Hey, I'm looking to buy a RA+ to work with some DIY LED's I am having made. Does the standard RA+ come with dimming ports, or do I need to purchase an expansion module? What type of connections do the analog dimming ports use?
Thank you.
Dimming question
Re: Dimming question
It comes with 2 dimming channels.
If you want to have more than 2, you will need the dimming expansion module.
You can also purchase the dimming port lead wire at the webstore.
jhawkor
Thanks for the response. Is the code to ramp My LED's up and down preloaded, or will it need to be added online?
