Android app to control led dimming
PostPosted: Tue Dec 16, 2014 4:28 pm
I would like to be able to control the dimming of my led's with my smart phone app. Is this possible?
PostPosted: Tue Dec 16, 2014 5:50 pm
Yes it is. You can use either the android app or the universal app.
PostPosted: Tue Dec 16, 2014 8:37 pm
Do I have to use the Portal or can I just use the App? Is there a tutorial on how to do it.
PostPosted: Wed Dec 17, 2014 11:16 am
Depends which app. In the universal app you go in the dimming tab and you can adjust the sliders. If you want to change the program and are using internal memory you can go into settings -> internal memory and adjust all the values just like on the portal
PostPosted: Thu Dec 18, 2014 10:08 pm
the android app, you can just long press on the dimming percentage and it pops up a window for you to adjust the dimming values with a slider and then set/save the values and it updates the controller.
PostPosted: Fri Dec 19, 2014 8:34 pm
Do I need portal to be able to use the dimming in the app? Or do I need the dimming expansion? The app let me adjust the output but it didn't take the charge.
PostPosted: Sun Dec 21, 2014 1:34 pm
lurch wrote:Do I need portal to be able to use the dimming in the app? Or do I need the dimming expansion? The app let me adjust the output but it didn't take the charge.
no. you do not need the portal to use dimming. the ap and dp dimming ports on the controller are different than the expansion.
if the settings didn't take, then you could have something in your controller code that is overriding the settings or your controller may not accept the override commands that get sent.
Sent from my Moto X
PostPosted: Sun Dec 21, 2014 6:13 pm
I had an extra space in my ip address now it works. I don't see a feeding button?
PostPosted: Sun Dec 21, 2014 7:10 pm
Upper left corner.
PostPosted: Sun Dec 21, 2014 7:33 pm
Sorry I meant the universal app
Next
Return to Requests
