Daily Controller Restart
Hello everyone! I was wondering if there is a way to write a code to schedule a daily restart for the controller itself? I have this issue with my controller that I have to power down and power up every morning, because of wireless not working, wavemaker is stopped, or lights are on when they are supposed to be off.
Re: Daily Controller Restart
It is "Reef Angel Controller"
I believe that board uses the standard bootloader. You would have to update your bootloader to enable the watchdog functionality (or get a replacement board/head unit). Then you could force a reset quite easily. I'm sure Roberto has suggestions or ideas for you.
Sorry, my internet was so bad yesteday that I gave up trying to connect to anything.
Yes, you need to upgrade the bootloader like Curt said.
http://forum.reefangel.com/viewtopic.php?f=2&t=113
Here is another event for this morning. My wavemaker is shutdown, my lights are on. The readings on Client Suite is below. After resetting the controller, all readings are normal. I will try the recommendation and see what happens.
Which ISP am I suppose to use? I have;
AVR ISP
AVRIPS mkII
USBtinyISP
Parallel Programmer
Arduino as ISP
AVR ISP
AVRIPS mkII
USBtinyISP
Parallel Programmer
Arduino as ISP
rimai wrote:Sorry, my internet was so bad yesteday that I gave up trying to connect to anything.
The problem you are experiencing is due to the wavemaker pumps generating noise when they are turned on/off constantly.
Your relay box is one of the very early models that didn't have dampening components to minimize these spikes.
If you make them on instead of on/off in a cycle, it should take care of the causing issue. Otherwise, you can upgrade the bootloader and the controller will just fix itself should any problem happen.
Which one do you have?Rey wrote:Which ISP am I suppose to use? I have;
AVR ISP
AVRIPS mkII
USBtinyISP
Parallel Programmer
Arduino as ISP
These are external programmers that you need to buy from an online electronics store or build the parallel programmer yourself.
I have niether. Which one is highly recommended?
Roberto wrote:Which one do you have?
I've only used USBTinyISP from adafruit.com and it's always worked great for me.
I've got that one too. You have to solder it together though to get it to work. So if you are handy with a soldering iron, that would be fine for you.rimai wrote:I've only used USBTinyISP from adafruit.com and it's always worked great for me.
I've also got the pocket avr from sparkfun and that works great for me too. It's only windows though.
