Internal memory through wifi
Posted: Sat Jun 18, 2011 10:34 am
Hello,
Does anyone with good knowledge of HTML/AJAX programming want to be apart of the development of the internal memory settings change through wifi?
Curt has expressed that the "Updated XML data sending for Client Suite usage of reading/writing memory values" is in progress and I'm pretty sure that Dave is also apart of this one on his Client software.
But, I would also love to be able to have this capability with direct connection to the controller through wifi.
My idea is to have the internal webserver return a javascript file, which will then construct the webpage and everything necessary for the change of settings.
Everything has to be self contained in the JS file for it to work.
Then when the user changes any settings, an http request is made to the controller through wifi and the controller would change the internal memory and return with a sucess or failed response.
Let me know if you are this guy :ugeek:
Re: Internal memory through wifi
Posted: Thu Jan 05, 2012 9:40 am
by dedvalson
Do we have enough memory to hold the java script file somewhere? It seems to me that most systems are running on the very edge of having enough memory to run basic functionality. Mine is with 400 bytes of being maxed out and a javascript file to do what you describe would be several K.
Posted: Thu Jan 05, 2012 9:51 am
yes. the wifi js file is hosted remotely. :)
The entire html page returned by the controller when you browse the controller is:
<script language='javascript' src='http://www.reefangel.com/wifi/ra1.js'></script>
That's it.
The whole web experience is contained within the ra1.js file and that's why AJAX is really nice in this case.
Posted: Thu Jan 05, 2012 10:52 am
by dedvalson
duhh
Posted: Wed Jan 11, 2012 8:20 am
by Xender
Can we have the possibility to host the js too?
Posted: Wed Jan 11, 2012 8:55 am
Yes, but that would mean you would have to send all your webbanner stuff to your own server too.
Posted: Fri Jan 13, 2012 6:18 am
by Xender
ok
and can we host in the RA? Or whith an addon USB HD or other?
Posted: Fri Jan 13, 2012 9:13 am
It would be too big for RA
