Help to connect a certain controllable pump to my ATO DWM
PostPosted: Thu May 30, 2013 6:33 pm
Hello reefers!
Let me warn all of you that I am a complete noob who's just managed to get the wizard do everything I need... up until now... so this is my first incursion in the programming territory. I also know, because I saw something like this and can't find it again, that this has been done.
Here's my predicament:
I would like to run a pretty powerful pump that has a model name very similar to MP40... only costs like 1/5 of the price... (I understand there's patent issues and that's why I rather not use specific names) from one of my DWM ATO channels as my light dimmers are taken by 4 Meanwell drivers and I have an external ATO float switch taking care of my ATO needs...
I need someone to take a look at my code and hand-held me through this process.
Any takers? I'd be forever grateful... I can treat to brews if ever in Western Massachusetts.
I know I need to make a mod to the cable. Is it the 'pump controller cable' sold at the RA store? And then after that, all I want it to do is to run on the minimum setting during the night... say 11pm to 11am and do random flow at random speed (between 30 and 60 seconds) during the day. Max power 50%, min power 20% I have read most of the threads on this topic but couldn't find one that is specific for my scenario.
This is my code:
    ReefAngel.WaterChangePorts = Port1Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.Relay.On( Port3 );
    ReefAngel.Relay.On( Port4 );
    ReefAngel.StandardLights( Port2,23,0,11,0 );
    ReefAngel.WavemakerRandom1( Port5,60,100 );
    ReefAngel.WavemakerRandom2( Port6,30,130 );
    ReefAngel.StandardHeater( Port7,761,771 );
    ReefAngel.PWM.SetDaylight( PWMParabola(11,0,19,0,10,60,10) );
    ReefAngel.PWM.SetActinic( PWMParabola(10,0,20,0,10,60,10) );
    ReefAngel.Portal( "oscarinw" );
Thanks in advance!
PostPosted: Thu May 30, 2013 6:39 pm
Forgot to mention I am running library 1.0.4... I believe
PostPosted: Thu May 30, 2013 10:19 pm
I'll send your cable already mod :)
Then, you can use this:
viewtopic.php?p=24108#p24108
PostPosted: Fri May 31, 2013 8:01 am
I just placed the order. Paypal transacton ID is is: 9WA17139EY9676625
Thanks so much, you're the best! I'll be in touch to get some help with the code
Return to Requests
