Bootloader upgrade (optiboot)
Re: Bootloader upgrade (optiboot)
Cool!!
I'm happy with v4 too. It's got a very slightly delay on boot from v2, but it's barely noticeable and helped with the small code size sketches.
Nice. Well it's still working good for me. No complaints so far....haven't fully tested it out but will keep you posted. So far so good. :)
lukeluke
Post by lukeluke »
hi,
i was tryng with the DIY parallel port programmer and win 7 32B ..... but nothing
it's return this:
avrdude: AVR device not responding
avrdude: initialization failed, rc=-1
avrdude: Yikes! Invalid device signature.
avrdude: Expected signature for ATMEGA328P is 1E 95 0F
***failed;
avrdude: verification error, first mismatch at byte 0x0000
0x05 != 0x07
avrdude: verification error; content mismatch
My Arduino IDE is the official program, not RA .
It does not matter Official IDE or RA installer IDE. They are about the same with just slight differences on some files, but I think your problem lies on the programmer itself.
Make sure RA is on when you want to program and also watch for the orientation of pin 1, which I forgot to add in the silk screen of the board.
Please see attachment.
The silk screen for pin 1 would have been useful, but I managed to figure it out. :)
I also don't use arduino gui to upload my bootloader. I use the following command:
avrdude -c usbtiny -p m328p -U flash:w:BOOTLOADER.hex
You will have to check the -c option for parallel programmer. Mine uses the ubstiny to upload. It took me a few tries to get things figured out on how it works but once I did, it has worked great for me.
lukeluke
Post by lukeluke »
binder wrote:The silk screen for pin 1 would have been useful, but I managed to figure it out. :)
i had remake the solder because i had inverted the connector...
Now this is the Arduino error:
avrdude: verification error, first mismatch at byte 0x7800
0x0c != 0xff
i download WinAVR. go in winavr/bin directory and lunch this command:
avrdude -c dapa -p m328p -U flash:w:optiboot_ReefAngel.hex
this is the error:
C:\WinAVR-20100110\bin>avrdude -c dapa -p m328p -U flash:w:optiboot_ReefAngel.hex
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.05s
avrdude: Device signature = 0x1e950f
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "optiboot_ReefAngel.hex"
avrdude: input file optiboot_ReefAngel.hex auto detected as Intel Hex
avrdude: writing flash (32768 bytes):
Writing | ################################################## | 100% 15.32s
avrdude: 32768 bytes of flash written
avrdude: verifying flash memory against optiboot_ReefAngel.hex:
avrdude: load data flash data from input file optiboot_ReefAngel.hex:
avrdude: input file optiboot_ReefAngel.hex contains 32768 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 16.02s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x7e00
0x11 != 0xff
avrdude: safemode: hfuse changed! Was da, and is now ff
Would you like this fuse to be changed back? [y/n] y
why ?
Thanks ;)
You need to setup the fuses correctly.
This is the command:
avrdude -c dapa -p atmega328p -P lpt1  -e -u -U lock:w:0x3f:m -U efuse:w:0x05:m -U hfuse:w:0xDE:m -U lfuse:w:0xFF:m
Followed by:
avrdude -c dapa -p m328p -U flash:w:optiboot_ReefAngel.hex -U lock:w:0x0f:m
lukeluke
Post by lukeluke »
I retry:
C:\WinAVR-20100110\bin>avrdude -c dapa -p atmega328p -P lpt1 -e -u -U lock:w:0x
Reading | ################################################## | 100% 0.02s
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
Reading | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock verified
avrdude: reading input file "0x05"
avrdude: writing efuse (1 bytes):
avrdude: 1 bytes of efuse written
avrdude: verifying efuse memory against 0x05:
avrdude: load data efuse data from input file 0x05:
avrdude: input file 0x05 contains 1 bytes
avrdude: reading on-chip efuse data:
Reading | ################################################## | 100% 0.01s
avrdude: 1 bytes of efuse verified
avrdude: reading input file "0xDE"
avrdude: writing hfuse (1 bytes):
avrdude: 1 bytes of hfuse written
avrdude: verifying hfuse memory against 0xDE:
avrdude: load data hfuse data from input file 0xDE:
avrdude: input file 0xDE contains 1 bytes
avrdude: reading on-chip hfuse data:
avrdude: 1 bytes of hfuse verified
avrdude: reading input file "0xFF"
avrdude: writing lfuse (1 bytes):
avrdude: 1 bytes of lfuse written
avrdude: verifying lfuse memory against 0xFF:
avrdude: load data lfuse data from input file 0xFF:
avrdude: input file 0xFF contains 1 bytes
avrdude: reading on-chip lfuse data:
avrdude: 1 bytes of lfuse verified
avrdude done. Thank you.
x -U lock:w:0x0f:m
Writing | ################################################## | 100% 12.76s
Reading | ################################################## | 100% 11.45s
0x11 != 0xff
avrdude: safemode: hfuse changed! Was de, and is now ff
I don't have my makefile with me. I'll post later.
You may want to try the Arduino IDE with the correct boards.txt modification to see if you can do it that way in the mean time.
Well, I guess I was wrong.
Here is the correct fuses to burn the bootloader:
avrdude  -c usbtiny -p atmega328p -P lpt1  -e -u -U lock:w:0x3f:m -U efuse:w:0x05:m -U hfuse:w:0xDE:m -U lfuse:w:0xFF:m
avrdude  -c usbtiny -p atmega328p -P lpt1  -B1 -U flash:w:optiboot_ReefAngel.hex -U lock:w:0x2f:m
I revised the original post with the correct fuses and also updated the readme.txt file inside the optiboot_ReefAngel_v4.0.zip to reflect the same fuses.
I'm sorry for the confusion.
rimai wrote:I revised the original post with the correct fuses and also updated the readme.txt file inside the optiboot_ReefAngel_v4.0.zip to reflect the same fuses.
Cool. That will make it easy for me to burn it and test out the new stuff.
Thanks for all your hard work. :)
lukeluke
Post by lukeluke »
roberto thanks.... i'll try it monday ;-)
lukeluke
Post by lukeluke »
nothing to do:
C:\WinAVR-20100110\bin>avrdude -c dapa -p atmega328p -P lpt1 -B1 -U flash:w:op
Reading | ################################################## | 100% 0.06s
Writing | ################################################## | 100% 13.09s
Reading | ################################################## | 100% 11.56s
0x11 != 0xff
lukeluke
Post by lukeluke »
hi,
we have any news ?
Maybe you ought to try the Arduino IDE instead of WinAVR.
Let me know what you get.
lukeluke
Post by lukeluke »
i try with the Arduino IDE...but nothing....
This is the makefile I use with WinAVR:
# Makefile for ATmegaBOOT
# E.Lins, 18.7.2005
# $Id$
# Instructions
# To make bootloader .hex file:
# make diecimila
# make lilypad
# make ng
# etc...
# To burn bootloader .hex file:
# make diecimila_isp
# make lilypad_isp
# make ng_isp
# etc...
# program name should not be changed...
PROGRAM    = optiboot
# The default behavior is to build using tools that are in the users
# current path variables, but we can also build using an installed
# Arduino user IDE setup, or the Arduino source tree.
# Uncomment this next lines to build within the arduino environment,
# using the arduino-included avrgcc toolset (mac and pc)
# ENV ?= arduino
# ENV ?= arduinodev
# OS ?= macosx
# OS ?= windows
# enter the parameters for the avrdude isp tool
ISPTOOL	   = usbtiny
ISPPORT	   = lpt1
#ISPSPEED   = -b 115200
MCU_TARGET = atmega168
LDSECTIONS  = -Wl,--section-start=.text=0x3e00 -Wl,--section-start=.version=0x3ffe
# Build environments
# Start of some ugly makefile-isms to allow optiboot to be built
# in several different environments.  See the README.TXT file for
# details.
# default
fixpath = $(1)
ifeq ($(ENV), arduino)
# For Arduino, we assume that we're connected to the optiboot directory
# included with the arduino distribution, which means that the full set
# of avr-tools are "right up there" in standard places.
TOOLROOT = ../../../tools
GCCROOT = $(TOOLROOT)/avr/bin/
AVRDUDE_CONF = -C$(TOOLROOT)/avr/etc/avrdude.conf
ifeq ($(OS), windows)
# On windows, SOME of the tool paths will need to have backslashes instead
# of forward slashes (because they use windows cmd.exe for execution instead
# of a unix/mingw shell?)
fixpath = $(subst /,\,$1)
endif
else ifeq ($(ENV), arduinodev)
# Arduino IDE source code environment.  Use the unpacked compilers created
# by the build (you'll need to do "ant build" first.)
ifeq ($(OS), macosx)
TOOLROOT = ../../../../build/macosx/work/Arduino.app/Contents/Resources/Java/hardware/tools
endif
TOOLROOT = ../../../../build/windows/work/hardware/tools
endif
GCCROOT =
AVRDUDE_CONF =
endif
# End of build environment code.
# the efuse should really be 0xf8; since, however, only the lower
# three bits of that byte are used on the atmega168, avrdude gets
# confused if you specify 1's for the higher bits, see:
# http://tinker.it/now/2007/02/24/the-tale-of-avrdude-atmega168-and-extended-bits-fuses/
# similarly, the lock bits should be 0xff instead of 0x3f (to
# unlock the bootloader section) and 0xcf instead of 0x2f (to
# lock it), but since the high two bits of the lock byte are
# unused, avrdude would get confused.
GCCROOT =
ISPFUSES    = $(GCCROOT)avrdude $(AVRDUDE_CONF) -c $(ISPTOOL) \
              -p $(MCU_TARGET) -P $(ISPPORT) $(ISPSPEED) \
              -e -u -U lock:w:0x3f:m -U efuse:w:0x$(EFUSE):m \
              -U hfuse:w:0x$(HFUSE):m -U lfuse:w:0x$(LFUSE):m
ISPFLASH    = $(GCCROOT)avrdude $(AVRDUDE_CONF) -c $(ISPTOOL) \
              -B1 -U flash:w:$(PROGRAM)_$(TARGET).hex -U lock:w:0x2f:m
STK500 = "C:\Program Files\Atmel\AVR Tools\STK500\Stk500.exe"
STK500-1 = $(STK500) -e -d$(MCU_TARGET) -pf -vf -if$(PROGRAM)_$(TARGET).hex \
-lFF -LFF -f$(HFUSE)$(LFUSE) -EF8 -ms -q -cUSB -I200kHz -s -wt
STK500-2 = $(STK500) -d$(MCU_TARGET) -ms -q -lCF -LCF -cUSB -I200kHz -s -wt
OBJ        = $(PROGRAM).o
OPTIMIZE = -Os -fno-inline-small-functions -fno-split-wide-types -mshort-calls
DEFS       =
LIBS       =
CC         = $(GCCROOT)avr-gcc
# Override is only needed by avr-lib build system.
override CFLAGS        = -g -Wall $(OPTIMIZE) -mmcu=$(MCU_TARGET) -DF_CPU=$(AVR_FREQ) $(DEFS)
override LDFLAGS       = $(LDSECTIONS) -Wl,--relax -Wl,--gc-sections -nostartfiles -nostdlib
OBJCOPY        = $(GCCROOT)avr-objcopy
OBJDUMP        = $(call fixpath,$(GCCROOT)avr-objdump)
SIZE           = $(GCCROOT)avr-size
# Test platforms
# Virtual boot block test
virboot328: TARGET = atmega328
virboot328: MCU_TARGET = atmega328p
virboot328: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200' '-DVIRTUAL_BOOT'
virboot328: AVR_FREQ = 16000000L
virboot328: LDSECTIONS  = -Wl,--section-start=.text=0x7e00 -Wl,--section-start=.version=0x7ffe
virboot328: $(PROGRAM)_atmega328.hex
virboot328: $(PROGRAM)_atmega328.lst
# 20MHz clocked platforms
# These are capable of 230400 baud, or 115200 baud on PC (Arduino Avrdude issue)
pro20: TARGET = pro_20mhz
pro20: MCU_TARGET = atmega168
pro20: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
pro20: AVR_FREQ = 20000000L
pro20: $(PROGRAM)_pro_20mhz.hex
pro20: $(PROGRAM)_pro_20mhz.lst
pro20_isp: pro20
pro20_isp: TARGET = pro_20mhz
# 2.7V brownout
pro20_isp: HFUSE = DD
# Full swing xtal (20MHz) 258CK/14CK+4.1ms
pro20_isp: LFUSE = C6
# 512 byte boot
pro20_isp: EFUSE = 04
pro20_isp: isp
# 16MHz clocked platforms
pro16: TARGET = pro_16MHz
pro16: MCU_TARGET = atmega168
pro16: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
pro16: AVR_FREQ = 16000000L
pro16: $(PROGRAM)_pro_16MHz.hex
pro16: $(PROGRAM)_pro_16MHz.lst
pro16_isp: pro16
pro16_isp: TARGET = pro_16MHz
# 2.7V brownout
pro16_isp: HFUSE = DD
pro16_isp: LFUSE = C6
# 512 byte boot
pro16_isp: EFUSE = 04
pro16_isp: isp
# Diecimila, Duemilanove with m168, and NG use identical bootloaders
# Call it "atmega168" for generality and clarity, keep "diecimila" for
# backward compatibility of makefile
atmega168: TARGET = atmega168
atmega168: MCU_TARGET = atmega168
atmega168: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
atmega168: AVR_FREQ = 16000000L
atmega168: $(PROGRAM)_atmega168.hex
atmega168: $(PROGRAM)_atmega168.lst
atmega168_isp: atmega168
atmega168_isp: TARGET = atmega168
# 2.7V brownout
atmega168_isp: HFUSE = DD
# Low power xtal (16MHz) 16KCK/14CK+65ms
atmega168_isp: LFUSE = FF
# 512 byte boot
atmega168_isp: EFUSE = 04
atmega168_isp: isp
diecimila: TARGET = diecimila
diecimila: MCU_TARGET = atmega168
diecimila: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
diecimila: AVR_FREQ = 16000000L
diecimila: $(PROGRAM)_diecimila.hex
diecimila: $(PROGRAM)_diecimila.lst
diecimila_isp: diecimila
diecimila_isp: TARGET = diecimila
# 2.7V brownout
diecimila_isp: HFUSE = DD
diecimila_isp: LFUSE = FF
# 512 byte boot
diecimila_isp: EFUSE = 04
diecimila_isp: isp
atmega328: TARGET = ReefAngel
atmega328: MCU_TARGET = atmega328p
atmega328: CFLAGS += '-DLED_START_FLASHES=3' '-DLED_DATA_FLASH' '-DBAUD_RATE=115200'
atmega328: AVR_FREQ = 16000000L
atmega328: LDSECTIONS  = -Wl,--section-start=.text=0x7e00 -Wl,--section-start=.version=0x7ffe
atmega328: $(PROGRAM)_ReefAngel.hex
atmega328: $(PROGRAM)_ReefAngel.lst
atmega328_isp: atmega328
atmega328_isp: TARGET = ReefAngel
atmega328_isp: MCU_TARGET = atmega328p
# 512 byte boot, SPIEN
atmega328_isp: HFUSE = DE
atmega328_isp: LFUSE = FF
# 2.7V brownout
atmega328_isp: EFUSE = 05
atmega328_isp: isp
# Sanguino has a minimum boot size of 1024 bytes, so enable extra functions
sanguino: TARGET = atmega644p
sanguino: MCU_TARGET = atmega644p
sanguino: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200' '-DBIGBOOT'
sanguino: AVR_FREQ = 16000000L
sanguino: LDSECTIONS  = -Wl,--section-start=.text=0xfc00
sanguino: $(PROGRAM)_atmega644p.hex
sanguino: $(PROGRAM)_atmega644p.lst
sanguino_isp: sanguino
sanguino_isp: TARGET = atmega644p
sanguino_isp: MCU_TARGET = atmega644p
# 1024 byte boot
sanguino_isp: HFUSE = DE
sanguino_isp: LFUSE = FF
# 2.7V brownout
sanguino_isp: EFUSE = 05
sanguino_isp: isp
# Mega has a minimum boot size of 1024 bytes, so enable extra functions
#mega: TARGET = atmega1280
mega: MCU_TARGET = atmega1280
mega: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200' '-DBIGBOOT'
mega: AVR_FREQ = 16000000L
mega: LDSECTIONS  = -Wl,--section-start=.text=0x1fc00
mega: $(PROGRAM)_atmega1280.hex
mega: $(PROGRAM)_atmega1280.lst
mega_isp: mega
mega_isp: TARGET = atmega1280
mega_isp: MCU_TARGET = atmega1280
# 1024 byte boot
mega_isp: HFUSE = DE
mega_isp: LFUSE = FF
# 2.7V brownout
mega_isp: EFUSE = 05
mega_isp: isp
# ATmega8
atmega8: TARGET = atmega8
atmega8: MCU_TARGET = atmega8
atmega8: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
atmega8: AVR_FREQ = 16000000L
atmega8: LDSECTIONS  = -Wl,--section-start=.text=0x1e00 -Wl,--section-start=.version=0x1ffe
atmega8: $(PROGRAM)_atmega8.hex
atmega8: $(PROGRAM)_atmega8.lst
atmega8_isp: atmega8
atmega8_isp: TARGET = atmega8
atmega8_isp: MCU_TARGET = atmega8
# SPIEN, CKOPT, Bootsize=512B
atmega8_isp: HFUSE = CC
# 2.7V brownout, Low power xtal (16MHz) 16KCK/14CK+65ms
atmega8_isp: LFUSE = BF
atmega8_isp: isp
# ATmega88
atmega88: TARGET = atmega88
atmega88: MCU_TARGET = atmega88
atmega88: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
atmega88: AVR_FREQ = 16000000L
atmega88: LDSECTIONS  = -Wl,--section-start=.text=0x1e00 -Wl,--section-start=.version=0x1ffe
atmega88: $(PROGRAM)_atmega88.hex
atmega88: $(PROGRAM)_atmega88.lst
atmega88_isp: atmega88
atmega88_isp: TARGET = atmega88
atmega88_isp: MCU_TARGET = atmega88
# 2.7V brownout
atmega88_isp: HFUSE = DD
atemga88_isp: LFUSE = FF
# 512 byte boot
atmega88_isp: EFUSE = 04
atmega88_isp: isp
# 8MHz clocked platforms
# These are capable of 115200 baud
lilypad: TARGET = lilypad
lilypad: MCU_TARGET = atmega168
lilypad: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
lilypad: AVR_FREQ = 8000000L
lilypad: $(PROGRAM)_lilypad.hex
lilypad: $(PROGRAM)_lilypad.lst
lilypad_isp: lilypad
lilypad_isp: TARGET = lilypad
# 2.7V brownout
lilypad_isp: HFUSE = DD
# Internal 8MHz osc (8MHz) Slow rising power
lilypad_isp: LFUSE = E2
# 512 byte boot
lilypad_isp: EFUSE = 04
lilypad_isp: isp
lilypad_resonator: TARGET = lilypad_resonator
lilypad_resonator: MCU_TARGET = atmega168
lilypad_resonator: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
lilypad_resonator: AVR_FREQ = 8000000L
lilypad_resonator: $(PROGRAM)_lilypad_resonator.hex
lilypad_resonator: $(PROGRAM)_lilypad_resonator.lst
lilypad_resonator_isp: lilypad_resonator
lilypad_resonator_isp: TARGET = lilypad_resonator
# 2.7V brownout
lilypad_resonator_isp: HFUSE = DD
lilypad_resonator_isp: LFUSE = C6
# 512 byte boot
lilypad_resonator_isp: EFUSE = 04
lilypad_resonator_isp: isp
pro8: TARGET = pro_8MHz
pro8: MCU_TARGET = atmega168
pro8: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
pro8: AVR_FREQ = 8000000L
pro8: $(PROGRAM)_pro_8MHz.hex
pro8: $(PROGRAM)_pro_8MHz.lst
pro8_isp: pro8
pro8_isp: TARGET = pro_8MHz
# 2.7V brownout
pro8_isp: HFUSE = DD
pro8_isp: LFUSE = C6
# 512 byte boot
pro8_isp: EFUSE = 04
pro8_isp: isp
atmega328_pro8: TARGET = atmega328_pro_8MHz
atmega328_pro8: MCU_TARGET = atmega328p
atmega328_pro8: CFLAGS += '-DLED_START_FLASHES=3' '-DBAUD_RATE=115200'
atmega328_pro8: AVR_FREQ = 8000000L
atmega328_pro8: LDSECTIONS = -Wl,--section-start=.text=0x7e00 -Wl,--section-start=.version=0x7ffe
atmega328_pro8: $(PROGRAM)_atmega328_pro_8MHz.hex
atmega328_pro8: $(PROGRAM)_atmega328_pro_8MHz.lst
atmega328_pro8_isp: atmega328_pro8
atmega328_pro8_isp: TARGET = atmega328_pro_8MHz
atmega328_pro8_isp: MCU_TARGET = atmega328p
atmega328_pro8_isp: HFUSE = DE
atmega328_pro8_isp: LFUSE = FF
# 2.7V brownout
atmega328_pro8_isp: EFUSE = 05
atmega328_pro8_isp: isp
# 1MHz clocked platforms
# These are capable of 9600 baud
luminet: TARGET = luminet
luminet: MCU_TARGET = attiny84
luminet: CFLAGS += '-DLED_START_FLASHES=3' '-DSOFT_UART' '-DBAUD_RATE=9600'
luminet: CFLAGS += '-DVIRTUAL_BOOT_PARTITION'
luminet: AVR_FREQ = 1000000L
luminet: LDSECTIONS = -Wl,--section-start=.text=0x1d00 -Wl,--section-start=.version=0x1efe
luminet: $(PROGRAM)_luminet.hex
luminet: $(PROGRAM)_luminet.lst
luminet_isp: luminet
luminet_isp: TARGET = luminet
luminet_isp: MCU_TARGET = attiny84
# Brownout disabled
luminet_isp: HFUSE = DF
# 1MHz internal oscillator, slowly rising power
luminet_isp: LFUSE = 62
# Self-programming enable
luminet_isp: EFUSE = FE
luminet_isp: isp
# Generic build instructions
all: atmega328
program: atmega328_isp
isp: $(TARGET)
	$(ISPFUSES)
	$(ISPFLASH)
isp-stk500: $(PROGRAM)_$(TARGET).hex
	$(STK500-1)
	$(STK500-2)
%.elf: $(OBJ)
	$(CC) $(CFLAGS) $(LDFLAGS) -o $@ $^ $(LIBS)
	$(SIZE) $@
clean:
	rm -rf *.o *.elf *.lst *.map *.sym *.lss *.eep *.srec *.bin *.hex
%.lst: %.elf
	$(OBJDUMP) -h -S $< > $@
%.hex: %.elf
	$(OBJCOPY) -j .text -j .data -j .version --set-section-flags .version=alloc,load -O ihex $< $@
%.srec: %.elf
	$(OBJCOPY) -j .text -j .data -j .version --set-section-flags .version=alloc,load -O srec $< $@
%.bin: %.elf
	$(OBJCOPY) -j .text -j .data -j .version --set-section-flags .version=alloc,load -O binary $< $@
lukeluke
Post by lukeluke »
this is wrong: MCU_TARGET = atmega168 ..... no ?
lukeluke
Post by lukeluke »
i try to use Linux and the avrdude.
$ avrdude -c dapa -p atmega328p -e -u -U lock:w:0x3f:m -U efuse:w:0x05:m -U hfuse:w:0xDE:m -U lfuse:w:0xFF:m
Double check connections and try again, or use -F to override
this check.
What can i do ?
I've never tried linux but I think you need to tell which port you are connecting to:
lukeluke wrote:this is wrong: MCU_TARGET = atmega168 ..... no ?
Open the file on programmer's notepad.
Use the menu, you can just use Tools->Make All
If you look at the all section:
all: atmega328
It calls atmega328.
My bad....
Actually, make all is to actually compile.
You need to use Tools->Program, which calls atmega328_isp
You need to change this though:
ISPTOOL      = usbtiny
To this:
ISPTOOL      = dapa
when I used avrdude, I had to use this for the -p command:
 -p m328p
I tried the atmega328p and it gave me errors.
lukeluke
Post by lukeluke »
the option -P i think that on linux is not utilized:
[luke@PC_005299 optiboot_ReefAngel_v4.0]$ avrdude  -c dapa -p m328p -e -u -U lock:w:0x3f:m -U efuse:w:0x05:m -U hfuse:w:0xDE:m -U lfuse:w:0xFF:m
         this check.
i receive the same error on windows...
is possible that the chip is broken ?
can the DIY interface not work right ?
i see this http://cgi.ebay.it/ws/eBayISAPI.dll?Vie ... K:MEWAX:IT what do you think ?
i would also get that error on windows if the programmer wasnt recognized properly. I had to unplug it and plug it back in to get it to work. I also have to have my controller powered on for it to work too. I would also make sure that your parallel pprt is enabled and working too.
It could be that your programmer is not wired up properly.
Chrome has made one and he had sucess in burning his bootloader.
The link you sent is the kind of programmer you are looking for, except that one does not support ATMega328P. If the chip was broken, your whole RA would be broken, so I doubt it's the chip.
I use a USBTiny programmer. You can buy it at adafruit or sparkfun:
http://www.adafruit.com/products/46&zen ... 469c4ccacc
http://www.sparkfun.com/products/9825
rimai wrote:It could be that your programmer is not wired up properly.
I have the same programmer but it does not work with linux. So i have to use windows to program my bootloader.
lukeluke
Post by lukeluke »
oh yeah!!!!!!
I retry on linux and it's works !!!!!
[luke@PC_005299 ~]$ avrdude -c dapa -p m328p -e -u -U lock:w:0x3f:m -U efuse:w:0x05:m -U hfuse:w:0xDE:m -U lfuse:w:0xFF:m
[luke@PC_005299 optiboot_ReefAngel_v4.0]$ avrdude -c dapa -p m328p -B1 -U flash:w:optiboot_ReefAngel.hex -U lock:w:0x2f:m
Writing | ################################################## | 100% 8.27s
Reading | ################################################## | 100% 6.95s
avrdude: 32768 bytes of flash verified
avrdude: reading input file "0x2f"
avrdude: verifying lock memory against 0x2f:
avrdude: load data lock data from input file 0x2f:
avrdude: input file 0x2f contains 1 bytes
avrdude: safemode: Fuses OK
lukeluke
Post by lukeluke »
i changed my board.txt and the type of the board in the Arduino IDE.
I reinstall the PDE and it's WORKS !!!!
Now, how can i use the WDT ? Curt on you latest release the function works right ?
