Different settings for 2 different DC Pumps.
PostPosted: Sun Aug 31, 2014 4:39 am
It compiled now.
I had all that stuff at the bottom too, but there is always stuff running down there.
I pay attention to what's in the bar,
I'm going to upload it now and see how it works.
PostPosted: Sun Aug 31, 2014 5:16 am
It uploaded and either it's not working properly or it;s not working because my pumps are coded to run at 30% at night.
Both the portal and Android show the pumps running at 29% rather than the 30 they are coded at during the night.
I tried it with an offset of 85% and then 50% and both the same results.
Is it because of this line of code....
} else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
  // Night mode (go to 30%)
that puts it at 30% between 10pm and noon.
If so why is it at 29% and not 30%?
Thanks;
PostPosted: Sun Aug 31, 2014 5:41 am
I've also noticed that other readings are off.
The main WL sensor is reading 29% where it would normally be 32% where the water level in the sump sits now.
Also the multi WL sensors are not reporting now.
PostPosted: Sun Aug 31, 2014 5:51 am
Can you try with Roberto's dev library and see if it's the same?
One reason it could say 29% instead of 30% is that everything is high resolution now. So there may be some rounding issues somewhere. As far as the WL, I don't believe any of that has been touched... I dont' recall seeing any commits that would change that.
Also try with the offset set to 100. That would be 100% and should have no change on what your pumps were at.
Finally one other thing to try is to run the wizard and just set a generic code (without all the random stuff and things we have in yours...) to see what the result is...
PostPosted: Sun Aug 31, 2014 5:54 am
I'll try later today.
I have to try a repair a pool pump today.
Pumps are not high resolution. But I always see 29 instead of 30 on mine too. Maybe there is an off by 1 error somewhere in dev.
PostPosted: Sun Aug 31, 2014 6:31 am
Good to remember...
PostPosted: Sun Aug 31, 2014 6:33 am
I tried Robertos Dev Code and got the same issues.
29% of ump speeds and main WL sensor.
The Multi WL is not displaying.
Obviously I had to pull the offset out to use Roberto's libraries, but I did try it at 100% before switching to his libraries and it still showed 29%.
I haven't tried an INO from the wizard yet.
The wife it bugging me to look at the pool pump.
PostPosted: Sun Aug 31, 2014 6:46 am
Wait, so you set it to 100 and it shows 29? I thought it was showing 29 when you set it to 30.
PostPosted: Sun Aug 31, 2014 7:15 am
The offset of the pumps speed is set to 100% or no offset as opposed to 50% (half speed).
The 30% is what the pump is running at.
It supposed to run at 30% over night and it is running at 29%.
Return to Requests
