vortech/radion control
PostPosted: Wed Jun 06, 2012 5:16 am
Thanks heaps! :)
I just received my Expansion and R+ with lots of memory! :P
I have really hard time to setup my vortech :?
Finished to swap over the new board and wondering how I can get control of my Radion and the
only code I have is:
ReefAngel.RF.RadionChannels[Radion_Intensity]=75;
  ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(12,0,18,0,0,100,0);
  ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(9,0,22,0,0,100,0);
  ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,22,0,0,5,0);
  ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,22,0,0,10,0);
  ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(10,0,21,0,0,60,0);
  if (second()==0) ReefAngel.RF.RadionWrite();
here is my silly questions:
Where to put it?
internal memory or RA code?
once it's upload, how i can setup storms from any app or java?
thank you so much for your time and help
Slow down to speed up
PostPosted: Wed Jun 06, 2012 7:55 am
Let's start with the vortech.
Did you sync them to the controller?
PostPosted: Sat Jun 09, 2012 1:38 am
rimai wrote:Let's start with the vortech.
Hi Roberto:
Yes it does work and I can change the mode by wireless but the radion doesn't sync when I change the mode in the vortech memory :cry:
PostPosted: Sat Jun 09, 2012 7:32 am
Your radions need to be restored to factory settings.
When you do that, they will pick up the signal from the controller and start adjusting accordingly.
PostPosted: Sat Jun 09, 2012 3:53 pm
give me o for awesome!
thanks for your fast reply, i will try tonight.
i am wonder if the storm mode is the same in vortech than Radion?
:o
PostPosted: Sun Jun 10, 2012 1:47 am
I have changed to factory settings and does not sync when i change modes in my vortech :(
should I add a new chanel in the memory?
PostPosted: Sun Jun 10, 2012 2:14 am
here is:
// Autogenerated file by RAGen (v1.2.2.171), (05/02/2012 22:36)
// RA_050212_2236.ino
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
// Globals Needed for Params on Custom Main
byte x,y;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
boolean bFeeding=false;
byte PWMChannel[]={
0,0,0,0,0,0};
int v;
            //Top Banner
        ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Erick&SooZ ReeF ");
               // Display T1 Header Text
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
        // Display the T1 Temp Value
        char text[7];
        ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
        // Display the T2 Header Text
        ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Room");
        // Display the T2 Temp Value
        ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
        ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
        // Display pH Header Text
        ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
        // Display pH Value
        ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
        // Display Vortech MP40wES Mode Header Text
        ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
        ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
        // Display EcoSmart Mode Value
        ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
        if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
        else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
        else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
        else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
        else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
        else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
        else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
        else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
         ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.SingleATOLow(Port1);
    ReefAngel.StandardLights(Port4);
    ReefAngel.StandardFan(Port6);
    ReefAngel.Portal("pilonstar", "whatupbrah");
//------------------------------ Start Feeding Mode Schedule (Start 1st Feeding at 9:55 AM and 2nd at 1:55 PM)---------------------
    // if the hour is 9a or 1p, minute is 55 and seconds is 0
    // start the feeding mode
    if ( ((hour() == 9) || (hour() == 13)) &&
       (minute() == 55) &&
       (second() == 0) )
      ReefAngel.FeedingModeStart();
      vtechmode = InternalMemory.RFMode_read();
//------------------------------------------------------ End of Feeding Mode Schedule ---------------------------------------------
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
  if (hour() >=8 && hour() <= 22)
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
      bFeeding=false;
      ReefAngel.RF.UseMemory=false;
      ReefAngel.RF.SetMode(Smart_NTM,155,5);
      ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
      ReefAngel.Timer[4].Start();
      vtechmode = 5;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
      ReefAngel.RF.UseMemory=true;
//---------------------------------------------------------- End RF Daytime Control -----------------------------------------------
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
  if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
      vtechmode = 9;
      ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
PostPosted: Sun Jun 10, 2012 6:45 am
:? Confused.
What are you talking about?
The vortechs don't sync or the radions don't sync?
Did you sync the vortechs? Are they working as intended?
PostPosted: Mon Jun 11, 2012 2:18 am
rimai wrote::? Confused.
Sorry I didn't mean to confused you. :oops:
What happened with my code, I can control the Vortech modes but the
Radion modes doesn't change, it looks like it send a signal to the radion but i doesn't change any
of the modes and i think is my PDE :(
So what I am trying to setup is a code i can change the radion modes like storm mode lighting mode or
day cycle.
Can you help with the modes please?
thanks for your time.
Erick
PostPosted: Mon Jun 11, 2012 7:44 am
Is it dimming?
Return to Requests
