Setting Up Help
fatman
Setting Up Help
I've been working for hours trying to set my RA + up. Now all I get are the relays clicking on and off. Nothing seems to help and I've looked through the documentation several time and searched on the forums. I tried to restore to it's shipped state and get a file too long error. I know this thing will work, but I'm getting frustrated with my ineptness at this!
Re: Setting Up Help
I saw your other post about drivers. Did you get that figured out?
Also, Did you change the board to RA+ on menu Tools->Board?
fatman
Re: Setting Up Help
I got the drivers figured out. I just did that and still have issues with the relays clicking on and off.
Re: Setting Up Help
You can't possibly get file too big if you chose RA+.
We still have not got the libraries big enough to fill up an RA+ board.
Can you double check?
fatman
Re: Setting Up Help
Ok, I muddled my way though it and now the relays are not clicking on and off. I had to shut all the outlets down. Now I'll try to restore the factory defaults. Maybe I got it!?! Just tried that and now I'm back to clicking relays....sad day for me. Anyone know what I need to do to fix this?
Fat
Fat
fatman
Re: Setting Up Help
Just found out that I hadn't checked the RA+ box, now it's checked and did a custom program with all the ports off. I restored to factory defaults after that and the clicking relays are back!rimai wrote:You can't possibly get file too big if you chose RA+.
fatman
Re: Setting Up Help
Fingers crossed, I finally generated a new code and the relays are done clicking. Let me do some additional testing to see what's on and I'll let you know. Thanks for the help Roberto.
Fat
Fat
fatman
Re: Setting Up Help
Update. I have the controller working so far. Had to reset the WiFi and finally gave up for the night. I'll spend some time on it tomorrow and get it all running.
