Request: Updated web banner
Re: Request: Updated web banner
I created the Style 3 web banner.
http://www.reefangel.com/status/image_s ... x?id=rimai
To have the new data showing up, you have to append the string you send to the reefangel.com server with the following:
relaydata1 through relaydata8 - value that contains the status of the relays for the expansion boxes
r11n through r18n - names for the expansion relay box #1
r81n through r88n - names for the expansion relay box #8
yesssss!!
Very cool. Just to let everybody know, this will probably not be inside RAGen for a little while. You can still add it in to the PDE after it is generated by RAGen, but the ability for RAGen to include it automatically for you will be available yet.rimai wrote:I created the Style 3 web banner.
How do I make it so that I can actually see the status of the expansion relays? I am using the client and I included these codes to test out relay 14:
It does turn on the pump, but I don't see the banner.
#define Vortech 14
ReefAngel.Relay.On(Vortech);
The dev libraries already include statements for the expansion relays in ReefAngel_Globals.h. The one for you is:alexwbush wrote:How do I make it so that I can actually see the status of the expansion relays? I am using the client and I included these codes to test out relay 14:
#define Vortech 14
It does turn on the pump, but I don't see the banner.Code: Select all
#define Box1_Port4 14
good to know, thanks Curt! I'll keep an eye out for an easier way to broadcast the info from the relays.
