I/O expansion added to wizard.
PostPosted: Thu May 01, 2014 1:22 pm
I have the I/O expansion but have not been able to use it.
I don't know how to program.
Will it ever be added to the wizard?
Also when will more pump modes be added?
I have gone back to using my stock jebo controllers to use else mode.
The reef crest mode sucks in that the lowest I have ever seen is 80%
It would be nice if it varied the flow from 30% to 100%
PostPosted: Thu May 01, 2014 1:26 pm
Sorry I accidentally put this under the hardware requests. Can I to have it put down in the software requests area.
PostPosted: Thu May 01, 2014 1:31 pm
Moved.
PostPosted: Thu May 01, 2014 2:02 pm
Else mode has been added and will be in the next release.
I agree we need conditional statements in the wizard, but I just find it hard to wrap my head around it because there are so many options of what you can do.
PostPosted: Thu May 01, 2014 2:19 pm
Maybe put some basic conditional statements and then people with little or nor coding experience (like myself) can use that as a basis to get started.
For example I'm sure I can set up the basics of my automated water change system, buy I'm going to want to put some conditional statements like if WL is <5% don't do AWC or if NSW is in mixing mode don't run AWC.
PostPosted: Fri May 02, 2014 6:57 am
I also suggest that we should able to use the IO expansion to cater for OUTPUT as well. I hope the wizard can include this request.
The OUTPUT can be used to set Alarm (buzzer) , LED alert and other third party devices.
Veeresh
Just my two cents worth
PostPosted: Fri May 02, 2014 2:44 pm
Veeresh wrote:I also suggest that we should able to use the IO expansion to cater for OUTPUT as well. I hope the wizard can include this request.
Veeresh
Yes The output to be used to set Alarm (buzzer) would help what I want to do.
Float switch in Cal and alk container. Buzzer or email turns on when they get low.
Float switch in Skimmer cup. Turn off Skimmer and turn on buzzer and email if cup gets full.
PostPosted: Fri May 02, 2014 4:34 pm
For all those float switches i would recommend the multi water level sensor.,
PostPosted: Fri May 02, 2014 7:55 pm
What revision is your board?
PostPosted: Sat May 03, 2014 9:44 am
rimai wrote:What revision is your board?
Not sure. How do I find out?
Next
Return to Requests
