Different settings for 2 different DC Pumps.
PostPosted: Mon Sep 01, 2014 8:56 am
I'm having a labor day party too...it's called long postponed aquascaping day :D
PostPosted: Mon Sep 01, 2014 5:02 pm
For what it's worth, with my current version of /dev with the fix to pump speed reporting, I am now seeing 30 percent instead of 29 percent when things are set to 30, so it was integer truncation error.
PostPosted: Mon Sep 01, 2014 5:48 pm
Btw, there should be no reason the offset can't be greater than 100. Say you want it to be 125% you can go all the way to 255 :)
PostPosted: Mon Sep 01, 2014 5:55 pm
I tried else mode with 100% offset and it didn't seem right.
The daylight channel was physically off. I put my hand in the tank and there was no movement. All displays read 0.
The actinic was full throttle.
Displays read 193 and felt like more power then I ever felt out of the WP40.
Something wasn't right.
PostPosted: Mon Sep 01, 2014 6:34 pm
Hmm thats odd. Will need to do some checking...
PostPosted: Mon Sep 01, 2014 7:31 pm
Can you try some tests with constant too, may be better able to see what's going on.
PostPosted: Tue Sep 02, 2014 3:28 am
I'll try them tonight.
PostPosted: Tue Sep 02, 2014 6:48 am
I think I did try Constant Mode, but I'll try it again.
PostPosted: Tue Sep 02, 2014 7:23 am
Just curious the results at diff speeds on constant and with a couple diff offsets. Would help to narrow down what I may have done wrong.
PostPosted: Tue Sep 02, 2014 7:49 am
Lee;
How can you have a value of over 100%?
you said in a previous post that you can enter up to 255.
Will that make the pump run faster then it should?
Return to Requests
