My almost completed pde
- Contact:
Re: My almost completed pde
I'm working on it right now. I think I have some improvements made. The menu should work on all screens. I'm also glancing through other code as well. I will post the code later when I have it at what I think is a workable state.JNieuwenhuizen wrote:Can anyone help me?
- Contact:
Ok. Attached is the code file. It has a CPP extension (forum won't let me post INO files for some reason). So you will have to rename it to .INO.
I made some big changes to the file. Here's what I did:
NOTE: I have not tested or compiled any of this code. I do not have a RA+ to test out on. I also have not loaded it into Arduino to see how it compiles either. Everything should work, but you will want to test to confirm it.
- Moved screen drawing to DrawCustomMain() - All screens will be drawn with this function. This ensures that the menu will be displayed properly. It also calls the ReefAngel.Refresh() function so you don't have to manually do it. Plus, it's entire reason for existence for drawing the custom main screens. These changes would most likely benefit the other people using the multiple screens.
- I left DrawCustomGraph() empty so it will work properly. The graph is drawn every time through with the standard / default main screen. This may be overkill, but you will have to test it. It should work just fine since it's how you were doing it before.
- I removed the InternalMemory writing during the RF Slave mode assignments. They don't appear to be needed at all, so why waste time updating them if they aren't needed.
- I added an override for your RF modes. The flag is called fOverrideRF. Vortech RF Mode cycling should work now. When you use the menu entry to cycle through the RF Modes, it overrides your current RF mode. Once you cycle through all the modes in the menu, normal operations should restore. You will want to test this out to confirm. There may be a slight instance where it goes to Constant mode first before resuming the normal mode. If it does that, then we will have to modify / update the function differently. Not a big deal to do now that I have a better idea of what's going on.
- The RF Modes from the menu are going to use the InternalMemory values for the Speed and Duration. If you want a specific Speed and Duration for each mode, that can be added in without a problem. I didn't add it in because I didn't know what it should be.
- Contact:
i will later tonight when i get home.rimai wrote:I made a change to the server. Can you try upload ino now?
- Contact:
It works just fine now.rimai wrote:I made a change to the server. Can you try upload ino now?
- JNieuwenhuizen
Thank You! Its much appreciated.
I had to change 1 or 2 small things, but it compiles now. I will test and give you feedback.
Again, thank you - i know you had to use some of your time on this.
Do you recommend any spesific internal memory settings for this pde?
- JNieuwenhuizen
HI.
I have uploaded the code and everything works, except for the Vortech modes, it changes for a fraction of a second, and the back to daytime functions.
The menus and main screens work 100%.
- Contact:
Hmmm....I will have to look at it some more then. Could you attach your INO file that you used (with your minor changes)? This way I can work with what you have.JNieuwenhuizen wrote: I have uploaded the code and everything works, except for the Vortech modes, it changes for a fraction of a second, and the back to daytime functions.
Good.JNieuwenhuizen wrote:The menus and main screens work 100%.
I was looking at the code and I think you need to move this out of the menu function:
I needs to be moved here:
Try that and let us know if it works.
ReefAngel.RF.SetMode(vtechmode, InternalMemory.RFSpeed_read(), InternalMemory.RFDuration_read());
if ( ! fOverrideRF )
- JNieuwenhuizen
Hi Roberto.
I have had no change to have a look at this, will do sometime today or tommorow.
For anyone else interrested, I have posted the code.
I have to split it into 2 posts, as its big.
Does the "bool fOverrideRF = false;" not need to be "boolean fOverrideRF = false;"
First Half :
First Half :
#include <avr/pgmspace.h>>
//-------------------------------------------------------------------------- Screen set-up ---------------------------------------------------------------------------------
#define NumScreens 7
int ScreenID=0;
//---------------------------------------------------------------------------- PWM Cloud -----------------------------------------------------------------------------------
boolean ForceCloud=false;
boolean ForceLightning=false;
//--------------------------------------------------------------------------- PWM Channels ----------------------------------------------------------------------------------
#define LEDWhiteBlue 0
#define LEDWhiteBlue1 1
#define LEDWhiteBlue2 2
#define LEDWhiteBlue3 3
#define MixedLED 4
#define LEDMoonlights 5
//--------------------------------------------------------------------- Start of Global Variables ---------------------------------------------------------------------------
byte ChannelValue[]=
0,0,0,0,0,0
byte SeasonsVar[]=
0,0,0,0,0,0
byte MoonPWMValue;
byte vtechmode = 0;
byte DayAge;
byte ThisPhase;
int JulianDate(int,int,int);
double MoonAge(int,int,int);
byte MoonState();
boolean bFeeding=false;
byte x,y;
int maxTemp=0;
int minTemp=2000;
int maxPH=600;
int minPH=900;
int v;
int moonlight=0;
long calcSec(long,long);
long calcTime(long,long);
short Ndays;
int rhour = 0, rmin = 0, shour = 0, smin = 0;
byte TempRelay =15;
byte TempRelay2=15;
byte cloudduration=0;
int cloudstart=0;
//----------------------------------------------------------------------- Custom Menu Code ----------------------------------------------------------------------------------
prog_char menu1_label[] PROGMEM = "Food!!";
prog_char menu2_label[] PROGMEM = "Cleanup";
prog_char menu4_label[] PROGMEM = "Force Storm";
prog_char menu6_label[] PROGMEM = "Salty Calibration";
prog_char menu7_label[] PROGMEM = "Vortech Modes";
prog_char menu8_label[] PROGMEM = "Sump On";
prog_char menu9_label[] PROGMEM = "Sumo Off";
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ReefAngel.ATOClear();
void MenuEntry4()
ForceCloud=true;
ForceLightning=true;
ReefAngel.DisplayedMenu=RETURN_MAIN_MODE;
void MenuEntry5()
ReefAngel.SetupCalibratePH();
void MenuEntry6()
ReefAngel.SetupCalibrateSalinity();
void MenuEntry7()
// TODO complete this function
Need to have an override variable inside the loop that forces a specific mode whenever
the menu is toggled. This should mimic the PWM override.
Cycle through the modes.
Use the Internal Memory values OR create a switch statement that has default values
for Speed and Duration based on the modes being switched to.
Once at the end of the modes,
return to constant mode (begining)
resume normal operations
fOverrideRF = true;
vtechmode++;
if ( vtechmode == 7 ) vtechmode = 9;
if ( vtechmode > 9 ) { vtechmode = 0; fOverrideRF = false; }
// 1st parameter is Mode, 2nd is speed, 3rd is duration
void MenuEntry8()
ReefAngel.Relay.RelayMaskOn = ReefAngel.LightsOnPorts;
#ifdef RelayExp
for ( byte i = 0; i < MAX_RELAY_EXPANSION_MODULES; i++ )
ReefAngel.Relay.RelayMaskOnE[i] = ReefAngel.LightsOnPortsE[i];
#endif // RelayExp
ReefAngel.Relay.Write();
void MenuEntry9()
ReefAngel.Relay.RelayMaskOn = 0;
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE[i] = 0;
#endif // RelayExp
//------------------------------------------------------------------------- Grouped Menu Entries ----------------------------------------------------------------------------
PROGMEM const char *menu_items[] =
menu4_label, menu5_label, menu6_label,
menu7_label,menu8_label,menu9_label
//------------------------------------------------------------------------------- Custom Main -------------------------------------------------------------------------------
void DrawCircleOutline(byte x, byte y, byte radius, byte bordercolor);
void FillCircle(byte x, byte y, byte radius, byte fillcolor);
void DrawCircleOutletBox(byte x, byte y, byte RelayData, bool reverse = false);
//-------------------------------------------------------------------------- Analog Clock constants -------------------------------------------------------------------------
const float pi = 3.141592653;
byte clock_center_x = 65;
byte clock_center_y = 65;
byte clock_radius = 55;
byte secondhand_radius = 33;
float secondangle;
byte secondend_x;
byte secondend_y;
float minuteangle;
float hourangle;
//--------------------------------------------------------------------------- Analog Clock Structure ------------------------------------------------------------------------
int minutebase_radius = 3;
int minutehand_radius = 33;
int hourbase_radius = 3;
int hourhand_radius = 25;
int seconds_hand_x, seconds_hand_y, minutes_hand_x, minutes_hand_y, hours_hand_x, hours_hand_y;
int hours_hand_base_x, hours_hand_base_y, hours_hand_base_x1, hours_hand_base_y1;
int minutes_hand_base_x, minutes_hand_base_y, minutes_hand_base_x1, minutes_hand_base_y1;
int minutebase_x, minutebase_y, minutebase_x1, minutebase_y1;
int minuteend_x, minuteend_y;
int hourbase_x, hourbase_y, hourbase_x1, hourbase_y1;
int hourend_x, hourend_y;
float minfloat;
//--------------------------------------------------------------------------------Time Stamp --------------------------------------------------------------------------------
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
//------------------------------------------------------------------------------ Draw Minutes Hand --------------------------------------------------------------------------
void draw_minute(int color)
Drawline(minutebase_x, minutebase_y, minutebase_x1, minutebase_y1, color);
Drawline(minutebase_x, minutebase_y, minuteend_x, minuteend_y, color);
Drawline(minutebase_x1, minutebase_y1, minuteend_x, minuteend_y, color);
//--------------------------------------------------------------------------- Draw Hour Hand --------------------------------------------------------------------------------
void draw_hour(int color)
Drawline(hourbase_x, hourbase_y, hourbase_x1, hourbase_y1, color);
Drawline(hourbase_x, hourbase_y, hourend_x, hourend_y, color);
Drawline(hourbase_x1, hourbase_y1, hourend_x, hourend_y, color);
//------------------------------------------------------------------------------ Draw Line ----------------------------------------------------------------------------------
void Drawline (int x0, int y0, int x1, int y1, int color)
int dy = y1 - y0;
int dx = x1 - x0;
int stepx, stepy;
if (dy < 0)
dy = -dy;
stepy = -1;
stepy = 1;
if (dx < 0)
dx = -dx;
stepx = -1;
stepx = 1;
dy <<= 1; // dy is now 2*dy
dx <<= 1; // dx is now 2*dx
ReefAngel.LCD.PutPixel(color, x0, y0);
if (dx > dy)
int fraction = dy - (dx >> 1); // same as 2*dy - dx
while (x0 != x1)
if (fraction >= 0)
y0 += stepy;
fraction -= dx; // same as fraction -= 2*dx
x0 += stepx;
fraction += dy; // same as fraction -= 2*dy
int fraction = dx - (dy >> 1);
while (y0 != y1)
if (fraction >= 0)
x0 += stepx;
fraction -= dy;
y0 += stepy;
fraction += dx;
//------------------------------------------------------------------------------ Draw Time ----------------------------------------------------------------------------------
void DrawTime(byte x, byte y, byte FGcolor, byte BGcolor, time_t ts)
char text[13];
char temp[]=" ";
strcpy(text,"");
itoa(hourFormat12(ts),temp,10);
if (temp[1]==0) strcat(text,"0");
strcat(text,temp);
strcat(text,":");
itoa(minute(ts),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(second(ts),temp,10);
strcat(text,temp);
if (isAM(ts))
strcat(text," AM");
strcat(text," PM");
ReefAngel.LCD.DrawText(FGcolor, BGcolor, x, y, text);
//------------------------------------------------------------------------------ Draw Circle --------------------------------------------------------------------------------
void DrawCircle(int a, int b, int r, byte color)
int f = 1 - r;
int ddF_x = 1;
int ddF_y = -2 * r;
int x = 0;
int y = r;
ReefAngel.LCD.PutPixel(color, a, b+r);
ReefAngel.LCD.PutPixel(color ,a, b-r);
ReefAngel.LCD.PutPixel(color, a+r, b);
ReefAngel.LCD.PutPixel(color, a-r, b);
while (x<y)
if (f >= 0)
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
ReefAngel.LCD.PutPixel(color, a + x, b + y);
ReefAngel.LCD.PutPixel(color, a - x, b + y);
ReefAngel.LCD.PutPixel(color, a + x, b - y);
ReefAngel.LCD.PutPixel(color, a - x, b - y);
ReefAngel.LCD.PutPixel(color, a + y, b + x);
ReefAngel.LCD.PutPixel(color, a - y, b + x);
ReefAngel.LCD.PutPixel(color, a + y, b - x);
ReefAngel.LCD.PutPixel(color, a - y, b - x);
//------------------------------------------------------------------------------ Draw Weekly ------------------------------------------------------------------------------
void DrawWeeklyAvg (byte hr, int sensor, byte color, byte x, byte y, byte z)
const int numReadings = 7;
int dailyread;
int readings[numReadings]; // the readings from the analog input
int index = 0; // the index of the current reading
int total = 0; // the running total
int average = 0; // the average
if (hour()==hr && minute()==0 && second()==0)
dailyread=sensor;
total= total - readings[index]; // subtract the last reading:
readings[index] = dailyread; // read from the sensor:
total= total + readings[index]; // add the reading to the total:
index = index + 1; // advance to the next position in the array:
if (index >= numReadings) // if we're at the end of the array...
index = 0; // ...wrap around to the beginning:
average = total / numReadings; // calculate the average:
delay (1000);
ReefAngel.LCD.DrawSingleMonitor(average, color, x, y, z);
//------------------------------------------------------------------------------ Draw Daily ---------------------------------------------------------------------------------
void DrawDailyAvg (int sensor, byte color, byte x, byte y, byte z)
const int numReadings = 24;
int dailyread;
if (minute()==0 && second()==0)
dailyread=sensor;
delay (1000);
// Refresh is called at start of ShowInterface.
// ShowInterface calls DrawCustomMain
switch (ScreenID)
//---------------------------------------------------------------------------- Screen Code 1--------------------------------------------------------------------------------
case 0:
//Top Banner
ReefAngel.LCD.DrawLargeText(COLOR_WHITE, COLOR_CORNFLOWERBLUE, 0, 1, " Drop Reef Tank ", Font8x8); //Top Banner
// Display T1 Header Text
ReefAngel.LCD.DrawLargeText(COLOR_STEELBLUE,255,5,15,"Sump Temp", Font8x8);
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 10, 25, 50, 60);
if (ReefAngel.Params.Temp[T1_PROBE]>270) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 10, 25, text);
else if (ReefAngel.Params.Temp[T1_PROBE]>270) ReefAngel.LCD.DrawHugeNumbers(COLOR_ORANGE, 255, 10, 25, text);
else ReefAngel.LCD.DrawHugeNumbers(COLOR_MIDNIGHTBLUE, 255, 10, 25, text);
// Display the T2 Header Text
ReefAngel.LCD.DrawLargeText(0,255,5,45,"Room Temp", Font8x8);
// Display the T2 Temp Value
ReefAngel.LCD.Clear(255, 90, 50, 132, 60);
ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 90, 45, text, Num8x8);
// Display pH Header Text
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,95,15,"pH", Font8x8);
// Display pH Value
ConvertNumToString(text, ReefAngel.Params.PH, 100); // check code
ReefAngel.LCD.Clear(0, 65, 62 , 65, 62);
if (ReefAngel.Params.PH>840 || ReefAngel.Params.PH<790) ReefAngel.LCD.DrawLargeText(COLOR_RED, 255, 85, 25, text, Num8x8);
else if (ReefAngel.Params.PH>830 || ReefAngel.Params.PH<800) ReefAngel.LCD.DrawLargeText(COLOR_ORANGE, 255, 85, 25, text, Num8x8);
else ReefAngel.LCD.DrawLargeText(COLOR_MIDNIGHTBLUE, 255, 85, 25, text, Num8x8);
// Display Vortech Mode
ReefAngel.LCD.DrawLargeText(0,255,5,55,"Vortech", Font8x8);
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 66, 60, 132, 70);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255, 66, 55,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 66, 55,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255, 80, 55,"RCM");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255, 80, 55,"Short");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255, 66, 55,"Long");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 80, 55,"NTM");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255, 80, 55,"TSM");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_GRAY,255, 80, 55,"Night");
// Display Salinity
ReefAngel.LCD.DrawLargeText(0,255,64,114,"Salinity", Font8x8);
// Display Salinity Value
ReefAngel.LCD.Clear(255, 82, 85, 65, 95);
ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 85, 122, text, Num8x8);
//Start Moon Phase,Cloud or Storm Display
SeasonsVar[0]=ChannelValue[LEDWhiteBlue];
SeasonsVar[1]=rhour;
SeasonsVar[2]=rmin;
SeasonsVar[3]=shour;
SeasonsVar[4]=smin;
SeasonsVar[5]=cloudstart/60;
SeasonsVar[6]=cloudstart%60;
SeasonsVar[7]=cloudduration;
SeasonsVar[8]=lightningchance;
SeasonsVar[9]=ChannelValue[LEDWhiteBlue1];
SeasonsVar[10]=ChannelValue[LEDWhiteBlue2];
SeasonsVar[11]=ChannelValue[LEDWhiteBlue3];
SeasonsVar[12]=ChannelValue[MixedLED];
SeasonsVar[13]=ChannelValue[LEDMoonlights];
if (SeasonsVar[13] > 0)//if moon phase is active display state and pwm %
DayAge = MoonAge(day(), month(), year());
MoonState(DayAge);
char* ThisPhaseLabel[]= {"New","Waxing C","First Q","Waxing G","Full","Waning G","Last Q","Waning C"};
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,105,ThisPhaseLabel[ThisPhase]);
else if (SeasonsVar[5] > 0) //or if there is a cloud display clouds instead
if (SeasonsVar[8] > 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,60,85, "Storm"); //decide between dislaying storm or cloud based on lightningchance
else ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,95,85,"Cloud");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,60,95, SeasonsVar[5]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,94, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,80,95, SeasonsVar[6]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,93,95,"Lnt");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,113,95, SeasonsVar[7]);
else if (hour() >8 || hour() <14 && SeasonsVar[5,6,7] <= 0)
ReefAngel.LCD.DrawLargeText(COLOR_ORANGERED,255,3,65, "Sunrise",Font8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,3,75, SeasonsVar[0]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,24,75, SeasonsVar[9]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,41,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,45,75, SeasonsVar[10]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,66,75, "|");
else if (hour() >14 || hour() <22 && SeasonsVar[5,6,7] <=0)
ReefAngel.LCD.DrawLargeText(COLOR_ORANGE,255,75,65, "Sunset",Font8x8);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,75, SeasonsVar[0]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,87,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,91,75, SeasonsVar[9]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,108,74, ":");
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,112,75, SeasonsVar[10]);
//End Display Moon Phase Display
// Display Main and Expansion Relay Box
TempRelay = ReefAngel.Relay.RelayData;
ReefAngel.LCD.DrawCircleOutletBox(10,90, TempRelay);
TempRelay2 = ReefAngel.Relay.RelayDataE[0];
TempRelay2 &= ReefAngel.Relay.RelayMaskOffE[0];
TempRelay2 |= ReefAngel.Relay.RelayMaskOnE[0];
ReefAngel.LCD.DrawCircleOutletBox(40,90, TempRelay2);
break;
//---------------------------------------------------------------------------- Screen Code 2---------------------------------------------------------------------------------
case 1: //Temperature detail screen with sump and room temp, 24 hr. max/min, time stamps, and graph
ReefAngel.LCD.DrawLargeText(0,255,10,15,"Temp Details", Font8x8);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,33,"Sump:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 36, 33, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,43,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 43, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,43,"at");
DrawTime(60,43,0, COLOR_WHITE,tsmax);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,53,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 53, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,53,"at");
DrawTime(60,53,0,COLOR_WHITE, tsmin);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,63,"Range:");
ReefAngel.LCD.DrawSingleMonitor((maxTemp-minTemp), COLOR_BLACK, 46, 63, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,69,63,"Degrees C");
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,73,"Avg:");
DrawDailyAvg(ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 43, 73, 1);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,83,"WeeklyAvg:");
DrawWeeklyAvg(12,ReefAngel.Params.Temp[T1_PROBE], COLOR_BLACK, 66, 83, 1);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor, 86,83,"at noon");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor, 5 ,93,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 36, 93, 10);
break;
//---------------------------------------------------------------------------- Screen Code 3---------------------------------------------------------------------------------
case 2: //pH details
ReefAngel.LCD.DrawLargeText(0,255,20,15,"pH Details", Font8x8);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,33,"pH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, COLOR_BLACK, 36, 33, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,43,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxPH, 0, 23, 43, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,48,43,"at");
DrawTime(60,43,0, COLOR_WHITE,PHmax);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,53,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minPH, 0, 23, 53, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,48,53,"at");
DrawTime(60,53,0,COLOR_WHITE, PHmin);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,63,"Range:");
ReefAngel.LCD.DrawSingleMonitor((maxPH-minPH), COLOR_BLACK, 46, 63, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,73,"Avg:");
DrawDailyAvg(ReefAngel.Params.PH, COLOR_BLACK, 43, 73, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,83,"WeeklyAvg:");
DrawWeeklyAvg(12,ReefAngel.Params.PH, COLOR_BLACK, 66, 83, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 86,83,"at noon");
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5,93,"WeeklyAvg:");
DrawWeeklyAvg(0,ReefAngel.Params.PH, COLOR_BLACK, 66, 93, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 86,93,"at midnt");
break;
//---------------------------------------------------------------------------- Screen Code 4---------------------------------------------------------------------------------
case 3: //relay box key
ReefAngel.LCD.DrawCircleOutletBox(56,46,TempRelay);
ReefAngel.LCD.DrawLargeText(0,255,27,20,"RelayBox 1", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,3,44,"LDFan", Font8x8); //1
// ReefAngel.LCD.DrawLargeText(0,255,7,54,"ATU", Font8x8); //3
ReefAngel.LCD.DrawLargeText(0,255,7,64,"ATU", Font8x8); //5
ReefAngel.LCD.DrawLargeText(0,255,7,74,"Salty", Font8x8); //7
ReefAngel.LCD.DrawLargeText(0,255,75,44,"Skimer", Font8x8); //2
ReefAngel.LCD.DrawLargeText(0,255,75,54,"Reactr", Font8x8); //4
ReefAngel.LCD.DrawLargeText(0,255,75,64,"Heatr", Font8x8); //6
ReefAngel.LCD.DrawLargeText(0,255,75,74,"Relay", Font8x8); //8
break;
//---------------------------------------------------------------------------- Screen Code 5---------------------------------------------------------------------------------
case 4: //relay box key
ReefAngel.Refresh();
ReefAngel.LCD.DrawCircleOutletBox(56,46,TempRelay2);
ReefAngel.LCD.DrawLargeText(0,255,27,20,"RelayBox 2", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,7,44,"VTech", Font8x8);//1
ReefAngel.LCD.DrawLargeText(0,255,3,54,"Return", Font8x8);//3
// ReefAngel.LCD.DrawLargeText(0,255,7,64,"Day1", Font8x8);//5
// ReefAngel.LCD.DrawLargeText(0,255,7,74,"Day3", Font8x8);//7
ReefAngel.LCD.DrawLargeText(0,255,75,44,"VTech", Font8x8);//2
ReefAngel.LCD.DrawLargeText(0,255,75,54,"SumpL", Font8x8);//4
// ReefAngel.LCD.DrawLargeText(0,255,75,64,"Day2", Font8x8);//6
ReefAngel.LCD.DrawLargeText(0,255,75,74,"LED", Font8x8);//8
break;
//---------------------------------------------------------------------------- Screen Code 6---------------------------------------------------------------------------------
case 5: //setclock
// Analog clock is modified from the original source by Jeff Miller
// Author: Jeff Miller http://arduinofun.blogspot.com/
// Frame
DrawCircle(clock_center_x, clock_center_y, clock_radius, COLOR_CORNFLOWERBLUE);
DrawCircle(clock_center_x, clock_center_y, clock_radius - 1, COLOR_CORNFLOWERBLUE);
DrawCircle(clock_center_x, clock_center_y, clock_radius - 2, COLOR_CORNFLOWERBLUE);
// Face Tick Marks (x = r cos theta, y = r sin theta)
for (byte r=0; r < 12; r++)
float angle = (2 * pi / 12)*r;
int tick_x_out = (clock_radius - 8) * cos (angle) + clock_center_x;
int tick_y_out = (clock_radius - 8) * sin (angle) + clock_center_y;
int tick_x_in = clock_radius *.72 * cos (angle) + clock_center_x;
int tick_y_in = clock_radius * .72 * sin (angle) + clock_center_y;
Drawline(tick_x_in, tick_y_in, tick_x_out, tick_y_out, COLOR_CORNFLOWERBLUE);
// Face Characters
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 8,106," 6", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 8, 25,"12", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x + 34,clock_center_y," 3", Font8x8);
ReefAngel.LCD.DrawLargeText(0,255,clock_center_x - 50, clock_center_y - 4,"9 ", Font8x8);
// Draw Seconds Hand
secondangle = (2 * pi / 60) * second();
if (second() > 15)
secondangle = secondangle -1.57;
secondangle = secondangle +4.71;
Drawline(clock_center_x, clock_center_y, secondend_x, secondend_y, WHITE);
secondend_x = secondhand_radius * cos (secondangle) + clock_center_x;
secondend_y = secondhand_radius * sin (secondangle) + clock_center_y;
Drawline(clock_center_x, clock_center_y, secondend_x, secondend_y, BLACK);
// Redraw minutes hand since the section closest to the center gets erased by the seconds hand
draw_minute(BLACK);
// Redraw hour hand
draw_hour(BLACK);
// Draw Minutes Hand
minuteangle = (2 * pi / 60) * minute();
if (minute() > 15)
minuteangle = minuteangle -1.57;
minuteangle = minuteangle +4.71;
// Erase old minutes Hand
draw_minute(WHITE);
// Calculate Minute Hand Base
minutebase_x = minutebase_radius * cos (minuteangle - pi/2) + clock_center_x;
minutebase_y = minutebase_radius * sin (minuteangle - pi/2) + clock_center_y;
minutebase_x1 = minutebase_radius * cos (minuteangle + pi/2) + clock_center_x;
minutebase_y1 = minutebase_radius * sin (minuteangle + pi/2) + clock_center_y;
// Calculate Minute Hand Point
minuteend_x = minutehand_radius * cos (minuteangle) + clock_center_x;
minuteend_y = minutehand_radius * sin (minuteangle) + clock_center_y;
// Draw new minutes Hand
draw_minute(BLACK);
// Redraw hour hand
draw_hour(BLACK);
// Draw Hour Hand
minfloat = minute(); // Convert minute short to float
hourangle = (2 * pi / 12) * ((hourFormat12()) + (minfloat/60)); // Find angle for hour hand
hourangle = hourangle -1.57;
// Erase old Hour Hand
draw_hour(WHITE);
// Calculate hour Hand Base
hourbase_x = hourbase_radius * cos (hourangle - pi/2) + clock_center_x;
hourbase_y = hourbase_radius * sin (hourangle - pi/2) + clock_center_y;
hourbase_x1 = hourbase_radius * cos (hourangle + pi/2) + clock_center_x;
hourbase_y1 = hourbase_radius * sin (hourangle + pi/2) + clock_center_y;
// Calculate hour Hand Point
hourend_x = hourhand_radius * cos (hourangle) + clock_center_x;
hourend_y = hourhand_radius * sin (hourangle) + clock_center_y;
// Draw new hours Hand
draw_hour(BLACK);
ReefAngel.LCD.DrawDate(5,121);
break;
//---------------------------------------------------------------------------- Screen Code 7---------------------------------------------------------------------------------
case 6: // Vortech Setup
ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
ReefAngel.RF.SetMode(Slave_Start,0,0);
if (ReefAngel.Joystick.IsButtonPressed())
ReefAngel.RF.SetMode(Slave_Stop,0,0);
ReefAngel.LCD.DrawText(0,255,50,60,"Done");
break;
Last edited by JNieuwenhuizen on Sat May 12, 2012 9:08 am, edited 1 time in total.
- JNieuwenhuizen
Second Half:
All I am still having a problem with(except vortech menu) is the Sunrise, SunSet, Storm, Lightning and MoonCycle on Case 0 screen, it should only display either sunrise if its early day, sunset if its late afternoon, storm is there is a storm, lightning if there is a strike on the way, or storm and lightning when both is due or current moon cycle.
I think my IF statement are wrong.
//------------------------------------------------------------------------------ Begin Setup --------------------------------------------------------------------------------
ReefAngel.Timer[LCD_TIMER].SetInterval(180);
ReefAngel.Timer[LCD_TIMER].Start(); // start timer
ReefAngel.SetTemperatureUnit(1);
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port6Bit | Box1_Port1 | Box1_Port2;
ReefAngel.LightsOnPorts = Box1_Port4;
//------------------------------------------------------------------------- Ports that are always on ------------------------------------------------------------------------
ReefAngel.Relay.On(Port1);
ReefAngel.Relay.On(Port4);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port3);
ReefAngel.Relay.On(Box1_Port8);
CheckCloud();
//--------------------------------------------------------------------------- Specific Functions ----------------------------------------------------------------------------
ReefAngel.Relay.DelayedOn(Port2, 2);
ReefAngel.Relay.DelayedOn(Box1_Port1, 2);
ReefAngel.Relay.DelayedOn(Box1_Port2, 2);
ReefAngel.StandardATO(Port5);
ReefAngel.StandardHeater(Port6);
ReefAngel.MoonLights(Box1_Port4);//SumpLight
ReefAngel.Portal("JNieuwenhuizen","Evandre1");
//---------------------------------------------------------------------------- PWM Channel Set -----------------------------------------------------------------------------
ReefAngel.PWM.SetChannel(0,ChannelValue[LEDWhiteBlue]);
ReefAngel.PWM.SetChannel(1,ChannelValue[LEDWhiteBlue1]);
ReefAngel.PWM.SetChannel(2,ChannelValue[LEDWhiteBlue2]);
ReefAngel.PWM.SetChannel(3,ChannelValue[LEDWhiteBlue3]);
ReefAngel.PWM.SetChannel(4,ChannelValue[MixedLED]);
ReefAngel.PWM.SetChannel(5,ChannelValue[LEDMoonlights]);
//------------------------------------------------------------------------------ Multiple Screens ----------------------------------------------------------------------------
setTime(hour(),minute(),second(),day(),month(),year());
// update the min & max temps and min & max ph
if (now()%86400==0)
minTemp=ReefAngel.Params.Temp[T1_PROBE];
maxTemp=ReefAngel.Params.Temp[T1_PROBE];
minPH=ReefAngel.Params.PH;
maxPH=ReefAngel.Params.PH;
if (ReefAngel.Params.Temp[T1_PROBE]<minTemp)
tsmin=now();
if (ReefAngel.Params.Temp[T1_PROBE]>maxTemp)
tsmax=now();
if (ReefAngel.Params.PH<minPH)
PHmin=now();
if (ReefAngel.Params.PH>maxPH)
PHmax=now();
if (ReefAngel.Joystick.IsLeft())
ScreenID--;
if (ReefAngel.Joystick.IsRight())
ScreenID++;
if (ScreenID<0) ScreenID=NumScreens;
//------------------------------------------------------------------------- PWM Channels ------------------------------------------------------------------------------------
if (SeasonsVar[13]=MoonPWMValue);
MoonPWMValue=MoonPhase();
if (hour()>=22 || hour()<=8)
MoonPWMValue=PWMSlope(22,00,8,00,1,MoonPhase(),10,1);
if (SeasonsVar[0]>=1) MoonPWMValue=0;
ReefAngel.PWM.SetChannel(5,MoonPWMValue);
ReefAngel.PWM.Expansion(LEDWhiteBlue,int(ChannelValue[LEDWhiteBlue]));
ReefAngel.PWM.Expansion(LEDWhiteBlue1,int(ChannelValue[LEDWhiteBlue1]));
ReefAngel.PWM.Expansion(LEDWhiteBlue2,int(ChannelValue[LEDWhiteBlue2]));
ReefAngel.PWM.Expansion(LEDWhiteBlue3,int(ChannelValue[LEDWhiteBlue3]));
ReefAngel.PWM.Expansion(MixedLED,int(ChannelValue[MixedLED]));
ReefAngel.PWM.Expansion(LEDMoonlights,int(ChannelValue[LEDMoonlights]));
//------------------------------------------------------------------- End PWM Expansion Code for Slope ---------------------------------------------------------------------
//------------------------------------------------------------------ Start Time-of-Day Based Functions ----------------------------------------------------------------------
//~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ These are the mode numbers for the RF Expansion Module for reference ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
// RF Override
// RF Mode is not being overridden, AKA Normal operation mode
//----------------------------------------------------------------- Start RF Daytime Control ------------------------------------------------------------------------------
if (hour() >=8 && hour() <= 14)
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,80,7);
vtechmode = Smart_NTM;
if (hour() >=14 && hour() <= 22)
ReefAngel.RF.SetMode(Random2,60,7);
vtechmode = Random2;
//--------------------------------------------------------------- Start RF Nightmode Control -----------------------------------------------------------------------------
if (hour()>=22 || hour()<8) // Defining "Nightmode" hours for VorTech = between 10 PM and 8 AM
vtechmode = Night;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
} // if fOverrideRF
//-------------------------------------------------- Random Cloud/Thunderstorm effects function -----------------------------------------------------------------------------
//------------------------------------------------------- From Roberto - THANKS ROBERTO! ------------------------------------------------------------------------------------
void CheckCloud()
#define Clouds_Every_5_Days 1
#define Cloud_Chance_per_Day 25
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 3
#define Max_Clouds_per_Day 6
#define Start_Cloud_After NumMins(12,00)
// In this example, end could before 4:30pm
#define End_Cloud_Before NumMins(18,0)
#define Lightning_Change_per_Cloud 25
// Channels used by the actinic LEDs on the PWM Expansion module
// These channels will not be dimmed when the cloud effect is triggered
// Number is a binary form. B001100 means channel 2 and 3 are used for actinics
#define Actinic_Channels B000000
// Channels used by the daylight LEDs on the PWM Expansion module
// These channels will be used for the spike when lightning effect is triggered
// Number is a binary form. B000011 means channel 0 and 1 are used for daylights
#define Daylight_Channels B001000
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
//fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(26);
if ((day()%Clouds_Every_5_Days)!=0) cloudchance=0;
// If we have cloud today
if (cloudchance)
lightningchance=random(36);
if (cloudchance)
//is it time for cloud yet?
// let's go through all channels to pick which ones will be dimmed
for (int a=0; a<6; a++)
if (bitRead(Actinic_Channels,a)==0)
// this will slope down the channel from the current PWM to 0 within 3minutes.
// then it will stay at 0 for the duration of the cycle
// and finally slope up from 0 to PWM value within 3 minutes
// it is basically an inversed slope
ChannelValue[a]=ReversePWMSlope(cloudstart,cloudstart+cloudduration,ChannelValue[a],0,180);
for (int b=0; b<6; b++)
if (bitRead(Daylight_Channels,b)==1)
else lightningstatus=0;
if (lightningstatus) ChannelValue[b]=100;
else ChannelValue[b]=0;
//delay(10);
ChannelValue[b]=20;
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.RF.UseMemory=true;
lightningchance=random(100);
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
//----------------------------------------------------------------- End Cloud & Lighting ------------------------------------------------------------------------------------
//----------------------------------------------------------- Calculators for Seasons function ------------------------------------------------------------------------------
long calcSec(long hr, long minu) //if (hour()==hr && minute()==minu);
long totalseconds;
totalseconds= (hr*3600)+(minu*60);
return totalseconds;
long calcTime(long seconds1, long seconds2) //if (second()==seconds1 && second()==seconds2);
long timediff=abs(seconds1-seconds2);
return timediff;
void DayNumber(unsigned int y, unsigned int m, unsigned int d)
int days[]=
0,31,59,90,120,151,181,212,243,273,304,334
}; // Number of days at the beginning of the month in a not leap year.
//Start to calculate the number of day
if (m==1 || m==2)
Ndays = days[(m-1)] +d; //for any type of year, it calculate the number of days for January or february
} // Now, try to calculate for the other months
else if ((y % 4 == 0 && y % 100 != 0) || y % 400 == 0) //those are the conditions to have a leap year
Ndays = days[(m-1)]+d+1; // if leap year, calculate in the same way but increasing one day
else //if not a leap year, calculate in the normal way, such as January or February
Ndays = days[(m-1)]+d;
//End calculators
//Calculate Sunrise/set by date & predefined season & rise/set times
void Seasons()
//Set the hour you want the calculations of rise an set to be based on
int UserRiseHour = 8;
int UserSetHour = 22;
#define forceseasoncalculation
static byte ssn , ssnp = 0 , ssnpt ;
long stime, wstime, vstime, wrtime, rtime, vrtime;
int wrhour,wrmin,wrsec,wshour,wsmin,wssec,rsec,ssec,vrhour,vrmin,vrsec,vshour,vsmin,vssec;
int iDiffrise = 0;
int iDiffset = 0;
int risediffperday = 0;
int setdiffperday = 0;
int totalrise = 0;
int totalset = 0;
byte s=0;
int DaysPerYear;
//rise and set times set by hour and minute. there are 4 seasons however there are 8 highs & lows in rise and set throughout the year
//first spot is second half of winter starting jan 1st - DO NOT CHANGE
int risehour[8]= {UserRiseHour+1,UserRiseHour+1,UserRiseHour+1,UserRiseHour,UserRiseHour,UserRiseHour-1,UserRiseHour,UserRiseHour};/*{
7,7,7,6,6,5,6,6 };*/
int riseminute[8]=
00,30,00,30,00,30,00,30
int sethour[8] = {UserSetHour-2,UserSetHour-1,UserSetHour-1,UserSetHour,UserSetHour,UserSetHour,UserSetHour,UserSetHour-1};/*{
17,18,18,19,19,19,19,18 };*/
int setminute[8] =
30,00,30,00,00,30,00,00
if (hour()==0 && minute()==0 && second()==0) ssnp=0;
#ifdef forceseasoncalculation
if (ssnp==0)
#else
if (hour()==0 && minute()==0 && second()==1 && ssnp==0)
#endif
//leapyear or not to define DaysPerYear - DO NOT CHANGE
if (year()%4 == 0 && !(year()%100 == 0 && year()%400 != 0))
DaysPerYear=366;
DaysPerYear = 365;
//Call Day Number Calc to determin day ie december 31st on a non leap year is day 365 - DO NOT CHANGE
DayNumber(year(),month(),day());
//define days between beginning, middle and end of seasons high peaks - DO NOT CHANGE
int seasons[9] = {0,45,96,135,187,238,283,328,DaysPerYear};
//define season and array pulling variable - DO NOT CHANGE
for (s=0; seasons[s] < Ndays; s++) ssn = s+1, ssnpt = s+1, ssnp = s;
//set loop on array time pulling variable to go back to beginning instead of increasing array size - DO NOT CHANGE
if (ssn >= 7) ssn = 0;
//differece in seconds between two rise/set array times pulled - DO NOT CHANGE
long rise1 = calcSec(risehour[ssn],riseminute[ssn]);
long rise2 = calcSec(risehour[ssnp],riseminute[ssnp]);
iDiffrise = calcTime(rise1, rise2);
long set1 = calcSec(sethour[ssn],setminute[ssn]);
long set2 = calcSec(sethour[ssnp],setminute[ssnp]);
iDiffset = calcTime(set1,set2);
//calculate new sunrise/set difference from array value & last group of code - DO NOT CHANGE
risediffperday = iDiffrise/(seasons[ssnpt]-seasons[ssnp]);
totalrise = risediffperday*(Ndays - seasons[ssnp]);
setdiffperday = iDiffset/(seasons[ssnpt]-seasons[ssnp]);
totalset = setdiffperday*(Ndays - seasons[ssnp]);
//creating time in seconds for main sun rise/set number - DO NOT CHANGE
rtime=calcSec(risehour[ssnp],riseminute[ssnp]);
if (ssnp == 0 || ssnp == 2 || ssnp == 4 || ssnp == 6)
rtime -= totalrise;
rtime += totalrise;
stime=calcSec(sethour[ssnp],setminute[ssnp]);
if (ssnp == 1 || ssnp == 3 || ssnp == 5 || ssnp == 7)
stime -= totalset;
stime += totalset;
//These are the off set times, standard rtime and stime are for Royal Blues & Blues
// DO NOT CHANGE the operators in these equations ie +-
// The number is in seconds (1200) change this number to change the offset for each color
wrtime = rtime + 1200;
wstime = stime - 1200;
vrtime = rtime - 1200;
vstime = stime + 1200;
//turning seconds back to Hours:Minutes:Seconds
//Blues
rhour=rtime/3600;
rtime=rtime%3600;
rmin=rtime/60;
rtime=rtime%60;
rsec=rtime;
if(rsec > 30) rmin++;
shour=stime/3600;
stime=stime%3600;
smin=stime/60;
stime=stime%60;
ssec=stime;
if(ssec > 30) smin++;
//White
wrhour = wrtime/3600;
wrtime=wrtime%3600;
wrmin=wrtime/60;
wrtime=wrtime%60;
wrsec=wrtime;
if(wrsec>30) wrmin++;
wshour = wstime/3600;
wstime=wstime%3600;
wsmin=wstime/60;
wstime=wstime%60;
wssec=wstime;
if(wssec>30) wsmin++;
//Violet
vrhour = vrtime/3600;
vrtime=vrtime%3600;
vrmin=vrtime/60;
vrtime=vrtime%60;
vrsec=vrtime;
if(vrsec>30) vrmin++;
vshour = vstime/3600;
vstime=vstime%3600;
vsmin=vstime/60;
vstime=vstime%60;
vssec=vstime;
if(vssec>30) vsmin++;
//time for each active led channel to pull for sunrise - DO NOT CHANGE
int Sunrise[2]=
rhour,rmin
int Sunset[2]=
shour,smin
int whSunrise[2]=
wrhour,wrmin
int whSunset [2]=
wshour,wsmin
int vSunrise[2]=
vrhour,vrmin
int vSunset [2]=
vshour,vsmin
//This is the PWM Slope for each channel, each channel pulls an array value from above(hour,minute) to use, how you set them is up to you.
//Just always use a Rise hour in a Rise spot, always a set hour in a set spot ect ect
ChannelValue[LEDWhiteBlue]=PWMSlope(vSunrise[1],vSunrise[2],vSunset[1],vSunset[2],0,50,180,ChannelValue[LEDWhiteBlue]);
ChannelValue[LEDWhiteBlue1]=PWMSlope(whSunrise[1],whSunrise[2],whSunset[1],whSunset[2],0,50,180,ChannelValue[LEDWhiteBlue1]);
ChannelValue[LEDWhiteBlue2]=PWMSlope(Sunrise[1],Sunrise[2],Sunset[1],Sunset[2],0,50,180,ChannelValue[LEDWhiteBlue2]);
ChannelValue[LEDWhiteBlue3]=PWMSlope(Sunrise[1],Sunrise[2],Sunset[1],Sunset[2],0,50,180,ChannelValue[LEDWhiteBlue3]);
ChannelValue[MixedLED]=PWMSlope(Sunrise[1],Sunrise[2],whSunset[1],whSunset[2],0,50,180,ChannelValue[MixedLED]);
//return Sunrise, Sunset, whSunrise,whSunset,vSunrise,vSunset;
//------------------------------------------------------------------- End Seasons Calculation -------------------------------------------------------------------------------
int JulianDate(int d, int m, int y)
int mm, yy;
int k1, k2, k3;
int j;
yy = y - (int)((12 - m) / 10);
mm = m + 9;
if (mm >= 12)
mm = mm - 12;
k1 = (int)(365.25 * (yy + 4712));
k2 = (int)(30.6001 * mm + 0.5);
k3 = (int)((int)((yy / 100) + 49) * 0.75) - 38;
// 'j' for dates in Julian calendar:
j = k1 + k2 + d + 59;
if (j > 2299160)
// For Gregorian calendar:
j = j - k3; // 'j' is the Julian date at 12h UT (Universal Time)
return j;
double MoonAge(int d, int m, int y)
int j = JulianDate(d, m, y);
//Calculate the approximate phase of the moon
int ip = (j + 4.867) / 29.53059;
ip = ip - abs(ip);
//After several trials I've seen to add the following lines,
//which gave the result was not bad
if(ip < 0.5)
int ag = ip * 29.53059 + 29.53059 / 2;
int ag = ip * 29.53059 - 29.53059 / 2;
// Moon's age in days
byte ag = abs(ag) + 1;
return ag;
byte MoonState(byte D)
switch(D)
case 1:
0, 29;
ThisPhase = 0;
case 2:
1, 2, 3, 4, 5, 6;
ThisPhase = 1;
case 3:
7;
ThisPhase = 2;
case 4:
8, 9, 10, 11, 12, 13;
ThisPhase = 3;
case 5:
14;
ThisPhase = 4;
case 6:
15, 16, 17, 18, 19, 20, 21;
ThisPhase = 5;
case 7:
22;
ThisPhase = 6;
case 8:
23, 24, 25, 26, 27, 28;
ThisPhase = 7;
default:
return 0;
- JNieuwenhuizen
Ok
So I started from scratch here - the other code is a bit complex for me
This is my new pde
Only problem is my Reef Angel now freezes up ? any ideas
This is my new pde
int ScreenID=0;
#define LEDPWM0 0
#define LEDPWM1 1
#define LEDPWM2 2
#define LEDPWM3 3
#define LEDPWM4 4
#define LEDPWM5 5
byte ChannelValue[]={0,0,0,0,0,0};
byte PWMChannel[]={0,0,0,0,0,0};
byte MoonPWMValue;
byte vtechmode = 0;
byte DayAge;
byte ThisPhase;
char* ThisPhaseLabel[]={
"New","Waxing C","First Q","Waxing G","Full","Waning Gibbous","Last Q","Waning C"};
byte MoonState();
byte x,y;
int maxTemp=0;
int minTemp=2000;
int maxPH=600;
int minPH=900;
int moonlight=0;
byte TempRelay =15;
byte TempRelay2=15;
int cloudstart=0;
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
ForceCloud=true;
void MenuEntry5()
void MenuEntry6()
void MenuEntry7()
fOverrideRF = true;
vtechmode++;
void MenuEntry8()
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = ReefAngel.LightsOnPortsE;
#endif // RelayExp
void MenuEntry9()
#ifdef RelayExp
ReefAngel.Relay.RelayMaskOnE = 0;
#endif // RelayExp
float secondangle;
byte secondend_x;
byte secondend_y;
float minuteangle;
float hourangle;
float minfloat;
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
int dy = y1 - y0;
int dx = x1 - x0;
int stepx, stepy;
if (dy < 0)
dy = -dy;
stepy = -1;
stepy = 1;
if (dx < 0)
dx = -dx;
stepx = -1;
stepx = 1;
if (dx > dy)
while (x0 != x1)
if (fraction >= 0)
y0 += stepy;
x0 += stepx;
while (y0 != y1)
if (fraction >= 0)
x0 += stepx;
fraction -= dy;
y0 += stepy;
fraction += dx;
char text[13];
char temp[]=" ";
strcpy(text,"");
strcat(text,temp);
strcat(text,":");
strcat(text,temp);
strcat(text,":");
strcat(text,temp);
if (isAM(ts))
strcat(text," AM");
strcat(text," PM");
int f = 1 - r;
int ddF_x = 1;
int ddF_y = -2 * r;
int x = 0;
int y = r;
while (x<y)
if (f >= 0)
y--;
ddF_y += 2;
f += ddF_y;
x++;
ddF_x += 2;
f += ddF_x;
int dailyread;
dailyread=sensor;
delay (1000);
int dailyread;
dailyread=sensor;
delay (1000);
switch (ScreenID)
case 0:
//Top Banner
char text[7];
if (ReefAngel.Params.Temp[T1_PROBE]>290) ReefAngel.LCD.DrawHugeNumbers(COLOR_RED, 255, 10, 25, text);
// Display pH Value
//------------------------------------------------------------------ Display Vortech Mode ------------------------------------------------------------------------------------
//---------------------------------------------------------------- Display EcoSmart Mode Value -------------------------------------------------------------------------------
//------------------------------------------------------------------- Display Salinity ---------------------------------------------------------------------------------------
//----------------------------------------------------------------- Display Salinity Value -----------------------------------------------------------------------------------
//-----------------------------------------------------------Start Moon Phase,Cloud or Storm Display---------------------------------------------------------------------------
if (ReefAngel.PWM.ExpansionChannel[6] > 0);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,105,MoonPhaseLabel());
if (ReefAngel.PWM.ExpansionChannel[0] > 0 && (hour() < 14 ) )
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,3,75, ReefAngel.PWM.ExpansionChannel[0]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,24,75, ReefAngel.PWM.ExpansionChannel[1]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,45,75, ReefAngel.PWM.ExpansionChannel[2]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,70,75, ReefAngel.PWM.ExpansionChannel[3]);
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,91,75, ReefAngel.PWM.ExpansionChannel[4]);
else if (ReefAngel.PWM.ExpansionChannel[0] > 0 && (hour() > 14 ))
//---------------------------------------------------------- Display Main and Expansion Relay Box -----------------------------------------------------------------------------
break;
break;
break;
break;
break;
case 5: //setclock
// Frame
// Face Characters
if (second() > 15)
draw_minute(BLACK);
// Redraw hour hand
draw_hour(BLACK);
if (minute() > 15)
draw_minute(WHITE);
draw_minute(BLACK);
// Redraw hour hand
draw_hour(BLACK);
// Draw Hour Hand
draw_hour(WHITE);
draw_hour(BLACK);
break;
break;
CheckCloud();
ReefAngel.Portal("JNieuwenhuizen");
if (now()%86400==0)
tsmin=now();
tsmax=now();
PHmin=now();
PHmax=now();
ScreenID--;
ScreenID++;
//------------------------------------------------------------------------- Moon Cycle ------------------------------------------------------------------------------------
if (hour()==22 || hour()==6)
MoonPWMValue=PWMSlope(22,00,6,00,0,MoonPhase(),45,0);
if (ReefAngel.PWM.ExpansionChannel[4]) MoonPWMValue=0;
//--------------------------------------------------------------------------- End Moon Cycle --------------------------------------------------------------------------------
ReefAngel.PWM.SetChannel(0,PWMParabola(8,30,20,30,10,80,0));
ReefAngel.PWM.SetChannel(1,PWMParabola(9,0,21,0,15,80,0));
ReefAngel.PWM.SetChannel(2,PWMParabola(9,30,21,30,15,80,0));
ReefAngel.PWM.SetChannel(3,PWMParabola(10,0,22,0,15,80,0));
ReefAngel.PWM.SetChannel(4,PWMParabola(10,0,22,0,15,100,0));
for (int a=0;a<6;a++)
ReefAngel.PWM.Expansion(a,int(2.55*PWMChannel[a]));
//#define Night 9
//#define None 99
// RF Override
if (hour() >8 && hour() < 14)
else if (hour() >14 && hour() < 22)
else if (hour()>=22 || hour()<8) // Defining "Nightmode" hours for VorTech = between 10 PM and 8 AM
vtechmode = Night;
} // if fOverrideRF
void CheckCloud()
// could happen.
#else
#endif
if (cloudchance)
if (cloudchance)
if (lightningstatus) ChannelValue=100;
else ChannelValue=0;
//delay(10);
ChannelValue=20;
cloudindex++;
cstart*=60;
cend*=60;
char* MoonPhaseLabel()
int m,d,y;
int yy,mm;
long K1,K2,K3,J;
double V;
byte PWMvalue;
m = month();
d = day();
y = year();
yy = y-((12-m)/10);
mm = m+9;
if (mm>=12) mm -= 12;
K1 = 365.25*(yy+4712);
K2 = 30.6*mm+.5;
K3 = int(int((yy/100)+49)*.75)-38;
J = K1+K2+d+59-K3;
V = (J-2451550.1)/29.530588853;
V -= floor(V);
if (V<0) V++;
if (V<0.0625) return "New Moon";
else if (V<0.1875) return "Waxing Crescent";
else if (V<0.3125) return "First Quarter";
else if (V<0.4375) return "Waxing Gibbous";
else if (V<0.5625) return "Fuul Moon";
else if (V<0.6875) return "Waning Gibbous";
else if (V<0.8125) return "Last Quarter";
else if (V<0.9375) return "Waning Crescent";
else return "New Moon";
I think this line is the problem:
You are going out of bounds.
Also, remove these lines:
Or your lights will never turn on. You are sending 0s to all channels with this code.
- JNieuwenhuizen
My Bad.. Sorry. Now it works!
I do have a question.. on the scetchbook-custommain_pwm
There is a menu function call PWM-> and sub menus
Is there code for it somewhere? how would I replace one of my menus to have that?
Cool.
That PWM menu option was useless and has been even removed on the latest libraries update.
- JNieuwenhuizen
Thank You Roberto.
I have a bit of a dellema. my mooncycle is not working , what did I do wrong?
if (ReefAngel.PWM.ExpansionChannel[0]=1) MoonPWMValue=0;
Last edited by JNieuwenhuizen on Thu May 31, 2012 3:32 pm, edited 2 times in total.
- JNieuwenhuizen
Nothing. It does not switch on at all.
- JNieuwenhuizen
So using the new Reef Angel Wizard, I now get the moonlights on, but they stay on as the Wizard generates a bit of code like this
If I try adding times toit like the Parabola code, or PWMslop code, it gives me errors.
if (hour()>=22 || hour()<6)
ReefAngel.PWM.SetChannel( 5, 0);
- JNieuwenhuizen
Its working now
Thank You
Thank You
pilonstar
Can you post the code working please? also can you post any pics of the controller?JNieuwenhuizen wrote:Its working now
Thank You
thank you
- JNieuwenhuizen
Hi pilonstar
This code is no more.
Since the PWM module code has been moved to it, my head unit code is as simple as a wizrad generated file, its only the custom main screens, and that is still a work in progress.
As soon as everything works, I'll paste the code for you
- JNieuwenhuizen
I have re-done my code in the next Memory and versions upgrades..
I got rid off all the extra screens, and the unwanted stuffs, as I did not use them.
Now, my menus dont work.. what did I do wrong?
My new code
My new code
byte vtechmode = 0;
byte x,y;
byte TempRelay =15;
byte TempRelay2=15;
prog_char menu0_label[] PROGMEM = "Food";
prog_char menu1_label[] PROGMEM = "Cleanup";
prog_char menu2_label[] PROGMEM = "ATU Clear";
prog_char menu3_label[] PROGMEM = "pH";
prog_char menu4_label[] PROGMEM = "Salinity";
prog_char menu5_label[] PROGMEM = "Sump On";
prog_char menu6_label[] PROGMEM = "Sump Off";
prog_char menu7_label[] PROGMEM = "Item 8";
prog_char menu8_label[] PROGMEM = "Date/Time";
menu0_label, menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label, menu7_label, menu8_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");
void MenuEntry5()
ReefAngel.DisplayMenuEntry("Item 5");
void MenuEntry6()
ReefAngel.DisplayMenuEntry("Item 6");
#ifdef RelayExp
#endif // RelayExp
void MenuEntry7()
ReefAngel.DisplayMenuEntry("Item 7");
#ifdef RelayExp
#endif // RelayExp
void MenuEntry8()
ReefAngel.DisplayMenuEntry("Item 8");
if (!fOverrideRF && vtechmode == 9)
vtechmode=0;
vtechmode++;
fOverrideRF = true;
vtechmode = 0;
void MenuEntry9()
ReefAngel.DisplayMenuEntry("Item 9");
ReefAngel.SetupDateTime();
int x,y;
//Top Banner
char text[7];
// Display pH Value
/* if (ReefAngel.PWM.Channel[5] > 0);
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePortsE[0] = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPortsE[0] = Port4Bit;
ReefAngel.OverheatShutoffPorts = Port5Bit | Port6Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port5 );
ReefAngel.StandardHeater( Port6 );
ReefAngel.StandardATO( Box1_Port5 );
ReefAngel.MoonLights( Box1_Port4 );
//#define Night 9
//#define None 99
if (!fOverrideRF)
ReefAngel.RF.SetMode(Night,10,0);
vtechmode = Night;
ReefAngel.Portal( "JNieuwenhuizen" );
You are missing one line in the setup() section:
ReefAngel.InitMenu(pgm_read_word(&(menu_items[0])),SIZE(menu_items));Roberto.
- JNieuwenhuizen
Thanx Roberto!
