PWM inversion
PWM inversion
hey curt, how hard would it be to invert the pwm values displayed on the main? since i have buckpucks they run backwards, 0% being on, 100% being off. roberto already swapped the code so i use standard 0-100 ramp but the display shows the inverse...if actinic lights are 80% on pde code, the display shows 20%. a fix would be nice, thanks in advance.
Re: PWM inversion
inverting the displayed values would be pretty simple to do. if you make the changes, remember that you did because every time you update the libraries you will have to change this back:NanoTrevor wrote:hey curt, how hard would it be to invert the pwm values displayed on the main? since i have buckpucks they run backwards, 0% being on, 100% being off. roberto already swapped the code so i use standard 0-100 ramp but the display shows the inverse...if actinic lights are 80% on pde code, the display shows 20%. a fix would be nice, thanks in advance.
Inside ReefAngel_NokiaLCD.cpp, look for this function:
void ReefAngel_NokiaLCD::DrawMonitor(byte x, byte y, ParamsStruct Params, byte DaylightPWMValue, byte ActnicPWMValue)
void ReefAngel_NokiaLCD::DrawMonitor(byte x, byte y, ParamsStruct Params)
DrawText(T1TempColor,DefaultBGColor,x,y,"T1:");
DrawSingleMonitor(Params.Temp1, T1TempColor, x+18, y,10);
DrawText(T2TempColor,DefaultBGColor,x,y+10,"T2:");
DrawSingleMonitor(Params.Temp2, T2TempColor, x+18, y+10,10);
DrawText(T3TempColor,DefaultBGColor,x,y+20,"T3:");
DrawSingleMonitor(Params.Temp3, T3TempColor, x+18, y+20,10);
DrawText(PHColor,DefaultBGColor,x+60,y,"PH:");
DrawSingleMonitor(Params.PH, PHColor, x+78, y,100);
DrawText(DPColor,DefaultBGColor,x+60,y+10,"DP:");
// Code should be 100 - DaylightPWMValue
DrawSingleMonitor(DaylightPWMValue, DPColor, x+78, y+10,1); // Change this line
DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
// Code should be 100 - ActinicPWMValue
DrawSingleMonitor(ActnicPWMValue, APColor, x+78, y+20,1); // Change this line
Re: PWM inversion
hey curt, i added the 100-dp and 100-ap and still get the old inverted values...?
Re: PWM inversion
Are you using the CUSTOM_MAIN for the custom main screen?NanoTrevor wrote:hey curt, i added the 100-dp and 100-ap and still get the old inverted values...?
Did you save the file after you made those changes?
Did you reupload the PDE to the controller?
I know some of those sound like silly questions, but I have to ask them to make sure. A lot of times the problem is a simple error that is overlooked.
Re: PWM inversion
1. No, probably the problem cause..
2. Yes
3. Yes
so the dumb question, how do i enable custom main
2. Yes
3. Yes
Re: PWM inversion
You don't have to have CUSTOM_MAIN enabled to get it to work. I was thinking you were which would make it not work.NanoTrevor wrote:1. No, probably the problem cause..
2. Yes
3. Yes
I just tested the code on my end and it works great. Here's what I used:
DrawSingleMonitor(100-DaylightPWMValue, DPColor, x+78, y+10,1);
DrawSingleMonitor(100-ActnicPWMValue, APColor, x+78, y+20,1);
Re: PWM inversion
would the fact that roberto changed the code inside the pde loop to invert values there, would that affect things?
byte BuckPuckActinic=0;
byte BuckPuckDaylight=0;
ReefAngel.FeedingModePorts = B00000001; //turns off return pump
ReefAngel.WaterChangePorts = B10110001; //turns off return pump, heater, fan/chiller and ATO
ReefAngel.OverheatShutoffPorts = B00100110; //turns off lights and heater
ReefAngel.LightsOnPorts = B00001110; //turns on lights
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port4);
BuckPuckActinic=PWMSlope(8,0,19,0,0,50,60,BuckPuckActinic); //actinic leds ramp up from 0% at 7:30am to 60% at 8:30am and ramp down from 6:00pm to 7:00pm back to 0%
BuckPuckDaylight=PWMSlope(8,30,18,0,0,35,60,BuckPuckDaylight); //daylight leds ramp up from 0% at 8:30am to 50% at 9:30am and ramp down from 5:00pm to 6:0pm back to 0%
ReefAngel.PWM.SetActinic(100-BuckPuckActinic); // invert value for buckpucks
ReefAngel.PWM.SetDaylight(100-BuckPuckDaylight); // invert value for buckpucks
Re: PWM inversion
Yes it would affect things. If he's inverting it already and we try to invert it again, we are just changing things back to normal. So you would not need the changes that I made at all. You would just leave the display code alone and use what he has done. That would be a lot simpler.NanoTrevor wrote:would the fact that roberto changed the code inside the pde loop to invert values there, would that affect things?
Re: PWM inversion
hey curt, the prob is though what he did works for the (7,30,18,00,0,50,60) but not the displayed values. meaning i can code 0-100 for the ramping but the display still shows the wrong inverted values, if it ramps to 70 the display reads 30.
thanks
thanks
Re: PWM inversion
If he inverts it to work properly with the code, then what we need to do is what I mentioned before with inverting it when we display it. I will test it tonight when I get home.
Re: PWM inversion
I just tested the code. I copied the code that Roberto posted about inverting the PWM values inside the PDE and watched it display the inverted values. I then applied my fix for the display and it worked perfectly. It showed 0% when it should be 100%.
Here's the code that I used: (it was the same as I posted before)
Make sure when you make the change you save the file before you compile and upload to the controller.
Re: PWM inversion
ill try again, thanks for testing it
no luck...sorry not sure what im missing...
#include "WProgram.h"
#include "Time.h"
#include "NokiaLCD.h"
#include <EEPROM.h>
// Define Software SPI Pin Signal
#define BL 2 // Digital 2 --> BL
#define CS 3 // Digital 3 --> #CS
#define CLK 4 // Digital 4 --> SCLK
#define SDA 5 // Digital 5 --> SDATA
#define RESET 6 // Digital 6 --> #RESET
#define actinicPWMPin 9
#define daylightPWMPin 10
// Phillips PCF8833 Command Set
#define NOP 0x00 // nop
#define SWRESET 0x01 // software reset
#define BSTROFF 0x02 // booster voltage OFF
#define BSTRON 0x03 // booster voltage ON
#define RDDIDIF 0x04 // read display identification
#define RDDST 0x09 // read display status
#define SLEEPIN 0x10 // sleep in
#define SLEEPOUT 0x11 // sleep out
#define PTLON 0x12 // partial display mode
#define NORON 0x13 // display normal mode
#define INVOFF 0x20 // inversion OFF
#define INVON 0x21 // inversion ON
#define DALO 0x22 // all pixel OFF
#define DAL 0x23 // all pixel ON
#define SETCON 0x25 // write contrast
#define DISPOFF 0x28 // display OFF
#define DISPON 0x29 // display ON
#define CASET 0x2A // column address set
#define PASET 0x2B // page address set
#define RAMWR 0x2C // memory write
#define RGBSET 0x2D // colour set
#define PTLAR 0x30 // partial area
#define VSCRDEF 0x33 // vertical scrolling definition
#define TEOFF 0x34 // test mode
#define TEON 0x35 // test mode
#define MADCTL 0x36 // memory access control
#define SEP 0x37 // vertical scrolling start address
#define IDMOFF 0x38 // idle mode OFF
#define IDMON 0x39 // idle mode ON
#define COLMOD 0x3A // interface pixel format
#define SETVOP 0xB0 // set Vop
#define BRS 0xB4 // bottom row swap
#define TRS 0xB6 // top row swap
#define DISCTR 0xB9 // display control
//#define DAOR 0xBA // data order(DOR)
#define TCDFE 0xBD // enable/disable DF temperature compensation
#define TCVOPE 0xBF // enable/disable Vop temp comp
#define EC 0xC0 // internal or external oscillator
#define SETMUL 0xC2 // set multiplication factor
#define TCVOPAB 0xC3 // set TCVOP slopes A and B
#define TCVOPCD 0xC4 // set TCVOP slopes c and d
#define TCDF 0xC5 // set divider frequency
#define DF8COLOR 0xC6 // set divider frequency 8-color mode
#define SETBS 0xC7 // set bias system
#define RDTEMP 0xC8 // temperature read back
#define NLI 0xC9 // n-line inversion
#define RDID1 0xDA // read ID1
#define RDID2 0xDB // read ID2
#define RDID3 0xDC // read ID3
//a few basic colors
#define RED 0xE0
#define GREEN 0x1C
#define BLUE 0x03
#define YELLOW 0xFC
#define MAGENTA 0xE3
#define CYAN 0x1F
#define BLACK 0x00
#define WHITE 0xFF
#define WaterTempColor 0xE0
#define LightsTempColor 0xCC
#define AmbientTempColor 0xAA
#define PHColor 0x34
#define DPColor 0x88
#define APColor 0x49
#define cbi(reg, bit) (reg&=~(1<<bit))
#define sbi(reg, bit) (reg|= (1<<bit))
#if defined(__AVR_ATmega2560__)
#define BL0 cbi(PORTE,4);
#define BL1 sbi(PORTE,4);
#define CS0 cbi(PORTE,5);
#define CS1 sbi(PORTE,5);
#define CLK0 cbi(PORTG,5);
#define CLK1 sbi(PORTG,5);
#define SDA0 cbi(PORTE,3);
#define SDA1 sbi(PORTE,3);
#define RESET0 cbi(PORTH,3);
#define RESET1 sbi(PORTH,3);
#else
#define BL0 cbi(PORTD,BL);
#define BL1 sbi(PORTD,BL);
#define CS0 cbi(PORTD,CS);
#define CS1 sbi(PORTD,CS);
#define CLK0 cbi(PORTD,CLK);
#define CLK1 sbi(PORTD,CLK);
#define SDA0 cbi(PORTD,SDA);
#define SDA1 sbi(PORTD,SDA);
#define RESET0 cbi(PORTD,RESET);
#define RESET1 sbi(PORTD,RESET);
#endif
byte const font[475] = {
0x00 , 0x00 , 0x00 , 0x00 , 0x00 ,
0x00 , 0x06 , 0x5F , 0x06 , 0x00 , // !
0x07 , 0x03 , 0x00 , 0x07 , 0x03 , // ,
0x24 , 0x7E , 0x24 , 0x7E , 0x24 , // #
0x24 , 0x2B , 0x6A , 0x12 , 0x00 , // $
0x63 , 0x13 , 0x08 , 0x64 , 0x63 , // %
0x36 , 0x49 , 0x56 , 0x20 , 0x50 , // &
0x00 , 0x07 , 0x03 , 0x00 , 0x00 , // //
0x00 , 0x3E , 0x41 , 0x00 , 0x00 , // (
0x00 , 0x41 , 0x3E , 0x00 , 0x00 , // )
0x08 , 0x3E , 0x1C , 0x3E , 0x08 , // *
0x08 , 0x08 , 0x3E , 0x08 , 0x08 , // +
0x00 , 0xE0 , 0x60 , 0x00 , 0x00 , // ,
0x08 , 0x08 , 0x08 , 0x08 , 0x08 , // -
0x00 , 0x60 , 0x60 , 0x00 , 0x00 , // .
0x20 , 0x10 , 0x08 , 0x04 , 0x02 , // /
0x3E , 0x51 , 0x49 , 0x45 , 0x3E , // 0
0x00 , 0x42 , 0x7F , 0x40 , 0x00 , // 1
0x62 , 0x51 , 0x49 , 0x49 , 0x46 , // 2
0x22 , 0x49 , 0x49 , 0x49 , 0x36 , // 3
0x18 , 0x14 , 0x12 , 0x7F , 0x10 , // 4
0x2F , 0x49 , 0x49 , 0x49 , 0x31 , // 5
0x3C , 0x4A , 0x49 , 0x49 , 0x30 , // 6
0x01 , 0x71 , 0x09 , 0x05 , 0x03 , // 7
0x36 , 0x49 , 0x49 , 0x49 , 0x36 , // 8
0x06 , 0x49 , 0x49 , 0x29 , 0x1E , // 9
0x00 , 0x6C , 0x6C , 0x00 , 0x00 , // :
0x00 , 0xEC , 0x6C , 0x00 , 0x00 , // ;
0x08 , 0x14 , 0x22 , 0x41 , 0x00 , // <
0x24 , 0x24 , 0x24 , 0x24 , 0x24 , // =
0x00 , 0x41 , 0x22 , 0x14 , 0x08 , // >
0x02 , 0x01 , 0x59 , 0x09 , 0x06 , // ?
0x3E , 0x41 , 0x5D , 0x55 , 0x1E , // @
0x7E , 0x09 , 0x09 , 0x09 , 0x7E , // A
0x7F , 0x49 , 0x49 , 0x49 , 0x36 , // B
0x3E , 0x41 , 0x41 , 0x41 , 0x22 , // C
0x7F , 0x41 , 0x41 , 0x41 , 0x3E , // D
0x7F , 0x49 , 0x49 , 0x49 , 0x41 , // E
0x7F , 0x09 , 0x09 , 0x09 , 0x01 , // F
0x3E , 0x41 , 0x49 , 0x49 , 0x7A , // G
0x7F , 0x08 , 0x08 , 0x08 , 0x7F , // H
0x00 , 0x41 , 0x7F , 0x41 , 0x00 , // I
0x30 , 0x40 , 0x40 , 0x40 , 0x3F , // J
0x7F , 0x08 , 0x14 , 0x22 , 0x41 , // K
0x7F , 0x40 , 0x40 , 0x40 , 0x40 , // L
0x7F , 0x02 , 0x04 , 0x02 , 0x7F , // M
0x7F , 0x02 , 0x04 , 0x08 , 0x7F , // N
0x3E , 0x41 , 0x41 , 0x41 , 0x3E , // O
0x7F , 0x09 , 0x09 , 0x09 , 0x06 , // P
0x3E , 0x41 , 0x51 , 0x21 , 0x5E , // Q
0x7F , 0x09 , 0x09 , 0x19 , 0x66 , // R
0x26 , 0x49 , 0x49 , 0x49 , 0x32 , // S
0x01 , 0x01 , 0x7F , 0x01 , 0x01 , // T
0x3F , 0x40 , 0x40 , 0x40 , 0x3F , // U
0x1F , 0x20 , 0x40 , 0x20 , 0x1F , // V
0x3F , 0x40 , 0x3C , 0x40 , 0x3F , // W
0x63 , 0x14 , 0x08 , 0x14 , 0x63 , // X
0x07 , 0x08 , 0x70 , 0x08 , 0x07 , // Y
0x71 , 0x49 , 0x45 , 0x43 , 0x00 , // Z
0x00 , 0x7F , 0x41 , 0x41 , 0x00 , // [
0x02 , 0x04 , 0x08 , 0x10 , 0x20 , // Back slash
0x00 , 0x41 , 0x41 , 0x7F , 0x00 , // ]
0x04 , 0x02 , 0x01 , 0x02 , 0x04 , // ^
0x80 , 0x80 , 0x80 , 0x80 , 0x80 , // _
//0x00 , 0x03 , 0x07 , 0x00 , 0x00 , // `
0x20 , 0x40 , 0x80 , 0x40 , 0x20 , // `
0x20 , 0x54 , 0x54 , 0x54 , 0x78 , // a
0x7F , 0x44 , 0x44 , 0x44 , 0x38 , // b
0x38 , 0x44 , 0x44 , 0x44 , 0x28 , // c
0x38 , 0x44 , 0x44 , 0x44 , 0x7F , // d
0x38 , 0x54 , 0x54 , 0x54 , 0x18 , // e
0x08 , 0x7E , 0x09 , 0x09 , 0x00 , // f
0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C , // g
0x7F , 0x04 , 0x04 , 0x78 , 0x00 , // h
0x00 , 0x00 , 0x7D , 0x00 , 0x00 , // i
0x40 , 0x80 , 0x84 , 0x7D , 0x00 , // j
0x7F , 0x10 , 0x28 , 0x44 , 0x00 , // k
0x00 , 0x00 , 0x7F , 0x40 , 0x00 , // l
0x7C , 0x04 , 0x18 , 0x04 , 0x78 , // m
0x7C , 0x04 , 0x04 , 0x78 , 0x00 , // n
0x38 , 0x44 , 0x44 , 0x44 , 0x38 , // o
0xFC , 0x44 , 0x44 , 0x44 , 0x38 , // p
0x38 , 0x44 , 0x44 , 0x44 , 0xFC , // q
0x44 , 0x78 , 0x44 , 0x04 , 0x08 , // r
0x08 , 0x54 , 0x54 , 0x54 , 0x20 , // s
0x04 , 0x3E , 0x44 , 0x24 , 0x00 , // t
0x3C , 0x40 , 0x20 , 0x7C , 0x00 , // u
0x1C , 0x20 , 0x40 , 0x20 , 0x1C , // v
0x3C , 0x60 , 0x30 , 0x60 , 0x3C , // w
0x6C , 0x10 , 0x10 , 0x6C , 0x00 , // x
0x9C , 0xA0 , 0x60 , 0x3C , 0x00 , // y
0x64 , 0x54 , 0x54 , 0x4C , 0x00 , // z
//0x08 , 0x3E , 0x41 , 0x41 , 0x00 , // {
0x33 , 0x66 , 0xCC , 0x66 , 0x33 , // {
0x00 , 0x00 , 0x7F , 0x00 , 0x00 , // |
//0x00 , 0x41 , 0x41 , 0x3E , 0x08 , // }
0xCC , 0x66 , 0x33 , 0x66 , 0xCC , // }
0x02 , 0x01 , 0x02 , 0x01 , 0x00 // ~
NokiaLCD::NokiaLCD()
pinMode(BL,OUTPUT);
pinMode(CS,OUTPUT);
pinMode(CLK,OUTPUT);
pinMode(SDA,OUTPUT);
pinMode(RESET,OUTPUT);
digitalWrite(BL,HIGH);
digitalWrite(CS,HIGH);
digitalWrite(CLK,HIGH);
digitalWrite(SDA,HIGH);
digitalWrite(RESET,HIGH);
#else
DDRD |= B01111100; // Set SPI pins as output
PORTD |= B01111000; // Set SPI pins HIGH
#endif
void NokiaLCD::ShiftBits(byte b)
byte Bit;
for (Bit = 0; Bit < 8; Bit++) // 8 Bit Write
CLK0 // Standby SCLK
if((b&0x80)>>7)
SDA1
SDA0
CLK1 // Strobe signal bit
b <<= 1; // Next bit data
void NokiaLCD::SendData(byte data) {
CLK0
SDA1
CLK1
ShiftBits(data);
void NokiaLCD::SendCMD(byte data) {
CLK0
SDA0
CLK1
ShiftBits(data);
void NokiaLCD::SetBox(byte x1, byte y1, byte x2, byte y2)
SendCMD(CASET); // page start/end ram
SendData(x1); // for some reason starts at 2
SendData(x2);
SendCMD(PASET); // column start/end ram
SendData(y1);
SendData(y2);
void NokiaLCD::Clear(byte color, byte x1, byte y1, byte x2, byte y2)
uint16_t xmin, xmax, ymin, ymax;
uint16_t i;
unsigned int icolor;
icolor = ~color;
// best way to create a filled rectangle is to define a drawing box
// and loop two pixels at a time
// calculate the min and max for x and y directions
xmin = (x1 <= x2) ? x1 : x2;
xmax = (x1 > x2) ? x1 : x2;
ymin = (y1 <= y2) ? y1 : y2;
ymax = (y1 > y2) ? y1 : y2;
// specify the controller drawing box according to those limits
// Row address set (command 0x2B)
SendCMD(CASET);
SendData(xmin);
SendData(xmax);
// Column address set (command 0x2A)
SendCMD(PASET);
SendData(ymin);
SendData(ymax);
// WRITE MEMORY
SendCMD(RAMWR);
// loop on total number of pixels / 2
for (i = 0; i < ((xmax - xmin + 1) * (ymax - ymin + 1)) ; i++)
// use the color value to output three data bytes covering two pixels
// For some reason, it has to send blue first then green and red
//SendData((color << 4) | ((color & 0xF0) >> 4));
//SendData(((color >> 4) & 0xF0) | (color & 0x0F));
//SendData((color & 0xF0) | (color >> 8));
SendData(icolor);
void NokiaLCD::Init()
// Initial state
CS1
CS0
// Hardware Reset LCD
RESET0
delay(100);
RESET1
delay(100);
//Software Reset
SendCMD(SWRESET);
//Sleep Out
SendCMD(SLEEPOUT);
//Booster ON
SendCMD(BSTRON);
//Display On
SendCMD(DISPON);
//Normal display mode
SendCMD(NORON);
//Display inversion on
SendCMD(INVON);
//Data order
//SendCMD(0xBA);
SendCMD(SETCON);
SendData(0x38);
//Memory data access control
SendCMD(MADCTL);
//SendData(8|64); //rgb + MirrorX
//SendData(8|128); //rgb + MirrorY
SendData(0xc0);
SendCMD(COLMOD);
SendData(2); //16-Bit per Pixel
Clear(0xff,0,0,131,131);
void NokiaLCD::Sleep()
SendCMD(DISPOFF);
SendCMD(SLEEPIN);
BacklightOff();
void NokiaLCD::Wake()
BacklightOn();
SendCMD(SLEEPOUT);
SendCMD(DISPON);
void NokiaLCD::BacklightOn()
BL1
void NokiaLCD::BacklightOff()
BL0
void NokiaLCD::DrawTextLine(byte fcolor, byte bcolor,byte x, byte y,char c)
unsigned int i;
unsigned int ifcolor, ibcolor;
ifcolor = ~fcolor;
ibcolor = ~bcolor;
SetBox(x,y,x,y+7);
SendCMD(RAMWR);
for(i=0;i<8;i++)
if (1<<i & c)
SendData(ifcolor);
SendData(ibcolor);
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,char *text)
byte c;
byte t;
unsigned int i;
unsigned int j;
while(*text != 0)
t = *text;
i = t - 32;
i = i * 5;
for(j = i; j < i+5; j++)
c = font[j];
DrawTextLine(fcolor, bcolor, x++, y, c);
DrawTextLine(fcolor, bcolor, x++, y, 0);
text++;
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,int text)
char temp[6];
itoa(text,temp,10);
DrawText(fcolor, bcolor, x, y,temp);
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,byte text)
char temp[6];
itoa(text,temp,10);
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,long text)
char temp[20];
ltoa(text,temp,10);
void NokiaLCD::PutPixel(byte color, byte x, byte y)
icolor = ~color;
SendData(x); // for some reason starts at 2
SendData(x+1);
SendData(y);
SendData(y+1);
SendCMD(RAMWR);
SendData(icolor);
void NokiaLCD::SetContrast(byte Contrast)
SendCMD(SETCON);
SendData(Contrast);
void NokiaLCD::DrawDate(byte x, byte y)
//byte iTimeHourOffset=0;
char text[21];
char temp[]=" ";
strcpy(text,"");
itoa(month(),temp,10);
if (temp[1]==0) strcat(text,"0");
strcat(text,temp);
strcat(text,"/");
itoa(day(),temp,10);
strcat(text,temp);
strcat(text,"/");
itoa(year()-2000,temp,10);
strcat(text,temp);
strcat(text," ");
//if (iTimeHour>12) iTimeHourOffset=12;
itoa(hourFormat12(),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(minute(),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(second(),temp,10);
strcat(text,temp);
if (isAM())
strcat(text," AM");
strcat(text," PM");
DrawText(RED,WHITE,x,y,text);
void NokiaLCD::DrawOutletBox(byte x, byte y,byte RelayData)
Clear(94,x,y,x+104,y);
Clear(94,x,y+12,x+104,y+12);
for (int a=0;a<8;a++)
byte bcolor=WHITE;
byte fcolor=BLACK;
char temp[]=" ";
if ((RelayData&(1<<a))==1<<a)
bcolor=13;
fcolor=WHITE;
Clear(bcolor,x+1+(a*13),y+1,x+14+(a*13),y+11);
itoa(a+1,temp,10);
DrawText(fcolor,bcolor,x+5+(a*13),y+3,temp);
void NokiaLCD::DrawSingleMonitor(int Temp, byte fcolor, byte x, byte y, byte decimal)
char text[7];
char temptxt[3];
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,text,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(text , ".");
if (Temp%decimal<10 && decimal==100) strcat(text , "0");
strcat(text , temptxt);
Clear(WHITE,x,y,x+30,y+8);
DrawText(fcolor,WHITE,x,y,text);
void NokiaLCD::DrawMonitor(byte x, byte y, ParamsStruct Params, byte DaylightPWMValue, byte ActnicPWMValue)
DrawText(WaterTempColor,WHITE,x,y,"T1:");
DrawSingleMonitor(Params.Temp1, WaterTempColor, x+18, y,10);
DrawText(LightsTempColor,WHITE,x,y+10,"T2:");
DrawSingleMonitor(Params.Temp2, LightsTempColor, x+18, y+10,10);
DrawText(AmbientTempColor,WHITE,x,y+20,"T3:");
DrawSingleMonitor(Params.Temp3, AmbientTempColor, x+18, y+20,10);
DrawText(PHColor,WHITE,x+60,y,"PH:");
void NokiaLCD::DrawSingleGraph(byte color, byte x, byte y, int I2CAddr, int EEaddr)
int start;
for (int a=0;a<120;a++)
start=EEaddr+a;
if (start > (int(EEaddr/120)+1)*120) start=start-120;
Wire.beginTransmission(I2CAddr);
Wire.send((int)(start >> 8)); // MSB
Wire.send((int)(start & 0xFF)); // LSB
Wire.endTransmission();
Wire.requestFrom(I2CAddr,1);
if (Wire.available()) PutPixel(color,x+a,y+50-Wire.receive());
void NokiaLCD::DrawEEPromImage(int swidth, int sheight, byte x, byte y, int I2CAddr, int EEaddr)
int count = 0;
SetBox(x,y,swidth-1+x,sheight-1+y);
SendCMD(0x2c);
//for (int j = 0; j < sheight; j++)
// for (int i = 0; i < swidth; i++)
//e.lcd_put_pixel(readEEPROM(I2CEEPROM,count+start),i+x,j+y);
// count++;
// WatchDogReset();
do
Wire.send((int)(EEaddr+count >> 8)); // MSB
Wire.send((int)(EEaddr+count & 0xFF)); // LSB
Wire.requestFrom(I2CAddr,30);
for (int j = 0; j < 30; j++)
count+=1;
if ((count<swidth*sheight) && Wire.available()) SendData(~Wire.receive());
while (count < swidth*sheight);
void NokiaLCD::DrawGraph(byte x, byte y, int I2CAddr, int pointer)
Clear(WHITE,0,y,131,y+50);
Clear(BLACK,x,y,x,y+50);
for (int i=6; i<=131; i+=3){
PutPixel(0x49, i, y+25);
DrawSingleGraph(WaterTempColor,x,y,I2CAddr,EEPROM.read(pointer));
DrawSingleGraph(LightsTempColor,x,y,I2CAddr,EEPROM.read(pointer)+120);
DrawSingleGraph(AmbientTempColor,x,y,I2CAddr,EEPROM.read(pointer)+240);
DrawSingleGraph(PHColor,x,y,I2CAddr,EEPROM.read(pointer)+360);
Re: PWM inversion
Are you using my development libraries? This is the Standard Libraries code. This is the NokiaLCD.cpp file and not the ReefAngel_NokiaLCD.cpp. If you are running the dev libraries and modify this code, then it won't work because this code isn't even used.
Re: PWM inversion
oh yup im using the dev lib...now what?
Re: PWM inversion
If you converted to dev lib, just go back in the thread and apply the changes to the file ReefAngel_Nokia.cpp
Re: PWM inversion
thanks roberto, ill try that. hey quick question, when i reload the pde the lights go full on, which at night can be a bit startling to the fish...anyway of stopping this?
Re: PWM inversion
That's because the pucks are inverted. 0V means full on. When the controller is being programmed, it outputs 0V.
The only way to avoid this is by hooking up the pucks where 0V means no light output.
Re: PWM inversion
oh ok, that wont happen, its working great and im gonna leave well enough alone. so since i was not observant and was trying to put the 100- changes into the wrong nokia library, no go. i just dropped the changes into the correct library and its working awesome, thanks roberto and curt.
