T1:Error PH: Error
Posted: Tue Sep 04, 2012 12:38 am
by Bryan
Hi Roberto;
Just looking at the RA Interface and noticed that T1-3: All report "Error" as well as PH:Error. There is a temp probe on T1 and a Ph probe on the BNC connector. Using the RAPreloaded sketch.
Re: T1:Error PH: Error
Posted: Tue Sep 04, 2012 8:19 am
pH shows error too??
I've never seen it showing error before.
Could it be the calibration numbers on internal memory?
Posted: Tue Sep 04, 2012 8:49 am
by Bryan
Hi Roberto:
Thought the same, I was trying to find in the code where it reads the probe and returns a value, but couldn't. Here is a read of the EEPROM if that helps.
:10000000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF00
:10001000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0
:10002000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE0
:10003000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD0
:10004000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFC0
:10005000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFB0
:10006000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFA0
:10007000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF90
:10008000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF80
:10009000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF70
:1000A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF60
:1000B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF50
:1000C000FFFFFFFFFFFFFFFF0F1E15000E00151EB5
:1000D0000A000F00040484035802DC051414FE0215
:1000E000020306030203FFD601D501071400161E02
:1000F00000FFFF3C003C00F6090F643C0F643C002D
:1001000032080F643C0F643C0F643C0F643C0F6486
:100110003C0F643C7800FFFF0208C2011E0203F896
:100120000220032A0300643C00643C00643C006439
:100130003C00643C00643C00643C00643C00643C63
:1001400007F401C4093B0BF70DFFFFFFFFFFFFFFA3
:10015000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAF
:10016000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9F
:10017000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8F
:10018000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7F
:10019000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6F
:1001A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5F
:1001B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4F
:1001C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3F
:1001D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2F
:1001E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1F
:1001F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0F
:10020000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFE
:10021000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEE
:10022000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDE
:10023000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCE
:10024000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBE
:10025000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAE
:10026000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9E
:10027000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8E
:10028000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7E
:10029000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6E
:1002A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5E
:1002B000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF4E
:1002C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3E
:1002D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2E
:1002E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1E
:1002F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0E
:10030000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFD
:10031000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFED
:10032000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDD
:10033000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCD
:10034000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBD
:10035000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFAD
:10036000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF9D
:10037000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF8D
:10038000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF7D
:10039000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF6D
:1003A000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF5D
:1003B000FFFFFFFFFFFFFFFFFF281EA306CFFFFF8A
:1003C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF3D
:1003D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF2D
:1003E000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF1D
:1003F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF0D
:00000001FF
Posted: Tue Sep 04, 2012 9:40 am
I think they are wrong.
It is stored in mem location 231 and 233 and seems like they are 0x01d5 and 0x01d6, which looks wrong to me.
Posted: Tue Sep 04, 2012 12:17 pm
by Bryan
Hmm, I am using the InternalMemory Sketch to load the values. Perhaps the read of the eeprom is wrong. PHMAx should be 830 or x033E, and I don't see it either
Posted: Tue Sep 04, 2012 6:09 pm
by Bryan
Roberto:
Stripped out all the other memory mapping to the EEProm in the Internalmemory sketch and just stored the following
#include <avr/pgmspace.h>
    InternalMemory.PHMax_write(830);
    InternalMemory.PHMin_write(540);
    InternalMemory.IMCheck_write(0xCF06A31E);
After flashing and rereading the EEPROM this is what is returned. Not sure if correct or in the right place, assume so because the Memory Check is correct or the interface would not have gotten to the main screen.
3E03 and 1C02, obviously 3E03 is not 830, but not sure how the value of 830 would be stored as a int in 2 bytes
:1000C000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF40
:1000D000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF30
:1000E000FFFFFFFFFFFFFF3E031C02FFFFFFFFFFBD
:1000F000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF10
:10010000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF
:10011000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFEF
:10012000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFDF
:10013000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFCF
:10014000FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFBF
:1003B000FFFFFFFFFFFFFFFFFFFF1EA306CFFFFFB3
:00000001FF
Posted: Tue Sep 04, 2012 7:08 pm
That one is correct :)
Little endian.
0x021C=540
0x033E=830
Posted: Tue Sep 04, 2012 10:22 pm
by Bryan
Ah..little end first.
Still no banana though still shows PH:Error. Strange.. :(
:1000E000020306030203FF3E031C02071400161E50
:00000001FF
Posted: Wed Sep 05, 2012 7:45 am
What reading do you get from the raw analog pin?
  ReefAngel.Init();
  ReefAngel.LCD.DrawText(0,255,10,10,ReefAngel.PHMin);
  ReefAngel.LCD.DrawText(0,255,10,20,ReefAngel.PHMax);
  ReefAngel.LCD.DrawText(0,255,10,30,ReefAngel.Params.PH);
  ReefAngel.LCD.DrawText(0,255,10,40,analogRead(PHPin));
  ReefAngel.Refresh();
It's the 4th line in the screen.
Posted: Wed Sep 05, 2012 6:51 pm
by Bryan
Hi Roberto:
472 with probe attached and unattached
540
830
0
472
Posted: Wed Sep 05, 2012 7:17 pm
It doesn't look like the probe is working.
Can you short out that BNC connector?
What value do you get?
Posted: Thu Sep 06, 2012 12:15 am
by Bryan
Hi Roberto:
Tried a known good probe same "PH:Error"
540
830
0
626
BNC Shorted
540
830
0
537
Posted: Thu Sep 06, 2012 7:37 am
There is something weird in there.
The probe is reading raw data correctly, but it is not converting it to human readable pH scale.
The pH scale would be the 3rd number, which is the interpolation of the 4th within the range of the 1st and 2nd.
Posted: Fri Sep 07, 2012 12:24 am
by Bryan
So the 3rd number has to be something other than 0.
Posted: Fri Sep 07, 2012 7:48 am
:? Yes, it has to be a number between 0 and 1400, which represent the pH without decimal point.
If my calculations are correct, here is the interpolation:
Analog read: 540----626----830
pH converted read: 7.00----x----10.00
x would be 7.89, which should be the 3rd number.
So strange that is not calculation the math right... :?
I wonder if it is related to the temperature reading 0 too.
Posted: Fri Sep 07, 2012 7:51 am
Ok, I went to a test controller and shorted the center pin with the GND pin on the temperature probe connector and rebooted the controller manually.
I started getting errors on pH too.
I think you got a bad probe?
What happens if you remove it?
Posted: Fri Sep 07, 2012 11:41 am
by Bryan
Hi Roberto:
I know the probe is good, because it works fine on teh APEX, used 2 probes same thing. Same thing if BNC shorted. i am beginning to think it is a programming issue with Atmel Studio, too much of a coincidence that T!-3 both show error as well.
Posted: Mon Sep 24, 2012 3:24 am
by Bryan
Hi Roberto:
Problem solved, helps if R29 was attached :lol: :oops: :oops: I removed it from the board last year to do some tests as I was having issues with multiple probes and forgot to resolder it back on.
Strange how it would affect the PH as well, completely different circuits and one is analog and digital. Don't share the same code at all do they.??
Cheers
