Problem with iPhone app
birthdy
Post by birthdy »
hi
i got some problem with the app in iPhone
everything was running very well until i updated the app.
After i update i can control the tank, in the tab control when i click update the time update to the real time and every thing is ok.
however, the first tab "My Tank" which show the current figure of the tank- water- room-light and Ph
but when i click update the data is not update to the current time and the figure doesn't change. also it said unable to download.
do you anyway to make it work.
i think i did everything right as i can control my tank on the app but the first tab just doesn't work.
thankyou so much
wolfador
Re: Problem with iPhone app
Post by wolfador »
Do you have direct connect turned on or off?
With it turned off (default) it downloads the data from the RA "portal" instead of the controller.
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
birthdy
Post by birthdy »
I tried to set it on and off but nothing really change.
The data still doesn't work
wolfador
Post by wolfador »
birthdy wrote:I tried to set it on and off but nothing really change.
if you don't mind could you PM me the ip / url you are using? I would like to try and see if I can recreate the problem so I can track it down and fix.
John
wolfador
Post by wolfador »
Got your PM. It looks like you are still running the older libraries so you may want to upgrade to the new ones so you can get the "portal" features. It should still work though, so I will check it out when I get home.
Also did you try quitting and restarting the app or restarting your phone?
John
birthdy
Post by birthdy »
how do i update the libraries??
also what do the portal feature do?
sorry I'm lacking knowledge about these thing
birthdy wrote:how do i update the libraries??
http://forum.reefangel.com/viewtopic.php?f=8&t=2
birthdy wrote: also what do the portal feature do?
This is the Portal: http://forum.reefangel.com/portal.php
Basically, you can see parameters, logs and even control your relays from outside your network once it is setup.
Here is some more info:
http://forum.reefangel.com/viewtopic.php?f=20&t=716
wolfador
Post by wolfador »
Tried to check out your controller and I cannot reach it from the web anymore. Did the ip change?
John
birthdy
Post by birthdy »
tried again i can still view my data on the web 192.168.2.14 that the local ip of the controller
that the WAN IP 121.216.198.130 maybe you can use that to do something.
but every time i restart router the WAN IP change that why i set up DDNS
i hope that help
I could get to your controller just fine using the WAN IP. If you setup a DDNS, you need a client/tool on your computer (or router) that updates the DDNS entry every time your WAN IP address changes. DDNS makes mention of it on their site and tells you how to configure it.
birthdy
Post by birthdy »
Yes I can do that ebut the problem is with the app.
I can view my data and control Ra from the web.
But after I put in the app I can still update the controller and known which port is on and off and also able to control it.
But the data, temperature ph on the app just won't update for me
That is my problem
aranax
Post by aranax »
did this get resolved? I'm having the same issue with the iphone app. Please help when you get a chance. Thanks.
Jeremiah
wolfador
Post by wolfador »
aranax wrote:did this get resolved? I'm having the same issue with the iphone app. Please help when you get a chance. Thanks.
Jeremiah
What issue are you having? If that data is not showing is direct connect on or off? With it off it will grab the information from the "portal," on it goes direct to controller.
John
ahmedess
Post by ahmedess »
I m having the same problem. direct connect is on and I can view controls and memory but i cannot view My Tank parameters. whenever i press on My Tank it says "Enter RA URL in settings" even though i have direct connect on and it doesnt show any values
Which libraries version are you running?
ahmedess
Post by ahmedess »
0.9.2
wolfador
Post by wolfador »
ahmedess wrote:I m having the same problem. direct connect is on and I can view controls and memory but i cannot view My Tank parameters. whenever i press on My Tank it says "Enter RA URL in settings" even though i have direct connect on and it doesnt show any values
Are you using your ip address or a url to connect to? If you can send me a pm with the info and I can test it on my device.
John
ahmedess
Post by ahmedess »
problem solved. I changed direct connect to on but i forgot to click on the save button on top in the settings that was the problem
