dosing code???
PostPosted: Sun Dec 01, 2013 11:01 pm
so i finially got around to hooking all my new expansions today ( dimming, moonlight , dc power controller, expansion hub and dosing pumps). im trying to set up my dosing pumps for my 2 part. i would like to have them each run twice per 24 hours i want my alk to be doses at 9 pm and 9am and my calc to go from 10 pm and 10am. im looking to dose 35 ml per dose.
i tryed to figure this out with the wizard but got confused. i dont want to switch to the new dosing system till i have the code is worked out. any help would be awesome heres my code if it helps.
    ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
    ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port6Bit | Port7Bit;
    ReefAngel.Relay.On( Port5 );
    ReefAngel.StandardLights( Port1,21,0,9,0 );
    ReefAngel.StandardLights( Port2,9,0,19,0 );
    ReefAngel.Relay.DelayedOn( Port3,25 );
    ReefAngel.SingleATO( true,Port4,90,0 );
    ReefAngel.StandardLights( Port6,8,0,21,0 );
    ReefAngel.StandardHeater( Port7,785,790 );
    ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
    ReefAngel.Portal( "paulweck" );
PostPosted: Mon Dec 02, 2013 9:09 am
Try this:
ReefAngel.DosingPumpRepeat(Box1_Port1,540,720,45); // Alk Dose every 720 minutes with 540 minutes offset for 45 seconds
ReefAngel.DosingPumpRepeat(Box1_Port2,600,720,45); // Ca Dose every 720 minutes with 600 minutes offset for 45 seconds
PostPosted: Mon Dec 02, 2013 4:41 pm
Thanks Roberto. i place this in the custom code section right
Return to Requests
