PWM inversion
Re: PWM inversion
If he inverts it to work properly with the code, then what we need to do is what I mentioned before with inverting it when we display it. I will test it tonight when I get home.
Re: PWM inversion
I just tested the code. I copied the code that Roberto posted about inverting the PWM values inside the PDE and watched it display the inverted values. I then applied my fix for the display and it worked perfectly. It showed 0% when it should be 100%.
Here's the code that I used: (it was the same as I posted before)
Make sure when you make the change you save the file before you compile and upload to the controller.
DrawText(DPColor,DefaultBGColor,x+60,y+10,"DP:");
DrawSingleMonitor(100-DaylightPWMValue, DPColor, x+78, y+10,1);
DrawText(APColor,DefaultBGColor,x+60,y+20,"AP:");
DrawSingleMonitor(100-ActnicPWMValue, APColor, x+78, y+20,1);
Re: PWM inversion
ill try again, thanks for testing it
no luck...sorry not sure what im missing...
#include "WProgram.h"
#include "Time.h"
#include "NokiaLCD.h"
#include <EEPROM.h>
// Define Software SPI Pin Signal
#define BL 2 // Digital 2 --> BL
#define CS 3 // Digital 3 --> #CS
#define CLK 4 // Digital 4 --> SCLK
#define SDA 5 // Digital 5 --> SDATA
#define RESET 6 // Digital 6 --> #RESET
#define actinicPWMPin 9
#define daylightPWMPin 10
// Phillips PCF8833 Command Set
#define NOP 0x00 // nop
#define SWRESET 0x01 // software reset
#define BSTROFF 0x02 // booster voltage OFF
#define BSTRON 0x03 // booster voltage ON
#define RDDIDIF 0x04 // read display identification
#define RDDST 0x09 // read display status
#define SLEEPIN 0x10 // sleep in
#define SLEEPOUT 0x11 // sleep out
#define PTLON 0x12 // partial display mode
#define NORON 0x13 // display normal mode
#define INVOFF 0x20 // inversion OFF
#define INVON 0x21 // inversion ON
#define DALO 0x22 // all pixel OFF
#define DAL 0x23 // all pixel ON
#define SETCON 0x25 // write contrast
#define DISPOFF 0x28 // display OFF
#define DISPON 0x29 // display ON
#define CASET 0x2A // column address set
#define PASET 0x2B // page address set
#define RAMWR 0x2C // memory write
#define RGBSET 0x2D // colour set
#define PTLAR 0x30 // partial area
#define VSCRDEF 0x33 // vertical scrolling definition
#define TEOFF 0x34 // test mode
#define TEON 0x35 // test mode
#define MADCTL 0x36 // memory access control
#define SEP 0x37 // vertical scrolling start address
#define IDMOFF 0x38 // idle mode OFF
#define IDMON 0x39 // idle mode ON
#define COLMOD 0x3A // interface pixel format
#define SETVOP 0xB0 // set Vop
#define BRS 0xB4 // bottom row swap
#define TRS 0xB6 // top row swap
#define DISCTR 0xB9 // display control
//#define DAOR 0xBA // data order(DOR)
#define TCDFE 0xBD // enable/disable DF temperature compensation
#define TCVOPE 0xBF // enable/disable Vop temp comp
#define EC 0xC0 // internal or external oscillator
#define SETMUL 0xC2 // set multiplication factor
#define TCVOPAB 0xC3 // set TCVOP slopes A and B
#define TCVOPCD 0xC4 // set TCVOP slopes c and d
#define TCDF 0xC5 // set divider frequency
#define DF8COLOR 0xC6 // set divider frequency 8-color mode
#define SETBS 0xC7 // set bias system
#define RDTEMP 0xC8 // temperature read back
#define NLI 0xC9 // n-line inversion
#define RDID1 0xDA // read ID1
#define RDID2 0xDB // read ID2
#define RDID3 0xDC // read ID3
//a few basic colors
#define RED 0xE0
#define GREEN 0x1C
#define BLUE 0x03
#define YELLOW 0xFC
#define MAGENTA 0xE3
#define CYAN 0x1F
#define BLACK 0x00
#define WHITE 0xFF
#define WaterTempColor 0xE0
#define LightsTempColor 0xCC
#define AmbientTempColor 0xAA
#define PHColor 0x34
#define DPColor 0x88
#define APColor 0x49
#define cbi(reg, bit) (reg&=~(1<<bit))
#define sbi(reg, bit) (reg|= (1<<bit))
#if defined(__AVR_ATmega2560__)
#define BL0 cbi(PORTE,4);
#define BL1 sbi(PORTE,4);
#define CS0 cbi(PORTE,5);
#define CS1 sbi(PORTE,5);
#define CLK0 cbi(PORTG,5);
#define CLK1 sbi(PORTG,5);
#define SDA0 cbi(PORTE,3);
#define SDA1 sbi(PORTE,3);
#define RESET0 cbi(PORTH,3);
#define RESET1 sbi(PORTH,3);
#else
#define BL0 cbi(PORTD,BL);
#define BL1 sbi(PORTD,BL);
#define CS0 cbi(PORTD,CS);
#define CS1 sbi(PORTD,CS);
#define CLK0 cbi(PORTD,CLK);
#define CLK1 sbi(PORTD,CLK);
#define SDA0 cbi(PORTD,SDA);
#define SDA1 sbi(PORTD,SDA);
#define RESET0 cbi(PORTD,RESET);
#define RESET1 sbi(PORTD,RESET);
#endif
byte const font[475] = {
0x00 , 0x00 , 0x00 , 0x00 , 0x00 ,
0x00 , 0x06 , 0x5F , 0x06 , 0x00 , // !
0x07 , 0x03 , 0x00 , 0x07 , 0x03 , // ,
0x24 , 0x7E , 0x24 , 0x7E , 0x24 , // #
0x24 , 0x2B , 0x6A , 0x12 , 0x00 , // $
0x63 , 0x13 , 0x08 , 0x64 , 0x63 , // %
0x36 , 0x49 , 0x56 , 0x20 , 0x50 , // &
0x00 , 0x07 , 0x03 , 0x00 , 0x00 , // //
0x00 , 0x3E , 0x41 , 0x00 , 0x00 , // (
0x00 , 0x41 , 0x3E , 0x00 , 0x00 , // )
0x08 , 0x3E , 0x1C , 0x3E , 0x08 , // *
0x08 , 0x08 , 0x3E , 0x08 , 0x08 , // +
0x00 , 0xE0 , 0x60 , 0x00 , 0x00 , // ,
0x08 , 0x08 , 0x08 , 0x08 , 0x08 , // -
0x00 , 0x60 , 0x60 , 0x00 , 0x00 , // .
0x20 , 0x10 , 0x08 , 0x04 , 0x02 , // /
0x3E , 0x51 , 0x49 , 0x45 , 0x3E , // 0
0x00 , 0x42 , 0x7F , 0x40 , 0x00 , // 1
0x62 , 0x51 , 0x49 , 0x49 , 0x46 , // 2
0x22 , 0x49 , 0x49 , 0x49 , 0x36 , // 3
0x18 , 0x14 , 0x12 , 0x7F , 0x10 , // 4
0x2F , 0x49 , 0x49 , 0x49 , 0x31 , // 5
0x3C , 0x4A , 0x49 , 0x49 , 0x30 , // 6
0x01 , 0x71 , 0x09 , 0x05 , 0x03 , // 7
0x36 , 0x49 , 0x49 , 0x49 , 0x36 , // 8
0x06 , 0x49 , 0x49 , 0x29 , 0x1E , // 9
0x00 , 0x6C , 0x6C , 0x00 , 0x00 , // :
0x00 , 0xEC , 0x6C , 0x00 , 0x00 , // ;
0x08 , 0x14 , 0x22 , 0x41 , 0x00 , // <
0x24 , 0x24 , 0x24 , 0x24 , 0x24 , // =
0x00 , 0x41 , 0x22 , 0x14 , 0x08 , // >
0x02 , 0x01 , 0x59 , 0x09 , 0x06 , // ?
0x3E , 0x41 , 0x5D , 0x55 , 0x1E , // @
0x7E , 0x09 , 0x09 , 0x09 , 0x7E , // A
0x7F , 0x49 , 0x49 , 0x49 , 0x36 , // B
0x3E , 0x41 , 0x41 , 0x41 , 0x22 , // C
0x7F , 0x41 , 0x41 , 0x41 , 0x3E , // D
0x7F , 0x49 , 0x49 , 0x49 , 0x41 , // E
0x7F , 0x09 , 0x09 , 0x09 , 0x01 , // F
0x3E , 0x41 , 0x49 , 0x49 , 0x7A , // G
0x7F , 0x08 , 0x08 , 0x08 , 0x7F , // H
0x00 , 0x41 , 0x7F , 0x41 , 0x00 , // I
0x30 , 0x40 , 0x40 , 0x40 , 0x3F , // J
0x7F , 0x08 , 0x14 , 0x22 , 0x41 , // K
0x7F , 0x40 , 0x40 , 0x40 , 0x40 , // L
0x7F , 0x02 , 0x04 , 0x02 , 0x7F , // M
0x7F , 0x02 , 0x04 , 0x08 , 0x7F , // N
0x3E , 0x41 , 0x41 , 0x41 , 0x3E , // O
0x7F , 0x09 , 0x09 , 0x09 , 0x06 , // P
0x3E , 0x41 , 0x51 , 0x21 , 0x5E , // Q
0x7F , 0x09 , 0x09 , 0x19 , 0x66 , // R
0x26 , 0x49 , 0x49 , 0x49 , 0x32 , // S
0x01 , 0x01 , 0x7F , 0x01 , 0x01 , // T
0x3F , 0x40 , 0x40 , 0x40 , 0x3F , // U
0x1F , 0x20 , 0x40 , 0x20 , 0x1F , // V
0x3F , 0x40 , 0x3C , 0x40 , 0x3F , // W
0x63 , 0x14 , 0x08 , 0x14 , 0x63 , // X
0x07 , 0x08 , 0x70 , 0x08 , 0x07 , // Y
0x71 , 0x49 , 0x45 , 0x43 , 0x00 , // Z
0x00 , 0x7F , 0x41 , 0x41 , 0x00 , // [
0x02 , 0x04 , 0x08 , 0x10 , 0x20 , // Back slash
0x00 , 0x41 , 0x41 , 0x7F , 0x00 , // ]
0x04 , 0x02 , 0x01 , 0x02 , 0x04 , // ^
0x80 , 0x80 , 0x80 , 0x80 , 0x80 , // _
//0x00 , 0x03 , 0x07 , 0x00 , 0x00 , // `
0x20 , 0x40 , 0x80 , 0x40 , 0x20 , // `
0x20 , 0x54 , 0x54 , 0x54 , 0x78 , // a
0x7F , 0x44 , 0x44 , 0x44 , 0x38 , // b
0x38 , 0x44 , 0x44 , 0x44 , 0x28 , // c
0x38 , 0x44 , 0x44 , 0x44 , 0x7F , // d
0x38 , 0x54 , 0x54 , 0x54 , 0x18 , // e
0x08 , 0x7E , 0x09 , 0x09 , 0x00 , // f
0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C , // g
0x7F , 0x04 , 0x04 , 0x78 , 0x00 , // h
0x00 , 0x00 , 0x7D , 0x00 , 0x00 , // i
0x40 , 0x80 , 0x84 , 0x7D , 0x00 , // j
0x7F , 0x10 , 0x28 , 0x44 , 0x00 , // k
0x00 , 0x00 , 0x7F , 0x40 , 0x00 , // l
0x7C , 0x04 , 0x18 , 0x04 , 0x78 , // m
0x7C , 0x04 , 0x04 , 0x78 , 0x00 , // n
0x38 , 0x44 , 0x44 , 0x44 , 0x38 , // o
0xFC , 0x44 , 0x44 , 0x44 , 0x38 , // p
0x38 , 0x44 , 0x44 , 0x44 , 0xFC , // q
0x44 , 0x78 , 0x44 , 0x04 , 0x08 , // r
0x08 , 0x54 , 0x54 , 0x54 , 0x20 , // s
0x04 , 0x3E , 0x44 , 0x24 , 0x00 , // t
0x3C , 0x40 , 0x20 , 0x7C , 0x00 , // u
0x1C , 0x20 , 0x40 , 0x20 , 0x1C , // v
0x3C , 0x60 , 0x30 , 0x60 , 0x3C , // w
0x6C , 0x10 , 0x10 , 0x6C , 0x00 , // x
0x9C , 0xA0 , 0x60 , 0x3C , 0x00 , // y
0x64 , 0x54 , 0x54 , 0x4C , 0x00 , // z
//0x08 , 0x3E , 0x41 , 0x41 , 0x00 , // {
0x33 , 0x66 , 0xCC , 0x66 , 0x33 , // {
0x00 , 0x00 , 0x7F , 0x00 , 0x00 , // |
//0x00 , 0x41 , 0x41 , 0x3E , 0x08 , // }
0xCC , 0x66 , 0x33 , 0x66 , 0xCC , // }
0x02 , 0x01 , 0x02 , 0x01 , 0x00 // ~
NokiaLCD::NokiaLCD()
pinMode(BL,OUTPUT);
pinMode(CS,OUTPUT);
pinMode(CLK,OUTPUT);
pinMode(SDA,OUTPUT);
pinMode(RESET,OUTPUT);
digitalWrite(BL,HIGH);
digitalWrite(CS,HIGH);
digitalWrite(CLK,HIGH);
digitalWrite(SDA,HIGH);
digitalWrite(RESET,HIGH);
#else
DDRD |= B01111100; // Set SPI pins as output
PORTD |= B01111000; // Set SPI pins HIGH
#endif
void NokiaLCD::ShiftBits(byte b)
byte Bit;
for (Bit = 0; Bit < 8; Bit++) // 8 Bit Write
CLK0 // Standby SCLK
if((b&0x80)>>7)
SDA1
SDA0
CLK1 // Strobe signal bit
b <<= 1; // Next bit data
void NokiaLCD::SendData(byte data) {
CLK0
SDA1
CLK1
ShiftBits(data);
void NokiaLCD::SendCMD(byte data) {
CLK0
SDA0
CLK1
ShiftBits(data);
void NokiaLCD::SetBox(byte x1, byte y1, byte x2, byte y2)
SendCMD(CASET); // page start/end ram
SendData(x1); // for some reason starts at 2
SendData(x2);
SendCMD(PASET); // column start/end ram
SendData(y1);
SendData(y2);
void NokiaLCD::Clear(byte color, byte x1, byte y1, byte x2, byte y2)
uint16_t xmin, xmax, ymin, ymax;
uint16_t i;
unsigned int icolor;
icolor = ~color;
// best way to create a filled rectangle is to define a drawing box
// and loop two pixels at a time
// calculate the min and max for x and y directions
xmin = (x1 <= x2) ? x1 : x2;
xmax = (x1 > x2) ? x1 : x2;
ymin = (y1 <= y2) ? y1 : y2;
ymax = (y1 > y2) ? y1 : y2;
// specify the controller drawing box according to those limits
// Row address set (command 0x2B)
SendCMD(CASET);
SendData(xmin);
SendData(xmax);
// Column address set (command 0x2A)
SendCMD(PASET);
SendData(ymin);
SendData(ymax);
// WRITE MEMORY
SendCMD(RAMWR);
// loop on total number of pixels / 2
for (i = 0; i < ((xmax - xmin + 1) * (ymax - ymin + 1)) ; i++)
// use the color value to output three data bytes covering two pixels
// For some reason, it has to send blue first then green and red
//SendData((color << 4) | ((color & 0xF0) >> 4));
//SendData(((color >> 4) & 0xF0) | (color & 0x0F));
//SendData((color & 0xF0) | (color >> 8));
SendData(icolor);
void NokiaLCD::Init()
// Initial state
CS1
CS0
// Hardware Reset LCD
RESET0
delay(100);
RESET1
delay(100);
//Software Reset
SendCMD(SWRESET);
//Sleep Out
SendCMD(SLEEPOUT);
//Booster ON
SendCMD(BSTRON);
//Display On
SendCMD(DISPON);
//Normal display mode
SendCMD(NORON);
//Display inversion on
SendCMD(INVON);
//Data order
//SendCMD(0xBA);
SendCMD(SETCON);
SendData(0x38);
//Memory data access control
SendCMD(MADCTL);
//SendData(8|64); //rgb + MirrorX
//SendData(8|128); //rgb + MirrorY
SendData(0xc0);
SendCMD(COLMOD);
SendData(2); //16-Bit per Pixel
Clear(0xff,0,0,131,131);
void NokiaLCD::Sleep()
SendCMD(DISPOFF);
SendCMD(SLEEPIN);
BacklightOff();
void NokiaLCD::Wake()
BacklightOn();
SendCMD(SLEEPOUT);
SendCMD(DISPON);
void NokiaLCD::BacklightOn()
BL1
void NokiaLCD::BacklightOff()
BL0
void NokiaLCD::DrawTextLine(byte fcolor, byte bcolor,byte x, byte y,char c)
unsigned int i;
unsigned int ifcolor, ibcolor;
ifcolor = ~fcolor;
ibcolor = ~bcolor;
SetBox(x,y,x,y+7);
SendCMD(RAMWR);
for(i=0;i<8;i++)
if (1<<i & c)
SendData(ifcolor);
SendData(ibcolor);
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,char *text)
byte c;
byte t;
unsigned int i;
unsigned int j;
while(*text != 0)
t = *text;
i = t - 32;
i = i * 5;
for(j = i; j < i+5; j++)
c = font[j];
DrawTextLine(fcolor, bcolor, x++, y, c);
DrawTextLine(fcolor, bcolor, x++, y, 0);
text++;
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,int text)
char temp[6];
itoa(text,temp,10);
DrawText(fcolor, bcolor, x, y,temp);
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,byte text)
char temp[6];
itoa(text,temp,10);
void NokiaLCD::DrawText(byte fcolor, byte bcolor, byte x, byte y,long text)
char temp[20];
ltoa(text,temp,10);
void NokiaLCD::PutPixel(byte color, byte x, byte y)
icolor = ~color;
SendData(x); // for some reason starts at 2
SendData(x+1);
SendData(y);
SendData(y+1);
SendCMD(RAMWR);
SendData(icolor);
void NokiaLCD::SetContrast(byte Contrast)
SendCMD(SETCON);
SendData(Contrast);
void NokiaLCD::DrawDate(byte x, byte y)
//byte iTimeHourOffset=0;
char text[21];
char temp[]=" ";
strcpy(text,"");
itoa(month(),temp,10);
if (temp[1]==0) strcat(text,"0");
strcat(text,temp);
strcat(text,"/");
itoa(day(),temp,10);
strcat(text,temp);
strcat(text,"/");
itoa(year()-2000,temp,10);
strcat(text,temp);
strcat(text," ");
//if (iTimeHour>12) iTimeHourOffset=12;
itoa(hourFormat12(),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(minute(),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(second(),temp,10);
strcat(text,temp);
if (isAM())
strcat(text," AM");
strcat(text," PM");
DrawText(RED,WHITE,x,y,text);
void NokiaLCD::DrawOutletBox(byte x, byte y,byte RelayData)
Clear(94,x,y,x+104,y);
Clear(94,x,y+12,x+104,y+12);
for (int a=0;a<8;a++)
byte bcolor=WHITE;
byte fcolor=BLACK;
char temp[]=" ";
if ((RelayData&(1<<a))==1<<a)
bcolor=13;
fcolor=WHITE;
Clear(bcolor,x+1+(a*13),y+1,x+14+(a*13),y+11);
itoa(a+1,temp,10);
DrawText(fcolor,bcolor,x+5+(a*13),y+3,temp);
void NokiaLCD::DrawSingleMonitor(int Temp, byte fcolor, byte x, byte y, byte decimal)
char text[7];
char temptxt[3];
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,text,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(text , ".");
if (Temp%decimal<10 && decimal==100) strcat(text , "0");
strcat(text , temptxt);
Clear(WHITE,x,y,x+30,y+8);
DrawText(fcolor,WHITE,x,y,text);
void NokiaLCD::DrawMonitor(byte x, byte y, ParamsStruct Params, byte DaylightPWMValue, byte ActnicPWMValue)
DrawText(WaterTempColor,WHITE,x,y,"T1:");
DrawSingleMonitor(Params.Temp1, WaterTempColor, x+18, y,10);
DrawText(LightsTempColor,WHITE,x,y+10,"T2:");
DrawSingleMonitor(Params.Temp2, LightsTempColor, x+18, y+10,10);
DrawText(AmbientTempColor,WHITE,x,y+20,"T3:");
DrawSingleMonitor(Params.Temp3, AmbientTempColor, x+18, y+20,10);
DrawText(PHColor,WHITE,x+60,y,"PH:");
DrawSingleMonitor(Params.PH, PHColor, x+78, y,100);
void NokiaLCD::DrawSingleGraph(byte color, byte x, byte y, int I2CAddr, int EEaddr)
int start;
for (int a=0;a<120;a++)
start=EEaddr+a;
if (start > (int(EEaddr/120)+1)*120) start=start-120;
Wire.beginTransmission(I2CAddr);
Wire.send((int)(start >> 8)); // MSB
Wire.send((int)(start & 0xFF)); // LSB
Wire.endTransmission();
Wire.requestFrom(I2CAddr,1);
if (Wire.available()) PutPixel(color,x+a,y+50-Wire.receive());
void NokiaLCD::DrawEEPromImage(int swidth, int sheight, byte x, byte y, int I2CAddr, int EEaddr)
int count = 0;
SetBox(x,y,swidth-1+x,sheight-1+y);
SendCMD(0x2c);
//for (int j = 0; j < sheight; j++)
// for (int i = 0; i < swidth; i++)
//e.lcd_put_pixel(readEEPROM(I2CEEPROM,count+start),i+x,j+y);
// count++;
// WatchDogReset();
do
Wire.send((int)(EEaddr+count >> 8)); // MSB
Wire.send((int)(EEaddr+count & 0xFF)); // LSB
Wire.requestFrom(I2CAddr,30);
for (int j = 0; j < 30; j++)
count+=1;
if ((count<swidth*sheight) && Wire.available()) SendData(~Wire.receive());
while (count < swidth*sheight);
void NokiaLCD::DrawGraph(byte x, byte y, int I2CAddr, int pointer)
Clear(WHITE,0,y,131,y+50);
Clear(BLACK,x,y,x,y+50);
for (int i=6; i<=131; i+=3){
PutPixel(0x49, i, y+25);
DrawSingleGraph(WaterTempColor,x,y,I2CAddr,EEPROM.read(pointer));
DrawSingleGraph(LightsTempColor,x,y,I2CAddr,EEPROM.read(pointer)+120);
DrawSingleGraph(AmbientTempColor,x,y,I2CAddr,EEPROM.read(pointer)+240);
DrawSingleGraph(PHColor,x,y,I2CAddr,EEPROM.read(pointer)+360);
Re: PWM inversion
Are you using my development libraries? This is the Standard Libraries code. This is the NokiaLCD.cpp file and not the ReefAngel_NokiaLCD.cpp. If you are running the dev libraries and modify this code, then it won't work because this code isn't even used.
Re: PWM inversion
oh yup im using the dev lib...now what?
Re: PWM inversion
If you converted to dev lib, just go back in the thread and apply the changes to the file ReefAngel_Nokia.cpp
Re: PWM inversion
thanks roberto, ill try that. hey quick question, when i reload the pde the lights go full on, which at night can be a bit startling to the fish...anyway of stopping this?
Re: PWM inversion
That's because the pucks are inverted. 0V means full on. When the controller is being programmed, it outputs 0V.
The only way to avoid this is by hooking up the pucks where 0V means no light output.
Re: PWM inversion
oh ok, that wont happen, its working great and im gonna leave well enough alone. so since i was not observant and was trying to put the 100- changes into the wrong nokia library, no go. i just dropped the changes into the correct library and its working awesome, thanks roberto and curt.
