Reverse flag for RA_ATOClass
PostPosted: Sat Mar 30, 2013 5:42 am
Ok, yeah I see that the #define does not get into the scope from the INO, I guess it needs to be explicitly declared in that file through the include of ReefAngel_Features.h through Globals.h. Anyway, I'll see what I can do later about the push request and adding the functions and keywords. That part seems pretty straightforward..
PostPosted: Sat Mar 30, 2013 7:24 am
I can't get it to recognize the keywords :(
Added to feature.txt
REVERSE_ATO_LOW,ReefAngel.ReverseATOLow
REVERSE_ATO_HIGH,ReefAngel.ReverseATOHigh
Added to keywords.txt
ReverseATOLow KEYWORD2
ReverseATOHigh KEYWORD2
Added to ReefAngel.h
        void inline ReverseATOLow() {};
        void inline ReverseATOHigh() {};
Added to debug sketch
    ReefAngel.ReverseATOHigh();
But it's not picking up and adding to the ReefAngel_Features.h. Anything I'm missing?
PostPosted: Sat Mar 30, 2013 9:33 am
Following along...I was wanting to do something similar http://forum.reefangel.com/viewtopic.php?f=20&t=1542. I have mine set up in a StandardATO format and it just seems more logical to me for the status to appear green if the water level is above the low float (closed position). It's become less important now with the water level expansion, but it would still be nice.
Jon
PostPosted: Sat Mar 30, 2013 9:40 am
You are missing a description on the feature.txt file
REVERSE_ATO_LOW,ReefAngel.ReverseATOLow,Inverted Low Float Switch
REVERSE_ATO_HIGH,ReefAngel.ReverseATOHigh,Inverted High Float Switch
That's what it will display on the Arduino IDE when you compile the code as features found.
See if it works now.
PostPosted: Sat Mar 30, 2013 9:41 am
Got it. I'll try when i get home!
PostPosted: Sat Mar 30, 2013 7:40 pm
The pull request is in...i need to fix it though! I left a bit of decode in that isActive wont be declared unless its defined...
Also the feature.txt is not in the repo...
PostPosted: Sat Mar 30, 2013 8:14 pm
Ok, pull request should be good now. There should be 3 commits.
PostPosted: Mon Jul 01, 2013 8:37 am
I'm going to have 2 float switches in parallel basically set up to disable the ATO when the water level is to high ineither area.
Due to space issues I need to set up my ATO float switches in reverse.
Where the float is down and the wires are at the top.
Like this...
If I do this I can use the following code to reverse the ATO Flag?
class RA_ATOHighClass : public RA_ATOClass
public:
#ifdef REVERSE_HIGH_ATO
    inline bool IsActive() { return digitalRead(highATOPin); }
#else
    inline bool IsActive() { return !digitalRead(highATOPin); }
#endif
PostPosted: Mon Jul 01, 2013 8:47 am
You can also pull the plastic clip off the bottom and flip the float upside down to change it.
Sent from my HTC One X using Tapatalk 4 Beta
PostPosted: Mon Jul 01, 2013 9:03 am
I saw that from Roberto after I posted the question and I did that. It seems a lot easier to me.
Thanks.
Return to Requests
