looking at the comparison code. Hopefully it would help build my understanding. The registry is a limitation of windows, I was wondering if setting up a virtual machine might get around the issue.
Call me a wimp, but I don't want the screw up the registry as it is such a pain to sort out
The registry stuff isn't bad to worry about. My registry settings are consolidated and you can't really screw much stuff up. The registry is just to save the settings and not needed for normal usage.
Code comparison won't really lead to much differences. The functions are virtually the same. There has just been some more stuff added in 0.9.0.
Virtual machine would work just fine with testing things with it. You could run it in a VM and then force the 0.8.5.X and 0.9.0 libraries and compare the code side-by-side.
Hey Curt/Robert,
Can you guys please help me get my old sketch up and running? I'm having a bunch of issues converting this.
Here are the errors I'm getting:
And here is the sketch I'm trying to convert:
New_v1.cpp: In function 'void DrawCustomMain()':
New_v1:39: error: 'struct ParamsStruct' has no member named 'Temp1'
New_v1:41: error: 'struct ParamsStruct' has no member named 'Temp2'
New_v1:43: error: 'struct ParamsStruct' has no member named 'Temp3'
New_v1:73: error: 'PWMChannel' was not declared in this scope
New_v1:73: error: 'LEDPWM0' was not declared in this scope
New_v1:74: error: 'LEDPWM1' was not declared in this scope
New_v1:75: error: 'LEDPWM2' was not declared in this scope
New_v1:76: error: 'LEDPWM3' was not declared in this scope
New_v1.cpp: In function 'void loop()':
New_v1:129: error: 'PWMChannel' was not declared in this scope
New_v1:129: error: 'LEDPWM3' was not declared in this scope
New_v1:129: error: 'Moonphase' was not declared in this scope
New_v1:133: error: 'LEDPWM0' was not declared in this scope
New_v1:134: error: 'LEDPWM1' was not declared in this scope
New_v1:135: error: 'LEDPWM2' was not declared in this scope
New_v1.cpp: In function 'void CheckCloud()':
New_v1:293: error: 'PWMChannel' was not declared in this scope
New_v1:304: error: 'PWMChannel' was not declared in this scope
New_v1:305: error: 'PWMChannel' was not declared in this scope
New_v1:310: error: 'PWMChannel' was not declared in this scope
// Autogenerated file by RAGen (v1.2.1.158), (02/18/2012 22:40)
// RA_021812_2240.ino
#define DisplayLEDPWM
#define wifi
#define WDT
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15, 10, "T1:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, T1TempColor, 15+18, 10, 10);
ReefAngel.LCD.DrawText(T2TempColor, DefaultBGColor, 15, 10+10, "T2:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, T2TempColor, 15+18, 10+10, 10);
ReefAngel.LCD.DrawText(T3TempColor, DefaultBGColor, 15, 10+20, "T3:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, T3TempColor, 15+18, 10+20, 10);
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+60, 10, "PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, PHColor, 15+78, 10, 100);
//ATO status
ReefAngel.LCD.DrawText(DefaultFGColor, DefaultBGColor, 15+60, 10+20, "Pump:");
byte highcolor;
char highstatus[10];
if ( ReefAngel.HighATO.IsActive() )
ReefAngel.LCD.DrawText(PHColor, DefaultBGColor, 15+90, 10+20, "ON ");
ReefAngel.LCD.DrawText(T1TempColor, DefaultBGColor, 15+90, 10+20, "OFF");
//End ATO status
ReefAngel.LCD.DrawOutletBox(12, 95, TempRelay);
ReefAngel.LCD.DrawText(0,255,15,52,"RB:");
ReefAngel.LCD.DrawText(0,255,15,62,"BB:");
ReefAngel.LCD.DrawText(0,255,15,72,"CW:");
ReefAngel.LCD.DrawText(0,255,15,82,"WW:");
ReefAngel.LCD.DrawText(0,255,15+20,52,PWMChannel[LEDPWM0]);
ReefAngel.LCD.DrawText(0,255,15+20,62,PWMChannel[LEDPWM1]);
ReefAngel.LCD.DrawText(0,255,15+20,72,PWMChannel[LEDPWM2]);
ReefAngel.LCD.DrawText(0,255,15+20,82,PWMChannel[LEDPWM3]);
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port2);
// Specific functions
ReefAngel.StandardLights(Port4);
ReefAngel.Relay.DelayedOn(Port5, 2);
ReefAngel.MHLights(Port8);
ReefAngel.Portal("aranax");
ReefAngel.Relay.DelayedOn(Port1,1);
ReefAngel.Relay.Off(Port1);
//skimmer
if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.DelayedOn(Port5,1);
else ReefAngel.Relay.Off(Port5);
//refugium
if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
if ((hour() >= 12) && (hour() <= 21)) ReefAngel.Relay.On(Port7);
else ReefAngel.Relay.Off(Port7);
PWMChannel[LEDPWM3]=Moonphase();
PWMChannel[LEDPWM0]=PWMSlope(12,30,22,00,0,80,240,PWMChannel[LEDPWM0]);
PWMChannel[LEDPWM1]=PWMSlope(12,00,22,15,0,70,240,PWMChannel[LEDPWM1]);
PWMChannel[LEDPWM2]=PWMSlope(13,30,21,30,0,30,180,PWMChannel[LEDPWM2]);
PWMChannel[LEDPWM3]=PWMSlope(15,0,23,00,0,60,180,PWMChannel[LEDPWM3]);
//PWMChannel[LEDPWM0]=PWMSlope(16,30,21,00,0,80,120,PWMChannel[LEDPWM0]);
//PWMChannel[LEDPWM1]=PWMSlope(16,00,21,15,0,70,120,PWMChannel[LEDPWM1]);
//PWMChannel[LEDPWM2]=PWMSlope(17,30,20,30,0,30,60,PWMChannel[LEDPWM2]);
//PWMChannel[LEDPWM3]=PWMSlope(16,0,21,00,0,60,120,PWMChannel[LEDPWM3]);
CheckCloud();
PWMExpansion(LEDPWM0,int(2.55*PWMChannel[LEDPWM0]));
PWMExpansion(LEDPWM1,int(2.55*PWMChannel[LEDPWM1]));
PWMExpansion(LEDPWM2,int(2.55*PWMChannel[LEDPWM2]));
PWMExpansion(LEDPWM3,int(2.55*PWMChannel[LEDPWM3]));
//Start of PWM slope function code designed for the PWM Expansion module
void PWMExpansion(byte cmd, byte data)
Wire.beginTransmission(8); // transmit to device #2
Wire.send('$'); // sends $
Wire.send(cmd); // sends a value
Wire.send(data); // sends 255
Wire.endTransmission(); // stop transmitting
//End of PWM slope function code designed for the PWM Expansion module
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Cloud_Chance_per_Day 75
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
#define Start_Cloud_After NumMins(13 ,30)
#define Lightning_Change_per_Cloud 60
#define Actinic_Channels B000001
#define Daylight_Channels B001110
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
for (int a=0;a<6;a++)
PWMChannel[a]-=PWMSlope(cloudstart/60,cloudstart%60,(cloudstart+cloudduration)/60,(cloudstart+cloudduration)%60,0,PWMChannel[a],3,PWMChannel[a]);
for (int b=0;b<6;b++)
else lightningstatus=0;
if (lightningstatus) PWMChannel[b]=100;
else PWMChannel[b]=0;
//delay(10);
PWMChannel[b]=20;
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.Clear(255,0,50,93,90);
ReefAngel.LCD.DrawText(0,255,15+60,52,"CD:");
ReefAngel.LCD.DrawText(0,255,15+60,62,"NC:");
ReefAngel.LCD.DrawText(0,255,15+80,62,cloudindex);
ReefAngel.LCD.DrawText(0,255,24+80,62,"of");
ReefAngel.LCD.DrawText(0,255,38+80,62,numclouds);
ReefAngel.LCD.DrawText(0,255,15+60,72,"CS:");
ReefAngel.LCD.DrawText(0,255,15+80,72,"00:00");
ReefAngel.LCD.DrawText(0,255,15+60,82,"LS:");
ReefAngel.LCD.DrawText(0,255,15+80,82,"00:00");
int x=0;
if ((cloudstart/60)>=10) x=95; else x=98;
ReefAngel.LCD.DrawText(0,255,x,72,(cloudstart/60));
if ((cloudstart%60)>=10) x=113; else x=119;
ReefAngel.LCD.DrawText(0,255,x,72,(cloudstart%60));
ReefAngel.LCD.DrawText(0,255,15+80,52,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95; else x=58;
ReefAngel.LCD.DrawText(0,255,x,82,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113; else x=119;
ReefAngel.LCD.DrawText(0,255,x,82,((cloudstart+(cloudduration/2))%60));
There were several changes that were needed to be made. Here's a list of the changes that I made for you.
This should work now.
Ok, here's the code:
- Temp1 ==> Temp[T1_PROBE]
- Temp2 ==> Temp[T2_PROBE]
- Temp3 ==> Temp[T3_PROBE]
- Move Portal() to above ShowInterface()
- Move ShowInterface() to be last line in loop()
- Add LEDPWM defines back to code
- Changed Moonphase() to MoonPhase()
- Added PWMChannel[] array back to code
#define wifi
#define WDT
#define SIMPLE_MENU
#define CUSTOM_MAIN
// LEDPWM Channel defines for easy code reading
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
// Initial values to all 6 channels at startup.
byte PWMChannel[]={0,0,0,0,0,0};
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], T1TempColor, 15+18, 10, 10);
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 15+18, 10+10, 10);
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], T3TempColor, 15+18, 10+20, 10);
//ATO status
byte highcolor;
//End ATO status
// PWM Slope functions for PWM Channels on RA Head unit
//skimmer
//refugium
PWMChannel[LEDPWM3]=MoonPhase();
CheckCloud();
void CheckCloud()
#else
#endif
if (cloudchance)
if (cloudchance)
//delay(10);
PWMChannel[b]=20;
cloudindex++;
int x=0;
int x=0;
Thanks Curt. I got further but I'm still having some errors.
I had to change:
wire.send to wire.write
commented out (since I don't use the headunit PWM channels)
//ReefAngel.PWM.ActinicPWMSlope();
//ReefAngel.PWM.DaylightPWMSlope(); in the sketch file since I don't use the hadunit PWM channels
commented out (sketch was too big):
//#define DateTimeSetup
//#define VersionMenu
//#define DisplayLEDPWM
//#define WDT
Can you please help? Thanks again.
-J
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp: In function 'void processHTTP()':
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp:325: error: 'class ReefAngelClass' has no member named 'PWM'
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp: In function 'void SendXMLData(bool)':
C:\Documents and Settings\jdocs\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp:862: error: 'class ReefAngelClass' has no member named 'PWM'
//#define WDT
-J
You need even though you don't use the PWM on the head unit. Since you have the Expansion Module and have PWMExpansion, you MUST include DisplayLEDPWM. That's why you are getting the error.
Thanks again Curt. I was commenting out everything I could since I'm getting the sketch too big error.
I had to ditch the storm effects in my file to get it to fit.
I just compiled and everything compiled correctly. I just finished uploading and now my RA headunit says "No Internal Memory Found".
Everything sent fine:
Please help...again . Thanks.
-J
avrdude: Send: t [74] . [00] . [80] F [46] [20]
avrdude: Recv: . [14]
avrdude: Recv: . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [f8] . [01] f [66] . [85] w [77] . [85] . [80] . [ea] . [95] . [e0] J [4a] . [e0] P [50] . [e0] . [0e] . [94] . [b3] 9 [39] . [8c] . [e4] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [80] . [ea] . [95] . [e0] . [b7] . [01] . [0e] . [94] . [c6] 9 [39] . [81] . [e5] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [f8] . [01] . [e6] W [57] . [ff] O [4f] . [80] . [ea] . [95] . [e0] ` [60] . [81] J [4a] . [e0] P [50] . [e0] . [0e] . [94] a [61] 9 [39] . [86] . [e5] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [f8] . [01] . [e5] W [57] . [ff] O [4f] . [80] . [ea] . [95] . [e0] ` [60] . [81] J [4a] . [e0] P [50] . [e0] . [0e] . [94] a [61] 9 [39] . [8c] . [e5] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [80] . [ea] . [95] . [e0] . [b6] . [01] . [0e] . [94] . [c6] 9 [39] . [82] . [e6] . [99] . [e0] . [0e] . [94] ` [60] . [0b] . [c8] . [01] . [81] . [96]
avrdude: Recv: . [10]
avrdude: Send: U [55] . [00] , [2c] [20]
...deleted stuff....
avrdude: Send: U [55] . [c0] = [3d] [20]
avrdude: Send: t [74] . [00] . [04] F [46] [20]
avrdude: Recv: . [81] 7 [37] . [ca] 7 [37]
# | 100% 14.98s
avrdude: verifying ...
avrdude: 31620 bytes of flash verified
avrdude: Send: Q [51] [20]
avrdude done. Thank you.
-J
The "No Internal Memory Found" error is a new one that was added into the libraries for 0.9.0. You will need to use RAGen to generate a new Internal Memory file to upload OR use the included InternalMemory file to upload.
There is a value that is set in the internal memory that the controller looks for on startup. This will prevent people from accidentally forgetting to upload the Internal Memory first. The downside is that all people who are upgrading will have to set this value otherwise they will get this error.
If you don't have your initial internal memory file, then you can simply load this one to fix. It will not erase your values in internal memory, it will only tell the libraries that you have your memory set.
It is recommended that you load the initial values again to make sure that you don't try to use a feature that is new, but if nothing on your controller has changed other than you upgrading this will fix that problem.
#include <avr/pgmspace.h>
RA_NokiaLCD e;
e.Init();
e.BacklightOn();
// display success screen
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*2, "Internal Memory Set");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*4, "Now load your");
e.DrawText(COLOR_BLACK, COLOR_WHITE, MENU_START_COL, MENU_START_ROW*5, " RA code file");
delay(5000);
Thanks Curt. I'm back up and running. As usual, the support you guys provide is top notch. Thanks again.
-J
-J
Awesome. Glad you are up and running again.aranax wrote:Thanks Curt. I'm back up and running. As usual, the support you guys provide is top notch. Thanks again.
-J
Hey guys,
Everything works but...is it possible that you "fixed" a bug that now causes my drivers to blink? I have the meanwell "P" drivers that only work from 15% to 100% but I never had a problem running these at ~5% to 15%. I thought I got lucky as they worked between 5% and 15% without issue (no blinking). Since I updated, I'm running into the "expected" below 15% "blinking". I didn't change anything from a hardware standpoint so I don't know what it could be.
I had to change my PWMSlope from:
to
if ((hour() >= 22,00) && (hour() <= 12,30))PWMChannel[LEDPWM0]=0;
else PWMChannel[LEDPWM0]=PWMSlope(12,30,22,00,15,80,240,PWMChannel[LEDPWM0]);
if ((hour() >= 22,00) && (hour() <= 12,30))PWMChannel[LEDPWM1]=0;
else PWMChannel[LEDPWM1]=PWMSlope(12,00,22,15,15,70,240,PWMChannel[LEDPWM1]);
if ((hour() >= 22,00) && (hour() <= 12,30))PWMChannel[LEDPWM2]=0;
else PWMChannel[LEDPWM2]=PWMSlope(12,00,22,15,15,50,240,PWMChannel[LEDPWM2]);
if (hour()>22 && hour()<4)PWMChannel[LEDPWM3]=MoonPhase();
else PWMChannel[LEDPWM3]=PWMSlope(15,0,22,00,15,60,180,PWMChannel[LEDPWM3]);
Does this make sense or did I make a mistake? Thanks.
-J
to
-J
On a machine that previously did not have any RA software installed (XP SP3) I installed the 0.9.0 package from the download page, which installed with no errors. As an initial test, I opened RA Generator, and selected the items similar to my running sketch (which was done on another machine). After saving from RA Generator, and launching arduino 1.0, I tried to compile the sketch and got this error:
C:\Documents and Settings\Admin\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp: In function 'void SendXMLData(bool)':
C:\Documents and Settings\Admin\My Documents\Arduino\libraries\RA_Wifi\RA_Wifi.cpp:982: internal compiler error: Illegal instruction
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://sourceforge.net/tracker/?atid=52 ... unc=browse> for instructions.
The specific error changes if I select different options on the Controller tab in Generator. Removing the wifi option throws this compiler error instead:
C:\Program Files\Reef Angel Controller\libraries\Wire\Wire.cpp: In member function 'virtual size_t TwoWire::write(const uint8_t*, size_t)':
C:\Program Files\Reef Angel Controller\libraries\Wire\Wire.cpp:264: internal compiler error: Illegal instruction
I tried to reset to the default values and remove the features I'd checked (Watchdog, ATO logging, direct temp sensor) but got the same error after saving and compiling.
RA Generator -> Show Library Version displays Version 0.9.0.
Any suggestions? Thanks in advance.
thanks for the quick reply. Are there any other prerequisites to the 0.9.0 installer?rimai wrote:I have not seen these errors before.
OK, no worries. I will do the configuration work on a more modern machine. The one that is throwing the errors is an older industrial PC that I am using to run the client software (works fine) so it may be the hardware that is challenged.... it's a 500MHz Via processor with 512 MB RAM ...
Thanks again for the quick reply. I've been really impressed with your support.
This did the trick; no problems on a different PC.JoshSD wrote:OK, no worries. I will do the configuration work on a more modern machine.
Glad you got it working and thanks for sharing that old computers may have issues.
Hey guys,
My MoonPhase is still not working properly. Even if I comment out the IF statement and just set PWM3 to MoonPhase
ie. PWMChannel[LEDPWM3]=MoonPhase();
that channel never goes past 1% ON. It's been on 1% for the past 2 hours and my unit is NOT frozen. Any ideas? Thanks.
-J
-J
Well, we have a new moon...
It's supposed to be at 1%.
It will follow the lunar cycle. If you want it to be lit all the time, you can just set to any percentage between 0 and 100%.
Can I change the range to 15 - 100 (15 being new moon and 100 being full)? Thanks.
-J
-J
Try this:
PWMChannel[LEDPWM3]=(MoonPhase()*.85)+15;
Can a link be posted to the old RA installer? I looked on the download page and only saw the new .90 one. Thanks!
Cool, thanks Roberto.rimai wrote:http://reefangel.com/files/devlibs_0.8.5.19.zip
Oh, this is just the old Dev libs, I was looking for the old installer that had the older version of Arduino.
