Different settings for 2 different DC Pumps.
PostPosted: Fri Aug 29, 2014 7:47 pm
You can take out the const int and the ElseMode function you have in your code.
PostPosted: Fri Aug 29, 2014 8:02 pm
Ok so just remove all the code for Else Mode?
PostPosted: Sat Aug 30, 2014 6:06 am
Yep
PostPosted: Sat Aug 30, 2014 1:52 pm
As you know i don't know about coding.
I finally got my code to a point where it won't give me errors prior to the compiling when I remove the Else Mode Code.
It will check everything add then do the compiling and return a message that says
"Error Compiling" at the end.
#include <Wire.h>fF
#include <RA_NokiaLCD.h>f
// Define Relay Ports by Name
#define Actinic_Lights     1
#define Day_Lights         2
#define Kalkwasser         3
#define Pumps              4
#define Sump_Fan           5
#define DeNit_Doser        6
#define DeNit_Pump         7
#define ATO_Pump           8
#define Unused             Box1_Port1
#define Feeder             Box1_Port2
#define Unused             Box1_Port3
#define Unused             Box1_Port4
#define Unused             Box1_Port5
#define Unused             Box1_Port6
#define Unused             Box1_Port7
#define Dummy              Box1_Port8
// Does not need to be global.
// unsigned long ATOUpdate=0;
//Set Standard Menu
ReefAngel.AddStandardMenu();
ReefAngel.DCPump.DaylightChannel=AntiSync; // Now you're pump will be affected by the portal settings.
ReefAngel.DCPump.AntiSyncOffset=85;
ReefAngel.Relay.On( Pumps );
ReefAngel.Relay.On( Dummy );
  ReefAngel.StandardLights( Actinic_Lights,12,0,22,0 );
  ReefAngel.StandardLights( Day_Lights,13,0,21,0 );
  ReefAngel.StandardLights( Sump_Fan,13,0,21,0 );
  ReefAngel.WaterLevelATO(ATO_Pump,720,28,31);
  if ( hour()>=13 && hour()<21 )
  ReefAngel.PWM.SetChannel( 5, 0 );
  ReefAngel.PWM.SetChannel( 5, PWMSlope(21,0,13,0,0,MoonPhase() ,60,0) );
  //Mix Kalkwasser
static unsigned long Kalk_Mixing = 0;
static unsigned long stopTime = 0;
static byte prevWL=0;
if (ReefAngel.WaterLevel.GetLevel(1)>=100 && prevWL<100) {
  stopTime=now()+3600; // Get time one hour from now.
prevWL = ReefAngel.WaterLevel.GetLevel(1); // Store the water level
if (now() < stopTime) { ReefAngel.Relay.On(Kalkwasser); } else { ReefAngel.Relay.Off(Kalkwasser); }
  //AutoFeeder
static unsigned long autofeeding = 0;
if ((now()%SECS_PER_DAY==64800)) //if it is 6 pm
if ( autofeeding == 0 ) {
autofeeding = now(); //set the time of the start of feeding to variable feeding
if ((now()-autofeeding>=60) && (now()-autofeeding<=61)) //if between 60 and 61 seconds has past
if ( autofeeding > 0 ) {
autofeeding = 0;
  // DeNitrate Routine
int DeNit_Offset=3600;
int DeNit_Repeat=21600;
int DeNit_Doser_Offset=1200;
int DeNit_Doser_Runtime=600;
int DeNit_Pump_Runtime=1200;
int DeNit_ATO_Offtime=1500;
// Pump comes on first
ReefAngel.Relay.Set(DeNit_Pump,(now()-DeNit_Offset)%DeNit_Repeat<DeNit_Pump_Runtime);  // Runs denitrator pump
// Doser comes on second
ReefAngel.Relay.Set(DeNit_Doser,((now()-DeNit_Offset)-DeNit_Doser_Offset)%DeNit_Repeat<DeNit_Doser_Runtime); // Runs denitrator doser
  // Disable ATO
if ( (now()-3600)%21600<DeNit_ATO_Offtime) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Delay WL ATO after water change and DeNit_Dosing
  static time_t wcTimer=0;
  // First 10 minutes after WC disable ATO
  if (now()-wcTimer >= 0 && now()-wcTimer < 600)
    // Track Salinity low duration
    static unsigned long lastGoodSal;
    static boolean lowSalFlag;
    // Salinity is good, update counter
    if (ReefAngel.Params.Salinity>=335) lastGoodSal=now();
    // Counter hasn't been updating in 300 seconds..
    if (now()-lastGoodSal>300) {
      lowSalFlag=true; // Salinity is definitely below 33.5
      lowSalFlag=false; // Salinity back to normal
    // Disable ATO if lowSalFlag is true
    if (lowSalFlag) ReefAngel.WaterLevelATO(ATO_Pump,720,0,1);
  // Disable ATO if ATO High IsActive()
static int rmode;
byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else };
changeMode=false;
static unsigned long feeding;
if (now()-feeding<3600) {
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
  ReefAngel.DCPump.Speed=30;
  ReefAngel.Portal( "Sacohen","S3tho31o" );
int x,y;
// Water Level
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,75,57, "WL:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,57, ReefAngel.WaterLevel.GetLevel() );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,66,66, "WL 1:" );
ReefAngel.LCD.DrawText( COLOR_DARKGOLDENROD,DefaultBGColor,99,66, ReefAngel.WaterLevel.GetLevel(1) );
//Salinity
  strcat(text,"  ");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,39,75,"Salinity:");
  ReefAngel.LCD.DrawText(DefaultFGColor,DefaultBGColor,99,75,text);
ReefAngel.LCD.DrawOutletBox(12, 104, TempRelay);
PostPosted: Sat Aug 30, 2014 2:26 pm
Just Error Compiling? Odd.i'll take a look tonight
PostPosted: Sat Aug 30, 2014 3:13 pm
Yeah. That's all it says on the bar.
PostPosted: Sat Aug 30, 2014 6:55 pm
So I got "Error Compiling" as well with the following info though in the box at the bottom..
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp: In member function 'void ReefAngelClass::SetDCPumpChannels(byte, byte)':
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp:2333: error: name lookup of 'a' changed for new ISO 'for' scoping
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp:2322: error: using obsolete binding at 'a'
/Users/lnevo/Documents/Arduino/libraries/ReefAngel/ReefAngel.cpp:2333: error: expected primary-expression before ')' token
I think I hit that before and fixed it, maybe it forgot to get in the commit? Checking it now....
PostPosted: Sat Aug 30, 2014 7:02 pm
What are you two working on? You want one pump running ReefCrest while another runs Nutrient Transport? lol
PostPosted: Sat Aug 30, 2014 7:04 pm
Ok. Fixed it. Not sure why I was able to compile on my test code. Guess it would depend on what channels were used, I think in my I was just doing daylight/actinic.
Anyway, re-download the update at here
PostPosted: Sat Aug 30, 2014 7:05 pm
AlanM wrote:What are you two working on? You want one pump running ReefCrest while another runs Nutrient Transport? lol
No, just the ability to slow one of the pumps down if it's overpowered.
Return to Requests
Users browsing this forum: No registered users and 7 guests
