orp not working
PostPosted: Thu May 09, 2013 3:13 pm
I have purchased the orp expansion hub months ago. have had it plugged into the expansion hub, but the probe not. still in the storage solution.
I two weeks ago took the probe and put it in the sump ( i read 2 week break in period )
today i tried calibrating it.
hooked up the little bnc dongle. hit okay registered 1786
had probe sitting in the 400mV solution ( changed the libraries to read 400 instead of 470mV )
it read mid to high 100's i believe
placed in a cup of rodi water, the parameters changed, put it back into the 400mV solution it read 400mV instantly.
rinsed with rodi water again and placed in sump.
it lowered to 350ish. then BOOM dropped to 50 then to 0.
that was weird. took it out. placed in rodi water. didn't change. placed in the calibration fluid, no change.
re calibrated it worked, left in the rodi water it held, then boom it dropped off as it did in the sump
what gives?
any ideas? do I have a crap probe?
Adam
58 Gal
PostPosted: Thu May 09, 2013 3:34 pm
noticed wifi wasn't working. changed the parameters in the globals.cpp
recalibrated again and now seems to work.
maybe loose connection or build up? I dunno
Adam
58 Gal
PostPosted: Sat May 11, 2013 8:54 am
yup, so it dropped out again.
Adam
58 Gal
PostPosted: Sat May 11, 2013 10:54 am
What happened right before it dropped out?
PostPosted: Sat May 11, 2013 1:39 pm
I dunno. I haven't done anything with it.
Just Noticed I didn't have any readings while I was at a friends house plumbing his system for ATO ( 10 sumps )
Adam
58 Gal
PostPosted: Sat May 11, 2013 8:26 pm
Looking at the graph, something happened friday at noon pacific time that made the ORP go to 400 and then back down to 300 over the next 20 minutes or so, when it then went to zero at around 12:40pm pacific time.
PostPosted: Sun May 12, 2013 10:49 am
Friday I was gone all day, installing ATO system.
Adam
58 Gal
PostPosted: Sun May 12, 2013 5:43 pm
How did you get it to work the other time?
PostPosted: Sun May 12, 2013 10:53 pm
rimai wrote:How did you get it to work the other time?
Un plugged it, calibrated it, plug back in. It worked.
No change this time, I'm out of calibration fluid
Adam
58 Gal
PostPosted: Mon May 13, 2013 8:21 am
I think you will need to send it for analysis.
PM me for details.
Return to Requests
