Request for RA wizard functionality.
Posted: Tue Oct 09, 2012 9:57 pm
I have used the Wizard to generate code and seen others do the same. Many including myself also have custom code pasted into the areas in the generated code after generation (between the put your code here tags) to add customizations. Would it be possible to set up the Wizard to save all the user's custom code pasted into these areas and have it included in those same areas in newly generated code? a "Custom Code" screen during the wizard that reads a file that saves\contains allows you to read in\type in your custom code for inclusion when building your code for upload.
Nick
Nick
