Reverse flag for RA_ATOClass
Posted: Thu Mar 28, 2013 8:05 pm
Can we add a boolean to the RA_ATOClass that when set to true will return the opposite result with IsActive()?
This would have a few benefits for those troubleshooting who may have hooked up the switch upside down or for those that need the switch in that orientation.
For me this would help because I have two switches on one bracket and right now they are set perfectly. But for it to act properly in the SingleATO function I've current hacked the function to negate isActive.
Also, if I had to flip my low switch it may not reach where I need it to which would reduce my alert threshold which I don't want to do.
Re: Reverse flag for RA_ATOClass
Posted: Thu Mar 28, 2013 8:11 pm
Try this....
Remove C-clip from the float and flip the floating part.
Place the C-clip back.
Does that work for you?
Posted: Thu Mar 28, 2013 8:37 pm
That'll work... I didn't know our switches could do that. That'll be the route I go, I guess..
Would still be good for troubleshooting :)
Posted: Fri Mar 29, 2013 5:07 pm
How about an #define instead of changing code...
class RA_ATOHighClass : public RA_ATOClass
public:
#ifdef REVERSE_HIGH_ATO
    inline bool IsActive() { return digitalRead(highATOPin); }
#else
    inline bool IsActive() { return !digitalRead(highATOPin); }
#endif
Why force a hardware change when we can do it in software :)
Posted: Fri Mar 29, 2013 7:02 pm
Send me a pull request :)
Don't forget to also add a function in ReefAngel.cpp for the auto feature selection to enable the define.
Posted: Fri Mar 29, 2013 8:30 pm
What would a user do to enable the auto detection...
I'm thinking the user would just #define REVERSE_ATO_HIGH / LOW if they wanted it...it's not like there would be a new function to detect and add the feature. Kind of like the large fonts... If you want it you add the #define..
Also as far as the push request...I've already forgotten all the git commands...you can either refresh me in the commands, or the code is right above :) I'd be happy to write it out for ato low...
Posted: Fri Mar 29, 2013 8:32 pm
class RA_ATOLowClass : public RA_ATOClass
public:
#ifdef REVERSE_ATO_LOW
inline bool IsActive() { return digitalRead(lowATOPin); }
#else
inline bool IsActive() { return !digitalRead(lowATOPin); }
#endif
Posted: Fri Mar 29, 2013 8:46 pm
There is no way to define it other than using the auto feature selection I created for the Arduino IDE.
This define needs to be inside ReefAngel_Features.h file to be seen and compiled.
That's why we have dummy functions that trigger the auto feature selection to add stuff to ReefAngel_Features.h file.
For example:
ReefAngel.AddDateTimeMenu();
This function when added to the INO code, triggers the #define DateTimeSetup
All features are added this way into the compiled code.
A list of keywords and features is inside the file /update/feature.txt
Posted: Fri Mar 29, 2013 8:58 pm
Not sure I follow why a #define in my ino wouldn't trigger...but at least I understand the concept of what you mean. I'll look at it tomorrow and provide the rest of the code ;) just not sure if I'll have time to learn git again :( I'll see what I can do.
Posted: Sat Mar 30, 2013 5:31 am
Just thinking this morning and realized i may still have to flip the float magnets around, but then remembered why I was doing it initially..
I'm planning on moving both floats to one port. Since essentially they do the same thing (shut off my return) most of the time...
I have two choices to do that. I can either wire the switches in paralelle and leave them in their current orientation which would require this code change. Or i could run them in series which would require me to flip the float and no code change.
Its either one switch breaks the circuit in series, or one switch makes the circuit in parallel. I think in the end i'll go with it in series and change the floats to match, but still debating in my head if there is a right way to go.
I still think the code change is relevant and could be useful for someone and who knows I may still want to use it someday.
I need to see how the skimmate switch defaults (supposedly on until full).
Posted: Sat Mar 30, 2013 5:42 am
Ok, yeah I see that the #define does not get into the scope from the INO, I guess it needs to be explicitly declared in that file through the include of ReefAngel_Features.h through Globals.h. Anyway, I'll see what I can do later about the push request and adding the functions and keywords. That part seems pretty straightforward..
Posted: Sat Mar 30, 2013 7:24 am
I can't get it to recognize the keywords :(
Added to feature.txt
REVERSE_ATO_LOW,ReefAngel.ReverseATOLow
REVERSE_ATO_HIGH,ReefAngel.ReverseATOHigh
Added to keywords.txt
ReverseATOLow KEYWORD2
ReverseATOHigh KEYWORD2
Added to ReefAngel.h
        void inline ReverseATOLow() {};
        void inline ReverseATOHigh() {};
Added to debug sketch
    ReefAngel.ReverseATOHigh();
But it's not picking up and adding to the ReefAngel_Features.h. Anything I'm missing?
Posted: Sat Mar 30, 2013 9:33 am
by jsclownfish
Following along...I was wanting to do something similar http://forum.reefangel.com/viewtopic.php?f=20&t=1542. I have mine set up in a StandardATO format and it just seems more logical to me for the status to appear green if the water level is above the low float (closed position). It's become less important now with the water level expansion, but it would still be nice.
Jon
Posted: Sat Mar 30, 2013 9:40 am
You are missing a description on the feature.txt file
REVERSE_ATO_LOW,ReefAngel.ReverseATOLow,Inverted Low Float Switch
REVERSE_ATO_HIGH,ReefAngel.ReverseATOHigh,Inverted High Float Switch
That's what it will display on the Arduino IDE when you compile the code as features found.
See if it works now.
Posted: Sat Mar 30, 2013 9:41 am
Got it. I'll try when i get home!
Posted: Sat Mar 30, 2013 7:40 pm
The pull request is in...i need to fix it though! I left a bit of decode in that isActive wont be declared unless its defined...
Also the feature.txt is not in the repo...
Posted: Sat Mar 30, 2013 8:14 pm
Ok, pull request should be good now. There should be 3 commits.
Posted: Mon Jul 01, 2013 8:37 am
by Sacohen
I'm going to have 2 float switches in parallel basically set up to disable the ATO when the water level is to high ineither area.
Due to space issues I need to set up my ATO float switches in reverse.
Where the float is down and the wires are at the top.
Like this...
If I do this I can use the following code to reverse the ATO Flag?
public:
#else
#endif
Posted: Mon Jul 01, 2013 8:47 am
by cosmith71
You can also pull the plastic clip off the bottom and flip the float upside down to change it.
Sent from my HTC One X using Tapatalk 4 Beta
Posted: Mon Jul 01, 2013 9:03 am
by Sacohen
I saw that from Roberto after I posted the question and I did that. It seems a lot easier to me.
Thanks.
Posted: Mon Jul 01, 2013 11:02 am
You could have gone either way. For some doing it in code is easier. I gave you the option :D
Posted: Mon Jul 01, 2013 12:54 pm
by Sacohen
Thanks. For me flipping the flota is easier now. I hope it will get to the point where coding is easier.
