Creating custom modes in menu
PostPosted: Tue Jul 03, 2018 10:12 am
by tngo
Hi All,
Is there a way that I would be able to create a selectable custom mode similar to the feeding and water changing modes? If say I wanted to create a mode to fill my salt mixing bucket with ro/di water, which would turn on/off a certain relay after a set time. Being able to select it in the menu allows me to initiate the mode at any time.
Tim
Re: Creating custom modes in menu
PostPosted: Tue Jul 03, 2018 9:34 pm
You can use it like Lee did.
Just use a virtual relay port to trigger the mode.
Add a second or third relay box, even though you don't physically have it and use the relays on that port to trigger the mode.
PostPosted: Fri Jul 06, 2018 10:10 am
by tngo
Thanks Roberto. Found the virtual relay topic on the forums.
viewtopic.php?f=12&t=4531&p=38635&hilit=virtual+relay+port#p38635
Tim
