I/O expansion added to wizard.
Posted: Thu May 01, 2014 1:22 pm
by Trevenator
I have the I/O expansion but have not been able to use it.
I don't know how to program.
Will it ever be added to the wizard?
Also when will more pump modes be added?
I have gone back to using my stock jebo controllers to use else mode.
The reef crest mode sucks in that the lowest I have ever seen is 80%
It would be nice if it varied the flow from 30% to 100%
Re: I/O expansion added to wizard.
Posted: Thu May 01, 2014 1:26 pm
by Trevenator
Sorry I accidentally put this under the hardware requests. Can I to have it put down in the software requests area.
Posted: Thu May 01, 2014 1:31 pm
Moved.
Posted: Thu May 01, 2014 2:02 pm
Else mode has been added and will be in the next release.
I agree we need conditional statements in the wizard, but I just find it hard to wrap my head around it because there are so many options of what you can do.
Posted: Thu May 01, 2014 2:19 pm
by Sacohen
Maybe put some basic conditional statements and then people with little or nor coding experience (like myself) can use that as a basis to get started.
For example I'm sure I can set up the basics of my automated water change system, buy I'm going to want to put some conditional statements like if WL is <5% don't do AWC or if NSW is in mixing mode don't run AWC.
Posted: Fri May 02, 2014 6:57 am
by Veeresh
I also suggest that we should able to use the IO expansion to cater for OUTPUT as well. I hope the wizard can include this request.
The OUTPUT can be used to set Alarm (buzzer) , LED alert and other third party devices.
Veeresh
Just my two cents worth
Posted: Fri May 02, 2014 2:44 pm
by Trevenator
Veeresh wrote:I also suggest that we should able to use the IO expansion to cater for OUTPUT as well. I hope the wizard can include this request.
Veeresh
Yes The output to be used to set Alarm (buzzer) would help what I want to do.
Float switch in Cal and alk container. Buzzer or email turns on when they get low.
Float switch in Skimmer cup. Turn off Skimmer and turn on buzzer and email if cup gets full.
Posted: Fri May 02, 2014 4:34 pm
For all those float switches i would recommend the multi water level sensor.,
Posted: Fri May 02, 2014 7:55 pm
What revision is your board?
Posted: Sat May 03, 2014 9:44 am
by Trevenator
rimai wrote:What revision is your board?
Not sure. How do I find out?
Posted: Sat May 03, 2014 10:29 am
by Trevenator
Just ordered the Multi-Channel Water Level Expansion will use that to monitor the levels of my Cal - Alk - vinegar - vodka.
I already have the single Water Level Expansion on my ato.
Would still like a float switch on my skimmer cup and be able to shut it off and send a email when its full.
Posted: Sat May 03, 2014 11:40 am
Open the enclosure. It will be written in the pcb.
Posted: Sat May 03, 2014 11:42 am
For your skimmer cup, use this:
ReefAngel.Relay.Set(Port1,ReefAngel.IO.GetChannel(0)); // Set port 1 according to I/O channel 0
Posted: Mon May 05, 2014 11:35 am
by Trevenator
rimai wrote:Open the enclosure. It will be written in the pcb.
It says reef angel plus main unit 2.1
Posted: Mon May 05, 2014 11:36 am
I meant the I/O module.
Posted: Mon May 05, 2014 2:02 pm
by Trevenator
ok its I/O Expansion 2.0
Posted: Mon May 05, 2014 2:25 pm
Yes, starting on 2.0 version, you can easily use any port as output too. You just need to code it so the module knows you are using as output.
You need to add this to the end of your code:
void SetIOChannel(byte channel, byte value)
Wire.beginTransmission(I2CIO_PCF8574);
Wire.write(value<<channel);
Wire.endTransmission();
Then, in your code, you can set any channel on the I/O module like this:
SetIOChannel(0,1); // Set channel 0 to on
Posted: Fri May 16, 2014 4:17 pm
by Veeresh
Hi Roberto
My IO Expansion module rev is 2.2
I have added the following coding
in the setup I called the following codes
// init IO port 1 to 3
// Testing phase
SetIOChannel(1,1); // Set channel 1 to on
SetIOChannel(2,1); // Set channel 2 to on
SetIOChannel(3,0); // Set channel 3 to off
SetIOChannel(4,0); // Set channel 4 to off
SetIOChannel(5,0); // Set channel 5 to off
and in the loop
if (hour()>=0 && hour()< 17 )
unsigned long currentMillis = millis();
if ( currentMillis - previousMillis >= intervaltimer )
if (FanOffStatus == false)
FanOffStatus = true; // variable set to off the fan
previousMillis = currentMillis;
intervaltimer = 30000 ;
SetIOChannel(4,1); // Set channel 4 to on
SetIOChannel(5,0); // Set channel 5 to on
FanOffStatus = false; // variable set to on the fan
previousMillis = currentMillis ;
intervaltimer = 5000 ;
SetIOChannel(4,0); // Set channel 4 to on
SetIOChannel(5,1); // Set channel 5 to on
ReefAngel.Relay.Off( Port3 );
ReefAngel.Relay.On( Port3 );
I'm just wanted to test the IO module to in port 4 and 5 to toggle between ON and OFF stage. and I noticed that all my port are at +5V including port 4 an 5. There is no toggling in voltage in port and 4 and 5. Looks like the RA is not IO module is set to OUTPOT module. Please advise
Posted: Fri May 16, 2014 5:43 pm
I'll have to check when I get to the office.
Sent from my SM-G900P using Tapatalk
Posted: Fri May 23, 2014 10:40 pm
I'm not so sure why it is not working for you.
This is what I tested:
if (millis()%2000<1000)
SetIOChannel(0,1);
SetIOChannel(0,0);
Channel 0 goes high and low every second.
