smoothing out led dimming
Posted: Wed Nov 04, 2015 4:37 pm
by Ademster
is there a way to smoooth out the dimming?
I have the pwm expansion running ldd drivers.
you can see the steps as it dims, Id like to smooth it out so it slowly drops down like the sun rather step down... is this possible?
Re: smoothing out led dimming
Posted: Wed Nov 04, 2015 7:14 pm
As long as its not a really old dimming expansion you should be able to use the new highres dimming that gives us 4096 steps instead of 256. Can you post your code? When was the last time you updated your libraries and ra?
Posted: Wed Nov 04, 2015 7:15 pm
Even with the older module you'll actually get 256 steps rather than 100, which is still a big increase :)
Posted: Thu Nov 05, 2015 6:13 am
by Ademster
this is whats in there now, but will be changing it soon eliminated the dc pump as it doesnt work, stuck on constant 30% never changed.
and adding delay to when certain channels start coming on for sun rise effect.
I built a new 180gal 48x30x30 tank and large sump with new equipment. so codes needs to be redone.
    ReefAngel.AddSalinityExpansion();  // Salinity Expansion Module
    ReefAngel.AddMultiChannelWaterLevelExpansion();  // Water Level Expansion Module
    ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port4Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port3Bit;
    ReefAngel.DCPump.FeedingSpeed=30;
    ReefAngel.DCPump.ActinicChannel=Sync; // Now you're pump will be affected by the portal settings.
    ReefAngel.Relay.On( Port7 );
     //Use PH Flexible Calibration
    ReefAngel.Wavemaker1( Port5 );
    ReefAngel.DayLights( Port8 );
    ReefAngel.PWM.Channel0PWMSlope();
    ReefAngel.PWM.Channel1PWMSlope();
    ReefAngel.PWM.Channel2PWMSlope();
    ReefAngel.PWM.Channel3PWMSlope();
    ReefAngel.PWM.Channel4PWMSlope();
    // Add random mode if we set to Mode to Custom in portal
    static int rmode;
    byte modes[] = { ReefCrest, Lagoon, Constant, TidalSwell, ShortPulse, LongPulse, Else, Gyre };
    if (now()%SECS_PER_DAY==0 || changeMode==true) { // Change at midnight or if controller rebooted
    rmode=random(100)%sizeof(modes); // Change the mode once per day to pick from our array
    changeMode=false;
    static unsigned long feeding;
    if (now()-feeding<3600) {
    // Continue NTM for the 60 minutes
    ReefAngel.DCPump.Mode=NutrientTransport;
    } else if (now()%SECS_PER_DAY<43200 || now()%SECS_PER_DAY>=79200) { // 12pm / 10pm
    // Night mode (go to 30%)
    ReefAngel.DCPump.Mode=Constant;
    ReefAngel.DCPump.Speed=30;
    } else if (InternalMemory.DCPumpMode_read()==11) {
    ReefAngel.DCPump.Mode=modes[rmode]; // Put the mode to the random mode :)
    } else {
    ReefAngel.Portal( "ademster" );
Posted: Thu Nov 05, 2015 6:41 am
Good news. The code you are using will support the high resolution dimming. You just need to make sure you're on the latest libraries and re-upload. You should get either double or ~400x resolution.
Posted: Sat Nov 07, 2015 6:51 am
by Ademster
so simply updating the libs and uploading the new code will give me the better resolution on dimming?
Posted: Sat Nov 07, 2015 3:20 pm
It should. It was added into the last release and should be transparent based on your code.
Posted: Sun Nov 08, 2015 8:29 pm
I think he will need a code change.
Posted: Sun Nov 08, 2015 8:48 pm
Why? He'a using ReefAngel.PWM.ChannelXSlope() those functions call the HighRes functions behind the scenes. What code would need to change?
Posted: Sun Nov 08, 2015 8:52 pm
It calls the high res behind the scenes, but the resolution is still 0-100 steps, which gets upscaled, I think.
He would need to use the raw numbers 0-4096 to be able to take advantage of the high resolution.
Posted: Sun Nov 08, 2015 8:59 pm
I'm pretty sure thats not the case.
Posted: Mon Nov 09, 2015 5:37 am
Here's the function. It's callng HighRes slope and doing a SetChannelRaw. I think he's good....
void RA_PWMClass::ChannelPWMSlope(byte Channel, byte Start, byte End, byte Duration)
	SetChannelRaw(Channel,PWMSlopeHighRes(
		InternalMemory.StdLightsOnHour_read(),
		InternalMemory.StdLightsOnMinute_read(),
		InternalMemory.StdLightsOffHour_read(),
		InternalMemory.StdLightsOffMinute_read(),
		Start,
		End,
		Duration,
		ExpansionChannel[Channel]
Posted: Mon Nov 09, 2015 10:23 am
I think you are right.
Looking at the code now, it looks like it would work.
