RAGen v1.2.1
Re: RAGen v1.2.1
I continue to get the same error. I went back, de-installed everything, made sure all had been deleted by the un-install (it hadn't), re-downloaded the installer, and re-installed.rossbryant1956 wrote:attempting to follow instructions...getting error class twowire has no member named read. What was additionaly weird is that the example memory file will not load either. Same error. Thx
I am seeing Arduino 1.0, I made sure I have the most current libraries...what am I doing wrong?
___________________
found the post:
Oh by the way I must have not hit post a while back, I had made a message indicating that I got the code to compile and load onto the RA by deleting my User/Arduino folder and reinstalling with the Library Update Tool.
Did this, fixed it for now. Thx
Re: RAGen v1.2.1
Cool.
The problem you were running into was that Custom Colors was defined. That just means that you are using your own custom colors in a separate file. That include statement is not placed in the Internal Memory file. So you either have to manually add it or uncheck the Custom Colors (and press save on the Features tab) and then upload your Internal Memory.
Re: RAGen v1.2.1
Should we include the header file in the internal memory file so we don't run into this problems in the future?
Re: RAGen v1.2.1
one step ahead of you, already got that incorporated and will be in next release.rimai wrote:Should we include the header file in the internal memory file so we don't run into this problems in the future?
Re: RAGen v1.2.1
One additional point to consider. I wasn't intentionally using custom colors, unless it was something I did in a previous version of my code\internal memory. Not that far along in my "learning-ness." When I saw the extra post, I looked and thought my directory looked a little gunked up with other files and decided to try this.
Worked like a charm. BTW, again thx you guys. Appreciate all you do.
Re: RAGen v1.2.1
I am getting this error My Documents\Arduino\libraries\DS1307RTC\DS1307RTC.cpp:94: error: 'class TwoWire' has no member named 'write'
Any ideas? Started from scratch with my config
Re: RAGen v1.2.1
RAGen 1.2.1 and/or libraries 0.9.0 will require Arduino 1.0
My suggestion is rename your libraries folder to librariesold, uninstall the previous installer and install the newest one.
You can download it at http://www.reefangel.com/Download.ashx
Re: RAGen v1.2.1
Thanks that did it, I should know to unistall and start from scratch
Re: RAGen v1.2.1
I'm sure I'm just missing something... but I don't see a 1.2.1 installer on the downloads page? I see a "static", but it's just the RAGen executable. Can I just put that anywhere?
Re: RAGen v1.2.1
Ragen is installed for you with the Reef Angel Installer.
Re: RAGen v1.2.1
Ahh... got it. I had a crazy old version of the installer for some reason.rimai wrote:Ragen is installed for you with the Reef Angel Installer.
