Wireless Locking up
PostPosted: Sat Jun 16, 2012 8:33 am
Here are the ideas that the manufacturer gave me to try:
in our latest firmware,
we have a "back door" command that you can use to reboot the module
you use "set sys debug 0x80"
and then "set a r 86400" // 3600 * 24 seconds = 1 day....
but this only works if you are NOT connected to the AP.
you could set the sleep timer to sleep after XXXX seconds and then wake right away:
set sys sleep 86400 // sleep once per day or maybe much more often? 3600 = once per hour
set sys wake 1 // wakes right back up after 1 second.
We do have a new build ver 2.33 I would like you to try. You can get it via "ftp u wifly7-233.img"
They recently changed their FTP server.
The FTP server's IP address has changed. Please refer to the following to point your module to the correct IP address:
http://rovingnetworks.com/FAQs/I_get_FT ... o_upgrade_
my_WiFly_module
The command you need to issue is "ftp u wifly-233.img" after you point the module to the new FTP server.
Check to see if any one of those help you.
PostPosted: Tue Jul 31, 2012 9:41 pm
I just tried the first two commands . We will see how it goes. I usually do fine untill the power gets interupted at my AP. After that I have to unplug and replug the controller to get it to reconnect. I just want it to reconnect automatically once a day.
PostPosted: Fri Aug 03, 2012 7:12 am
I have had several power outages and the wireless consistently reconnects on it's on. The only Wierd think is that the portal does have any history past July 27. I used the first two of the commands above. They are clearly working.
PostPosted: Fri Aug 03, 2012 7:13 am
I have had several power outages since using the commands above and the wireless consistently reconnects on it's on. The only wierd thing is that the portal does not have any history past July 27. I used the first two of the commands above. They are clearly working.
PostPosted: Mon Aug 13, 2012 7:14 pm
Ok here is the final verdict. Using the option below works:
Input this code into your wireless module:
I use 3600 seconds to put my wireless to sleep and to wake it back up every hour. I used the davemotion wireless utility advanced screen to upload the code to my wireless module. Be sure to use $$$ before each command and enter the save command to save the code.
The first option above interferes with uploading to the portal so don't use it.
Since enabling this option, I have never lost a connection for more than one hour and my portal history is intact.
PostPosted: Mon Aug 13, 2012 7:36 pm
Thanks for sharing :)
PostPosted: Fri Aug 31, 2012 6:13 am
I thought I had done this correctly but I'm guessing not as can not log into the portal anymore.
When I did it I did the $$$ to get the command mode line then typed:
set sys sleep 86400 // (enter)
then it would go out of command mode and would have to log back in and do $$$ again to get it in command line then entered set sys wake 1 // and saved the config. Did I only save the sys wake command?
-Dave
PostPosted: Fri Aug 31, 2012 6:36 am
If you use get instead of set, you can pull the information store in the memory.
PostPosted: Fri Aug 31, 2012 8:04 am
ok Ill see if I can pull this info later when Im home
-Dave
PostPosted: Sat Sep 08, 2012 7:07 am
Looks like this works for me also. Ive now gone a week with out having to reboot the wifi device! Thanks!
-Dave
Return to Requests
