Parameter out of range warning flasher
Posted: Wed Sep 12, 2012 12:56 pm
by jsclownfish
I'm adding a little function on my display to flash the numbers red when they are above or below where I expect them to be so they are easy to see. I thought it might be useful if others want to use it as well and maybe we could add it to future libraries. There might be easier ways to do this as well. Here is my attempt....
//function to flash warning (parameter, high limt, low limit, x, y, decimal)
void Warningflash(int param, int high, int low, byte x, byte y, byte z)
int mod=second()%2;
if (param > high || param < low)
if (mod==0) ReefAngel.LCD.Clear(DefaultBGColor,x,y,x+40,y+10);
else ReefAngel.LCD.DrawSingleMonitor(param, COLOR_RED, x, y, z);
else ReefAngel.LCD.DrawSingleMonitor(param, DefaultFGColor, x, y, z);
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
// Display the PH with color sensors
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 13,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 23, 13, 100);
Warningflash(ReefAngel.Params.PH, 840, 790, 23, 13, 100);
I'll try this tonight to see how it goes.
-Jon
Re: Parameter out of range warning flasher
Posted: Wed Sep 12, 2012 1:26 pm
Awesome idea! Should definitely be in the libraries as a standard function..
DrawSingleMonitor
Flash()
DrawSingleMonitor
Alarm()
or even just override the existing DrawSingleMonitor();
void DrawSingleMonitor(param, color, x, y, z, high, low, warning_color?); ?
I think I like the override personally, not sure if that will be more confusing to some...
Posted: Wed Sep 12, 2012 1:31 pm
Wanna try to create a pull request
Posted: Wed Sep 12, 2012 2:32 pm
rimai wrote:Wanna try to create a pull request
Sure. which method did you prefer though?
I do need to get back to the git stuff so I can clone off your dev branch and start the commenting process again...
I'm in montreal for the week for business so next week I can setup the function. Any feedback on the function declaration I put? I can rearrange the params, etc on feedback...
Lee
Posted: Wed Sep 12, 2012 2:39 pm
yes, fork the latest dev branch and work on it. When you are done, send a pull request.
I personally like DrawSingleMonitorAlarm()
Posted: Wed Sep 12, 2012 2:52 pm
Cool, I'm not partial, and long term that will be less confusing for people who may not understand overridden functions...
Posted: Wed Sep 26, 2012 11:12 am
Ok, I've cloned the repo again... merged with dev and added the DOxygen title page and the function DrawSingleMonitorAlarm function... here's the declaration
void DrawSingleMonitorAlarm(int Temp, byte fcolor, byte x, byte y, byte decimal, byte high, byte low, byte wcolor);
So the params are the same as DrawSingleMonitor with the addition of high, low and warning color to the args.
Hopefully my pull request is good, but it seems two seperate commits happened, and the second was after the pull request, so I'm not 100% sure what I'm doing git wise...
Lee
Posted: Fri May 03, 2013 2:03 pm
Ok, I think I finally made a clean pull request for this function
Posted: Fri May 03, 2013 2:09 pm
Yeap
It will be in the next lib release.
Posted: Fri May 03, 2013 2:25 pm
by enigma32
haha- I was reading this thinking, "oh, I should +1 this"... then I looked at the dates
This is great. I have a question re: the method prototype though.
Isn't it a problem that "Temp" is an int and "high" and "low" are bytes?
Posted: Fri May 03, 2013 2:31 pm
Yes.
Posted: Fri May 03, 2013 2:35 pm
Pushed the fix
Posted: Fri May 03, 2013 2:38 pm
by enigma32
haha excellent
