ATO coding
PostPosted: Wed Apr 02, 2014 6:15 pm
by GTi_Leo
is there a coding for the ATO system were it goes on at set times of the day and uses the two floats as a shut off point?
my current sump is a DIY and what i have is a glass baffle box inserted and for some reason the 20lbs box wants to float if the water gets to low, so i'd like to change how the basic ATO function is to use both as a stop point for a solenoided RO holding tank ATO reservoir. which will use the same ATO plug to power the solenoid
Re: ATO coding
PostPosted: Wed Apr 02, 2014 9:25 pm
Not sure I understand what you want.
Can you explain a little better?
Re: ATO coding
PostPosted: Thu Apr 03, 2014 3:58 pm
by GTi_Leo
i want to have the ATO come on at a certain time of day, say 4PM and have the Float switch turn it off.
want to use both switches but when one hits the high limit it'll shut off and the other one as a back up just incase one seizes up
Re: ATO coding
PostPosted: Thu Apr 03, 2014 4:25 pm
Let's say it starts at 4pm and it turns off when it hits the float. Does it mean it would only turn on again next day at 4pm?
Re: ATO coding
PostPosted: Thu Apr 03, 2014 4:26 pm
by GTi_Leo
yes or at another point in the day if i choose to have it top off twice a day
Re: ATO coding
PostPosted: Fri Apr 04, 2014 8:31 am
You can use something like this:
  if (elapsedSecsToday(now())==57600) ReefAngel.Relay.On(Port1);
  ReefAngel.Relay.Off(Port1);
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Port1);
