Reef Angel Dashboard w/ video integration
PostPosted: Fri Jul 12, 2013 2:43 pm
Not without rooting it, then it would just be a simple edit of /etc/hosts :) but then again they have the home/away profile..
But yes that might be a good solution for some. +1
PostPosted: Wed Nov 27, 2013 11:27 am
Sacohen wrote:This is an image of the portal.
How do you get the DC pump section in the portal Mine doesnt show my DC pumps!
PostPosted: Wed Nov 27, 2013 11:48 am
You have to have the DCPump.h class in your code and then set your pumps to use that. You are probably still using the PWM code for your pump control.
PostPosted: Wed Nov 27, 2013 4:17 pm
this is what i have it changes the flow very often! i have the DC pump class
    ReefAngel.FeedingModePorts = Port5Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port5Bit | Port8Bit;
    InternalMemory.OverheatTemp_write( 840 );
  //  ReefAngel.DCPump.FeedingSpeed=25;
  //  ReefAngel.DCPump.WaterChangeSpeed=25;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardATO( Port1,5000 );
    ReefAngel.StandardLights( Port2,7,0,0,0 );
    ReefAngel.StandardLights( Port3,7,0,22,0 );
    ReefAngel.StandardLights( Port4,11,0,23,0 );
    ReefAngel.StandardHeater( Port7,780,790 );
    ReefAngel.PWM.SetChannel( 0, PWMSlope(7,0,23,0,0,100,90,0) );
    ReefAngel.PWM.SetChannel( 1, PWMParabola(10,0,22,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 2, PWMParabola(8,30,20,0,0,100,0) );
    ReefAngel.PWM.SetChannel( 3, PWMSlope(7,30,22,30,0,100,90,0) );
//Feed Mode Delay on Pump
static boolean feeding=false;
static unsigned long feedingstarted = now();
  if (!feeding)
  feeding=true;
  feeding=false;
///// Place your custom code below here
//IDK Rimai Posted
#define Mem_B_RFMode           VarsStart+55
// Read memory for RF Wave Settings and use for Tunze/Jaebo
int mode;  //=InternalMemory.RFMode_read();
int speed=InternalMemory.RFSpeed_read();
int duration=InternalMemory.RFDuration_read();
// Add random mode if we set to Mode to 12
static int rmode;
if (now()%1800==0) {
  rmode=random(7); // Change the mode twice per hour to modes 0-6
static int RSpeed;
if (now()%900==0) {
  RSpeed = random(40,75);
else if(RSpeed==0){
  RSpeed = 80;
int DurMS;
int DurS;
if (now()%900==0) {
DurMS=random(250,500);
if (now()%900==0) {
DurS=random(2,15);
if (rmode==6) {
  // Constant
    ReefAngel.DCPump.SetMode( Constant,RSpeed,10 );
else if (rmode==1) {
    // Lagoon
    ReefAngel.DCPump.SetMode( Lagoon,RSpeed,10 );
} else if (rmode==2) {
    // Reef Crest
    ReefAngel.DCPump.SetMode( ReefCrest,RSpeed,10 );
} else if (rmode==3) {
    // Short Pulse
    ReefAngel.DCPump.SetMode( ShortPulse,RSpeed,DurMS );
} else if (rmode==0) {
    // Long Pulse
    ReefAngel.DCPump.SetMode( LongPulse,RSpeed,DurS );
} else if (rmode==5) {
    // Tidal Swell
    ReefAngel.DCPump.SetMode( TidalSwell,RSpeed,10 );
} else if (rmode==4) {
    // Smart_NTM
    ReefAngel.DCPump.SetMode( NutrientTransport,RSpeed,250 );
// Add night mode (constant 30%)
if (now()%SECS_PER_DAY<30600 || now()%SECS_PER_DAY >=81000) { // Time is before 8:30am and after 10:30pm
    // Long Pulse
    ReefAngel.PWM.SetDaylight( LongPulseMode(0,40,20,true) );
    ReefAngel.PWM.SetActinic( LongPulseMode(0 ,40,5,false) );
    ReefAngel.Portal( "Bruz4023" );
PostPosted: Thu Dec 12, 2013 9:34 am
no one had an answer for me?
PostPosted: Thu Dec 12, 2013 10:20 am
I don't think your controller is sending data to the portal.
The last update was 10/15/13.
Previous
Return to Requests
