dosing code???
Posted: Sun Dec 01, 2013 11:01 pm
so i finially got around to hooking all my new expansions today ( dimming, moonlight , dc power controller, expansion hub and dosing pumps). im trying to set up my dosing pumps for my 2 part. i would like to have them each run twice per 24 hours i want my alk to be doses at 9 pm and 9am and my calc to go from 10 pm and 10am. im looking to dose 35 ml per dose.
i tryed to figure this out with the wizard but got confused. i dont want to switch to the new dosing system till i have the code is worked out. any help would be awesome heres my code if it helps.
ReefAngel.FeedingModePorts = Port3Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port3Bit | Port4Bit | Port5Bit | Port7Bit | Port8Bit;
ReefAngel.LightsOnPorts = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port6Bit | Port7Bit;
ReefAngel.StandardLights( Port1,21,0,9,0 );
ReefAngel.StandardLights( Port2,9,0,19,0 );
ReefAngel.Relay.DelayedOn( Port3,25 );
ReefAngel.SingleATO( true,Port4,90,0 );
ReefAngel.StandardLights( Port6,8,0,21,0 );
ReefAngel.StandardHeater( Port7,785,790 );
ReefAngel.PWM.SetChannel( 5, MoonPhase() );
ReefAngel.DCPump.SetMode( ReefCrest,100,10 );
ReefAngel.DCPump.ExpansionChannel[0] = None;
ReefAngel.Portal( "paulweck" );
