vortech/radion control
hi there folks!
i am really happy with my controller!
but i was thinking how cool would be have the control of the Ecotech Radion or Vortech in the app.
cheers!
erick
cheers!
erick
Re: vortech/radion control
I use Android app and it works awesome!!!
I can change modes and stuff from anywhere I get 3G signal
i can't do it with iphone app, the app it's awesome but the only parameters i can change is heater, standards lights and dosing pump :/
should i buy androi phone
I think the iPhone has a custom memory field that you can use.
The memory locations are:
Mode - 855
Speed - 856
Duration - 857
Mode - 855
Speed - 856
Duration - 857
Yes, the iPhone does have a custom memory field. So you can use those locations.rimai wrote:I think the iPhone has a custom memory field that you can use.
Mode - 855
Speed - 856
Duration - 857
thanks guys but i trying and the app keep crashing instead of update..
just quick question:
it;s that code right?
//#define Constant 0
//#define Random1 1 // Lagoonal
//#define Random2 2 // Reef Crest
//#define ShortWave 3
//#define LongWave 4
//#define Smart_NTM 5 // Nutrient Transport Mode
//#define Smart_TSM 6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop 8
//#define Night 9
//#define Slave_Start 97
//#define Slave_Stop 98
//#define None 99
ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
ReefAngel.RF.SetMode(Slave_Start,0,0);
If you get a compile error similar to this:
'class ReefAngelClass' has no member named 'RF'
Please make sure that you enabled RF Expansion on your features file.
Open RAGen and make sure you have RF Expansion checked under the Features tab.
Or, you can manually edit the file.
The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
#define RFEXPANSION
InternalMemory.RFMode_write(855);
InternalMemory.RFSpeed_write(856);
InternalMemory.RFDuration_write(857);
ReefAngel.Refresh();
if (ReefAngel.Joystick.IsButtonPressed())
ReefAngel.RF.SetMode(Slave_Stop,0,0);
ReefAngel.LCD.DrawText(0,255,50,60,"Done");
pilonstar wrote:thanks guys but i trying and the app keep crashing instead of update..
I will check it out. Make sure you are running the latest version. Just uninstall and re-download from the app store. Sometimes it doesnt update properly.
Yes, it is correct.pilonstar wrote:just quick question:
Thanks heaps!
I just received my Expansion and R+ with lots of memory!
I have really hard time to setup my vortech
Finished to swap over the new board and wondering how I can get control of my Radion and the
only code I have is:
here is my silly questions:
Where to put it?
internal memory or RA code?
once it's upload, how i can setup storms from any app or java?
thank you so much for your time and help
ReefAngel.RF.RadionChannels[Radion_Intensity]=75;
ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(12,0,18,0,0,100,0);
ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(9,0,22,0,0,100,0);
ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,22,0,0,5,0);
ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,22,0,0,10,0);
ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(10,0,21,0,0,60,0);
if (second()==0) ReefAngel.RF.RadionWrite();
Where to put it?
Let's start with the vortech.
Did you sync them to the controller?
Hi Roberto:rimai wrote:Let's start with the vortech.
Yes it does work and I can change the mode by wireless but the radion doesn't sync when I change the mode in the vortech memory
Your radions need to be restored to factory settings.
When you do that, they will pick up the signal from the controller and start adjusting accordingly.
give me o for awesome!
thanks for your fast reply, i will try tonight.
i am wonder if the storm mode is the same in vortech than Radion?
I have changed to factory settings and does not sync when i change modes in my vortech
should I add a new chanel in the memory?
here is:
// Autogenerated file by RAGen (v1.2.2.171), (05/02/2012 22:36)
// RA_050212_2236.ino
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
// Globals Needed for Params on Custom Main
byte x,y;
byte vtechmode;
boolean bFeeding=false;
byte PWMChannel[]={
0,0,0,0,0,0};
int v;
//Top Banner
ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Erick&SooZ ReeF ");
// Display T1 Header Text
ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
// Display the T1 Temp Value
char text[7];
ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
// Display the T2 Header Text
ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Room");
// Display the T2 Temp Value
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
// Display pH Header Text
ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
// Display pH Value
ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
// Display Vortech MP40wES Mode Header Text
ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
// Display EcoSmart Mode Value
ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
ReefAngel.LCD.DrawGraph(5, 5);
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.Relay.On(Port2);
ReefAngel.Relay.On(Port3);
ReefAngel.Relay.On(Port5);
ReefAngel.Relay.On(Port7);
ReefAngel.Relay.On(Port8);
ReefAngel.SingleATOLow(Port1);
ReefAngel.StandardLights(Port4);
ReefAngel.StandardFan(Port6);
ReefAngel.Portal("pilonstar", "whatupbrah");
//------------------------------ Start Feeding Mode Schedule (Start 1st Feeding at 9:55 AM and 2nd at 1:55 PM)---------------------
// if the hour is 9a or 1p, minute is 55 and seconds is 0
// start the feeding mode
if ( ((hour() == 9) || (hour() == 13)) &&
(minute() == 55) &&
(second() == 0) )
ReefAngel.FeedingModeStart();
vtechmode = InternalMemory.RFMode_read();
//------------------------------------------------------ End of Feeding Mode Schedule ---------------------------------------------
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
if (hour() >=8 && hour() <= 22)
if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
bFeeding=false;
ReefAngel.RF.UseMemory=false;
ReefAngel.RF.SetMode(Smart_NTM,155,5);
ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
ReefAngel.Timer[4].Start();
vtechmode = 5;
if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
ReefAngel.RF.UseMemory=true;
//---------------------------------------------------------- End RF Daytime Control -----------------------------------------------
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
vtechmode = 9;
ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
Confused.
What are you talking about?
The vortechs don't sync or the radions don't sync?
Did you sync the vortechs? Are they working as intended?
Sorry I didn't mean to confused you.rimai wrote: Confused.
What happened with my code, I can control the Vortech modes but the
Radion modes doesn't change, it looks like it send a signal to the radion but i doesn't change any
of the modes and i think is my PDE
So what I am trying to setup is a code i can change the radion modes like storm mode lighting mode or
day cycle.
Can you help with the modes please?
thanks for your time.
Erick
Unfortunately not, I'll trying to add radion.memory I the memory with no luck
The radion cannot be programmed to any mode.
You need to reset to factory settings and leave it like that. I think it's called basic mode.
If you have more than 1, you can't sync them together either, or they will just override the RA commands.
In basic mode, they will start accepting the commands from RA.
Hi Robertorimai wrote:The radion cannot be programmed to any mode.
I have updated my memory and it include radion section! Yay!
That means i can try to make the storm mode?
Any chance to copy the mode from the driver?
Storm mode would be amazing!
I'm working on that.
Apparently the storm mode is not avaialble the same way as if you were running the ecotech software.
awesome! you are the man with the master plan!
I was trying before fading the white/blue for seconds and it didn't work... just make it go crazy and just
freeze everything...I will keep trying with careful, but with the radion in the memory make the job much more easy.
thanks Mr Rimai!
thanks Mr Rimai!
You will need to update firmware on your module.
This will generate a unique mode, only available to RA users, which pulses the Vortech pumps differently and also will trigger lighttning effects on the Radion fixtures
- Download and unzip the attached file.
- Edit the file updateStorm.bat on notepad or your prefered editor.
- Change the COM port to the same one you use to upload codes to RA.
- Save and close the file.
- Open the module
- Remove the Ecotech RF module
- Connect the USB-TTL cable like in this photo: http://i761.photobucket.com/albums/xx25 ... 144436.jpg
- Double-click the file updateStorm.bat to execute it.
- You will see the module blinking red just like you were uploading code to RA.
- When done uploading, plug the Ecotech RF module back in.
- Close the module
- updateStorm.zip
- (424.94 KiB) Downloaded 755 times
Mr Rimai, you are a Genius!
thank you so much! Really appreciated!
If you ever want to go back to the original firmware, here it is.
- update.zip
- (423.63 KiB) Downloaded 674 times
Excellent, I had a few issues with the modes and the firmware when I tried to install.rimai wrote:If you ever want to go back to the original firmware, here it is.
I am running windows in a virtual machine and I didn't have libusb0.dll. At the beginning
the Ms-dos windows just closed in two seconds so I add this to the .dat file:
@echo off
cmd
Thank you so much Roberto again, I will post a video with the storm mode soon.
Erick.
Is there a way to add more points on the light spectrum curves?
I am trying to recreate this:
