display of temp settings
Posted: Thu Feb 21, 2013 1:58 am
by aus996
Just adding to the wishlist, but i often find myself wondering what I set my high and low temp and overheat to. yes yes, i have them written down ( somewhere) but just thought it would be cool if you could see the settings in small italics when you look at the dashboard through the portal. Just a thought
Re: display of temp settings
Posted: Thu Feb 21, 2013 5:25 am
by Sebyte
Why not just look at the internal memory settings page of the portal? Unless you have hard coded them, which is not the best option.
Posted: Thu Feb 21, 2013 7:29 am
Internal memory is the way to go! Hard coded is good and simple when your starting out...
Your other option is to display them on the screen...
