Problem with iPhone app
Re: Problem with iPhone app
I could get to your controller just fine using the WAN IP. If you setup a DDNS, you need a client/tool on your computer (or router) that updates the DDNS entry every time your WAN IP address changes. DDNS makes mention of it on their site and tells you how to configure it.
birthdy
Post by birthdy »
Yes I can do that ebut the problem is with the app.
I can view my data and control Ra from the web.
But after I put in the app I can still update the controller and known which port is on and off and also able to control it.
But the data, temperature ph on the app just won't update for me
That is my problem
aranax
Post by aranax »
did this get resolved? I'm having the same issue with the iphone app. Please help when you get a chance. Thanks.
Jeremiah
wolfador
Post by wolfador »
aranax wrote:did this get resolved? I'm having the same issue with the iphone app. Please help when you get a chance. Thanks.
Jeremiah
What issue are you having? If that data is not showing is direct connect on or off? With it off it will grab the information from the "portal," on it goes direct to controller.
John
ahmedess
Post by ahmedess »
I m having the same problem. direct connect is on and I can view controls and memory but i cannot view My Tank parameters. whenever i press on My Tank it says "Enter RA URL in settings" even though i have direct connect on and it doesnt show any values
Which libraries version are you running?
ahmedess
Post by ahmedess »
0.9.2
wolfador
Post by wolfador »
ahmedess wrote:I m having the same problem. direct connect is on and I can view controls and memory but i cannot view My Tank parameters. whenever i press on My Tank it says "Enter RA URL in settings" even though i have direct connect on and it doesnt show any values
Are you using your ip address or a url to connect to? If you can send me a pm with the info and I can test it on my device.
John
ahmedess
Post by ahmedess »
problem solved. I changed direct connect to on but i forgot to click on the save button on top in the settings that was the problem
