I have once again tried to do the code from the beginning but to no avail. When going to menu and press on water change mode I am hearing the click from the relay box but the power is still on both on skimmer and return pump. Do this have something to do with the relays?
I have also used the storm/cloud command. I am having an error on the display C0...0 L17:56. This is changing to C0...0 L18:15
//The following features are enabled for this File:
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define NUMBERS_8x16
#define SIMPLE_MENU
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
byte x = 6;
byte y = 2;
byte t;
char text[7];
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.DrawText(0,255,3,17,"Neville's 500Ltr Reef");
// ReefAngel.LCD.DrawText(0,255,20,57,MoonPhaseLabel());
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
//ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
ReefAngel.LCD.DrawText(0,255,10,30,"Main Tank");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 40, text, Num8x16);
ReefAngel.LCD.DrawText(0,255,8,68,"Refugium");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 40, 68, 10);
// ReefAngel.LCD.DrawText(0,255,70,68,"Temp3");
// ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 99, 68, 10);
ReefAngel.LCD.DrawText(0,255,100,30,"pH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
ReefAngel.LCD.DrawText(0,255,8,100, "WHITE");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
ReefAngel.LCD.DrawText(0,255,88,100, "R.BLUE");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,90,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.FeedingModePorts = Port6Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port5Bit | Port6Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port5Bit;
InternalMemory.OverheatTemp_write( 265 );
ReefAngel.Relay.On( Port1 );//Return Pump
ReefAngel.Relay.On( Port3 );//AI Leds
ReefAngel.Relay.On( Port6 );//Skimmer
ReefAngel.Relay.On( Port7 );//Hydor Wavemaker
ReefAngel.Relay.On( Port8 );//Overflow Pump
// Calculate your regular sunrise/sunset PWM value
ActinicPWMValue=PWMSlope(12,00,21,0,1,85,0,ActinicPWMValue);
DaylightPWMValue=PWMSlope(12,00,21,0,0,85,0,DaylightPWMValue);
CheckCloud();
ReefAngel.StandardLights( Port5,20,0,1,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(12,0,21,0,0,85,0) );
ReefAngel.PWM.SetActinic( PWMParabola(12,0,21,0,1,85,0) );
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 10
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 5
// In this example, start could after 01:00pm
#define Start_Cloud_After NumMins(13,00)
// In this example, end could before 7:00pm
#define End_Cloud_Before NumMins(19,00)
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (cloudchance)
//is it time for cloud yet?
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=100;
ActinicPWMValue=100;
DaylightPWMValue=0;
ActinicPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
int x=0;
if ((cloudstart/60)>=10) x=11; else x=17;
if ((cloudstart%60)>=10) x=29; else x=35;
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=51; else x=57;
if (((cloudstart+(cloudduration/2))%60)>=10) x=69; else x=75;
ReefAngel.LCD.DrawText(0,255,x,120,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
