Custom Main Screens
Would you like to help?
Deckoz2302
Re: Custom Main Screens
Post by Deckoz2302 »
//Custom Main, Graph & Menu
  Wire.requestFrom(8,8);
  for (int a=0;a<8;a++)
    if (Wire.available()) SeasonsVar[a]=Wire.receive();
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  ReefAngel.LCD.DrawDate(6, 2);
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, 123, "|");
  ReefAngel.LCD.DrawText(0,255,18,12,"EcoSmart Vortech");
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,22,"Constant");
  else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,21,"Lagoon");
  else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,21,"Reef Crest");
  else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,21,"Short Pulse");
  else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,21,"Long Pulse");
  else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,21,"Nutrient Trnsp.");
  else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,21,"Tidal Swell");
  else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,21,"Night");
  ReefAngel.LCD.DrawText(0,255,10,30,"Display");
  ConvertNumToString(text, ReefAngel.Params.Temp1, 10);
  ReefAngel.LCD.DrawLargeText(COLOR_INDIANRED, 255, 10, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,100,30,"pH");
  ReefAngel.LCD.DrawLargeText(COLOR_PLUM, 255, 85, 40, text, Num8x8);
  ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  ReefAngel.LCD.DrawOutletBox(12, 77, TempRelay);
  ReefAngel.LCD.DrawText(0,255,8,68,"Sump");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawText(0,255,70,68,"Room");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_CORNFLOWERBLUE, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,8,97,"Moon");
  DayAge = MoonAge(day(), month(), year());
  MoonState(DayAge);
  if (ThisPhase == 0) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"New");
  else if (ThisPhase == 1) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Crescent");
  else if (ThisPhase == 2) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"First Quarter");
  else if (ThisPhase == 3) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waxing Gibbous");
  else if (ThisPhase == 4) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Full");
  else if (ThisPhase == 5) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Gibbous");
  else if (ThisPhase == 6) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Last Quarter");
  else if (ThisPhase == 7) ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,97,"Waning Crescent");
  //  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.PWM.GetActinicValue(),COLOR_CORNFLOWERBLUE, 105, 109, 1);
  ReefAngel.LCD.DrawText(0,255,8,109, "Sunrise");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,119, SeasonsVar[1]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,20,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,25,119, SeasonsVar[2]);
  ReefAngel.LCD.DrawText(0,255,75,109,"%");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255, 60, 109, SeasonsVar[0]);
  ReefAngel.LCD.DrawText(0,255,88,109, "Sunset");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,90,119, SeasonsVar[3]);
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,102,119, ":");
  ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,107,119, SeasonsVar[4]);
I love this screen!!!
Deckoz2302
Thanks man, I worked on it all day haha, nudging each thing around to make it perfect - ps all of the ecotech modes are centered when theyre called and the color of the vortech mode matches the driver
wolfador
Post by wolfador »
very nice screen!
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
psyrob
Post by psyrob »
Great screen!! Hey, where in your code does it make the relay box be blue and white instead of the standard red/black? I can't figure it out...
psyrob wrote:Great screen!! Hey, where in your code does it make the relay box be blue and white instead of the standard red/black? I can't figure it out...
depends on how you want to do it. the values are stored in reefangel_globals.h or you can enable the colors file.
Deckoz2302
Like binder said - I edited the colors through globals.h
use caution with editing the globals.h file, that file gets updated with new releases of the libraries. the recommended way is to use the colors file.
Deckoz2302
hmmm yea i forgot that - come to think of it now that I went and looked at it, I did use colors. But I found out what colors were available/preprogrammed by looking at globals.h
Deckoz2302 wrote:hmmm yea i forgot that - come to think of it now that I went and looked at it, I did use colors. But I found out what colors were available/preprogrammed by looking at globals.h
ReefAngel_Colors.h contains a list of the colors in it's own file (same as Globals.h, there's a reason why it's like this).
ReefAngel_CustomColors.h is the file that you can make your changes to.
If using those files, they must be included into your PDE file and also the Features.h file needs to have the #define CUSTOM_COLORS in it.
Deckoz2302
I changed it up a little bit - Where moon cycle is in the last picture -
At night it shows moon phase with pwm% and where moonphase is(crescent, quarter, gibb, full ect)
During the day it shows 4 PWM module %'s
If there is a cloud it will show time and duration, also if there is lightning it will change the label from cloud to storm
  for (int a=0;a<12;a++)
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  for (byte Left=93; Left < 133; Left+=10)
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 2, Left, "|");
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255, 126, Left, "|");
  ReefAngel.LCD.Clear(255, 1, 19, 128, 29);
  if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,21,"Constant");
  ConvertNumToString(text, ReefAngel.Params.Temp3, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_CORNFLOWERBLUE, 40, 68, 10);
  if (ReefAngel.PWM.GetActinicValue() > 0)//if moon phase is active display state and pwm %
    ReefAngel.LCD.DrawText(0,255,8,98,"Moon");
    MoonState(DayAge);
    char* ThisPhaseLabel[]={
      "New","Waxing Crescent","First Quarter","Waxing Gibbous","Full","Waning Gibbous","Last Quarter","Waning Crescent"                        };
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,35,98,ThisPhaseLabel[ThisPhase]);
    ReefAngel.LCD.DrawSingleMonitor(COLOR_CORNFLOWERBLUE,255, 60, 109, ReefAngel.PWM.GetActinicValue());
  else if (SeasonsVar[5] > 0) //or if there is a cloud display clouds instead
    if (SeasonsVar[8] > 0) ReefAngel.LCD.DrawText(0,255, 8, 98, "Storm"); //decide between dislaying storm or cloud based on lightningchance
    else ReefAngel.LCD.DrawText(0,255,8,98,"Cloud");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,42,98, SeasonsVar[5]);
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,54,98, ":");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,59,98, SeasonsVar[6]);
    ReefAngel.LCD.DrawText(0,255,75,98,"Length");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,115,98, SeasonsVar[7]);
  else //if no moon or clouds show LED PWM %'s
    ReefAngel.LCD.DrawText(0,255,8,98,"W");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,15,98,SeasonsVar[0]);
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255,33,98,"|");
    ReefAngel.LCD.DrawText(0,255,38,98,"R");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,45,98,SeasonsVar[9]);
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255,63,98,"|");
    ReefAngel.LCD.DrawText(0,255,68,98,"B");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,75,98,SeasonsVar[10]);
    ReefAngel.LCD.DrawText(COLOR_TOMATO,255,93,98,"|");
    ReefAngel.LCD.DrawText(0,255,98,98,"V");
    ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,105,98,SeasonsVar[11]);
psyrob
Post by psyrob »
Here is my new one....Thanks to the user who posted the wave maker timer code...I'm sure I will be tinkering and making a new screen before too long :)
photo (2).jpg (88.87 KiB) Viewed 23692 times
SuperDodge
Post by SuperDodge »
Here's where my screen seems to have settled at during my first week of tinkering with my Reef Angel.
The line that says "Lagoon" will eventually update with my Vortech status (when I save some coin for the RF adapter. The line is always centered
The line that says "Clear Skies" will update to say "Cloudy(XX:XX)" or "Storms(XX:XX)" if there is a cloud or a cloud with lightning coming. This line is always centered.
The moon status updates throughout the month and is always centered.
The line that says W:100% B:100% R:100% updates in real-time to reflect all three channels on my AI Nano fixture. The line is always centered as the position of the numbers changes depending on the number of digits.
THANKS TO EVERYONE WHO PROVIDED GREAT CODE AND IDEAS THROUGHOUT THIS THREAD!
CODE REMOVED BECAUSE I FOUND AN ERROR - WILL REPOST WHEN FIXED
That's a pretty slick screen SuperDodge!! Nice work. :)
Deckoz2302
Yes nice screen sir ;)
JNieuwenhuizen
Post by JNieuwenhuizen »
I love the screen Deckoz2302 made. What bit do i have to edit to change the temp from f to c ?
Also the PWM control bit - I run a vertex illumina unit and that does the cycles by it self.
tkeracer619
Post by tkeracer619 »
Is there any way to test the display code without uploading to the controller?
tkeracer619 wrote:Is there any way to test the display code without uploading to the controller?
Unfortunately, No. There isn't a way to test the code without running it on the controller.....at least not yet. That's not saying that something is close. It's just saying that the idea has been discussed just nothing has been done for it.
tkeracer619
I spend a lot of time in hotels and was thinking it would be something fun to do in my boring hotel room. No biggie. I figured there wasn't. Thanks for the reply.
It would be pretty cool if RAGen had a click, drag, place, and modify type screen maker and would generate the code for you based on the screen you come up with.
tkeracer619 wrote:I spend a lot of time in hotels and was thinking it would be something fun to do in my boring hotel room. No biggie. I figured there wasn't. Thanks for the reply.
well, apparently you can read minds. that is what i want to have it do, however i just have not had time to work on it.
tkeracer619
Its scary what you can see with Google maps these days ;)
Sounds awesome.
I updated the Guide to be compatible with the latest RAGen and the 0.9.X libraries.
Deckoz2302 wrote:Image
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  MoonState(DayAge);
Love this screen...I'm trying to get it to work on mine, but I'm getting a ton of errors...I already have custom main and fonts in my Features.h file???
RA_052912_1615custom2Main.cpp: In function 'void DrawCustomMain()':
RA_052912_1615custom2Main:43: error: 'SeasonsVar' was not declared in this scope
RA_052912_1615custom2Main:69: error: 'struct ParamsStruct' has no member named 'Temp1'
RA_052912_1615custom2Main:79: error: 'struct ParamsStruct' has no member named 'Temp1'
RA_052912_1615custom2Main:90: error: 'struct ParamsStruct' has no member named 'Temp3'
RA_052912_1615custom2Main:93: error: 'struct ParamsStruct' has no member named 'Temp2'
RA_052912_1615custom2Main:96: error: 'DayAge' was not declared in this scope
RA_052912_1615custom2Main:96: error: 'MoonAge' was not declared in this scope
RA_052912_1615custom2Main:97: error: 'MoonState' was not declared in this scope
RA_052912_1615custom2Main:98: error: 'ThisPhase' was not declared in this scope
RA_052912_1615custom2Main:110: error: 'SeasonsVar' was not declared in this scope
Deckoz had a custom code on his Dimming expansion module to calculate sunrise/sunset according to the seasons. Longer days on summer and shorter on winter.
He's got his code in his thread too.
The errors you are getting is related to that.
You can try this:
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  static byte vtechmode=0;
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_CORNFLOWERBLUE, 40, 68, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_CORNFLOWERBLUE, 99, 68, 10);
To customize a little further, you can read the guide posted here:
http://forum.reefangel.com/viewtopic.php?f=14&t=109
ReefAngel\ReefAngel.cpp.o: In function `ReefAngelClass::ProcessButtonPressCustom()':
C:\Users\User\Documents\Arduino\libraries\ReefAngel/ReefAngel.cpp:2047: undefined reference to `MenuEntry1()'
That error is because you are trying to do custom menu and not custom main screen.
Is it what you wanted?
Can I see the code?
Got it! Thanks!
I'm on my byte size:
How can I shrink this down??
//The following features are enabled for this File:
//#define VersionMenu
#define DisplayLEDPWM
#define wifi
//#define WDT
//#define SIMPLE_MENU
  byte x = 6;
  byte y = 2;
  byte t;
  char text[7];
  //static byte vtechmode=0;
  ReefAngel.LCD.DrawLargeText(0,255,8,16,"Redneck Reefin!", Font8x8);
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 90, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 6, 126, "--------------------");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 2, 123, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 93, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 103, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 113, "|");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255, 126, 123, "|");
  ReefAngel.LCD.DrawHugeText(COLOR_BLACK, 255, 10, 40, text, Num12x16);
  ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 85, 40, text, Num8x16);
  //ReefAngel.LCD.DrawText(0,255,43,48,"Salinity");
  //ConvertNumToString(text, ReefAngel.Params.Salinity, 100);
  //ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN, 255, 49, 58, text, Num8x8);
  //pingSerial();
  ReefAngel.LCD.DrawText(0,255,8,68,"Light");
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_BLACK, 40, 68, 10);
  ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], COLOR_BLACK, 99, 68, 10);
  ReefAngel.LCD.DrawText(0,255,8,100, "CWLED");
  ReefAngel.LCD.DrawText(COLOR_BLACK,255,15,119, ReefAngel.PWM.GetDaylightValue());
  //ReefAngel.PWM.GetDaylightValue(),
  ReefAngel.LCD.DrawText(0,255,88,100, "RBLED");
  ReefAngel.LCD.DrawText(COLOR_NAVY,255,90,119, ReefAngel.PWM.GetActinicValue());
  //ReefAngel.PWM.GetActinicValue());
  //ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
    InternalMemory.OverheatTemp_write( 860 );
    ReefAngel.SingleATO( true,Port2,60,0 );
    pinMode(lowATOPin,OUTPUT);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port4);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.Relay.On(Port5);
    //randomSeed(analogRead(0));
    //ReefAngel.Init();  //Initialize controller
    //ReefAngel.Timer[1].SetInterval(random(15,35));
    //ReefAngel.Timer[1].Start();
    //ReefAngel.Relay.On(Port5);
    ReefAngel.StandardLights( Port1,19,0,6,30 );
    ReefAngel.StandardHeater( Port4,740,770 );
    ReefAngel.StandardLights( Port7,6,0,20,0 );
    ReefAngel.StandardLights( Port8,7,0,19,0 );
    //////// ReefAngel.Wavemaker1(Port5);
    /////// ReefAngel.Wavemaker2(Port6);
    //ReefAngel.PWM.SetActinic( MoonPhase ) Test for Meanwells
    ReefAngel.PWM.SetDaylight( PWMParabola(7,5,19,0,0,85,0) );
    ReefAngel.PWM.SetActinic( PWMParabola(6,5,21,0,0,85,0) );
    ///if ( ReefAngel.Timer[1].IsTriggered() )
          ///  ReefAngel.Timer[1].SetInterval(random(15,35));
          ///  ReefAngel.Timer[1].Start();
           /// ReefAngel.Relay.Toggle(Port5);
          ///  ReefAngel.Relay.Toggle(Port6);
    if (hour()>=6 && hour()<20)
    analogWrite(lowATOPin,0);
    analogWrite(lowATOPin,(int)MoonPhase()*2.55);
I got it to upload. But is there any reason my client suite isn't connecting based on the code above?
