Wavemaker Help
PostPosted: Wed Oct 31, 2012 8:12 pm
Try this:
// Autogenerated file by RAGen (v1.2.2.171), (06/11/2012 09:50)
// RA_061112_0950.ino
#define wifi
 #define WDT
 #define CUSTOM_MENU
 #define CUSTOM_MENU_ENTRIES 5
 #define ENABLE_ATO_LOGGING
 #define IOEXPANSION
unsigned long clearsiphon=now();
boolean NTM=false;
#include <avr/pgmspace.h>
prog_char menu3_label[] PROGMEM = "Lights On";
prog_char menu4_label[] PROGMEM = "Lights Off";
prog_char menu5_label[] PROGMEM = "Clear Siphon";
prog_char menu6_label[] PROGMEM = "Nutri Transp";
  menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label  };
void MenuEntry1()
  ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
  ReefAngel.ATOClear();
void MenuEntry4()
  ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
    ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif  // RelayExp
  ReefAngel.Relay.Write();
  ReefAngel.DisplayMenuEntry("Lights On");
void MenuEntry5()
  ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
    ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif  // RelayExp
  ReefAngel.DisplayMenuEntry("Lights Off");
void MenuEntry6()
  clearsiphon=now();
void MenuEntry7()
   NTM=true; // Enable NTM mode
   ReefAngel.Timer[1].Start(); // Start timer for NTM mode
  // Initialize the custom menu
  ReefAngel.FeedingModePorts = Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port5Bit | Port6Bit | Port7Bit | Port8Bit;
  //Light On/Off Ports
  ReefAngel.LightsOnPorts = Port2Bit | Port4Bit;
  ReefAngel.Relay.On(Port8);  //Return Pump
  //Adds Wifi function
  ReefAngel.AddWifi();
  ReefAngel.Timer[1].SetInterval(900); // Timer for Nutrient Transport mode
  ReefAngel.SingleATO(true,Port1,120,1);  //ATO time out 2 minutes once every hour
  ReefAngel.StandardLights(Port2,19,0,7,0);  //Refugium Light on at 7PM off at 6AM
  ReefAngel.StandardLights(Port3,7,0,19,0);  //Blue LED on at 7AM off at 7PM
  ReefAngel.StandardLights(Port4,8,0,18,0);  // Daylight on at 8AM off at 6PM
//  ReefAngel.StandardLights(Port5,6,0,22,0);  //Turn off powerheads from 10PM to 6AM
//  ReefAngel.StandardLights(Port6,6,0,22,0);  //Turn off powerheads from 10PM to 6AM
  ReefAngel.Relay.DelayedOn(Port7, 5);  //Skimmer
  if (now()%clearsiphon<120)
    ReefAngel.Relay.On(Port3);
   BackSiphon(Port8,Port3);
ReefAngel.WavemakerRandom(Port5,60,90); // Port 5 on random wavemaker
 ReefAngel.Relay.Set(Port6,!ReefAngel.Relay.Status(Port5)); // Port 6 is opposite of Port5
  if (ReefAngel.Timer[1].IsTriggered()) // if timer for NTM mode is expired
    NTM=false; // disable NTM mode
  if (NTM) // if we are on NTM mode, turn ports on
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port6);
void BackSiphon(byte MonitorPort, byte BackSiphonPort)
  static byte laststatus=0;
  static unsigned long lastnow=now();
  byte currentstatus=ReefAngel.Relay.Status(MonitorPort);
  if (laststatus!=currentstatus)
    laststatus=currentstatus;
    if (currentstatus) lastnow=now();
  ReefAngel.Relay.Set(BackSiphonPort,now()%lastnow<300);
PostPosted: Wed Oct 31, 2012 8:52 pm
Almost working just right, I appreciate all the help.
When Nutri Trans is stopped, random wave function does not resume. All PH remain on. Also, I don't know if it's possible to still shut off all PH after 10 PM?
Also, the clear siphon function is no longer needed as I have put ports 3&4 on to lights. I think the clear siphon is interfering with the light function.
Actually I have run out of space on my bar and until I can save enough for an expansion, I gotta run the siphon manually..
Thanks again!!
PostPosted: Wed Oct 31, 2012 8:55 pm
Wait, I just found time value for the nutri transport mode. I wil continue testing tomorrow. The lights still don't work right though, port 3 where the aqualifter was for the siphon on the overflow.
PostPosted: Wed Oct 31, 2012 9:40 pm
Yeah, the mode will last 15minutes (900seconds).
You can change it as you wish.
Try this one. I removed the siphon:
 #define wifi
 #define WDT
 #define CUSTOM_MENU
 #define IOEXPANSION
boolean NTM=false;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif  // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif  // RelayExp
void MenuEntry6()
  clearsiphon=now();
void MenuEntry7()
PostPosted: Fri Nov 02, 2012 6:44 am
Ok, so this line
Is the line that says how long the PHs are on yes? Is it between 60 to 90 seconds? Just making sure so I can play with the timing. Thanks.
Awesome work.
PostPosted: Fri Nov 02, 2012 7:46 am
yes :) between 60 and 90s
PostPosted: Fri Nov 02, 2012 7:39 pm
Is it not possible to get the PHs to shut off at 10PM? I wasn't able to test until tonight and they don't shut off.
Otherwise everything looks awesome.
PostPosted: Fri Nov 02, 2012 8:12 pm
Yes, we can shut them off.
What time period do you want them off?
PostPosted: Sat Nov 03, 2012 4:17 am
10pm to 6 am
PostPosted: Sat Nov 03, 2012 8:46 am
Try this:
 #define wifi
 #define WDT
 #define CUSTOM_MENU
 #define IOEXPANSION
boolean NTM=false;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
#ifdef RelayExp
#endif  // RelayExp
void MenuEntry5()
#ifdef RelayExp
#endif  // RelayExp
void MenuEntry6()
  clearsiphon=now();
void MenuEntry7()
  if (hour()>=22 || hour()<6)
    ReefAngel.Relay.Off(Port5);
    ReefAngel.Relay.Off(Port6);
Return to Requests
