WiFi Help
fatman
WiFi Help
Post by fatman »
I've had it running, now it went down and I can't get a connection. I've forwarded port 2000 to the wifi attachment internal IP, set up a DDNS service with no-ip.com and included the user address in my iPhone and the portal. I keep getting a bad address on the portal and the iPhone app won't work.
Used the WiFi utility to set it all up. Worked yesterday, but not today.
At this point I have the first status light slow blinking, the second and third blue ones blinking alternately with first one.
Anyone have a suggestion?
Fat
Re: WiFi Help
If you have blue light, it means it is not connected to your router.
Try factory reset and do over again.
fatman
WiFi Help
Post by fatman »
Will do. Tried that a few times without success, but will try again in a bit. Thanks for the quick response.
fatman
WiFi Help
Post by fatman »
Ok, reset it to factory settings, updated the firmware, reinstalled the setup program, reset the ddns account and updated the portal. Still can't see the controller. I have port 2000 forwarded to the correct ip. Pinging the ddns name takes me to my ISP ip but I get no response from it. Any suggestions?
Hard part is that it worked yesterday then died on me.
Re: WiFi Help
Do you still have blue led blinking?
Sent from my SPH-D700 using Tapatalk 2
fatman
Re: WiFi Help
Post by fatman »
No, the blue light is out.
Re: WiFi Help
Are you able to browse the controller using the internal ip?
http://myipaddress:2000
fatman
Re: WiFi Help
Post by fatman »
No. Can't get it through the internal IP.
Re: WiFi Help
What code did you load in your controller?
Can you load the WifiTestCode?
File->Sketchbook->Example Codes->WifiTestCode
fatman
Re: WiFi Help
Post by fatman »
Yes.
fatman
Re: WiFi Help
Post by fatman »
Just tried to reload the WifiTestCode and it gets hung up. Keep getting failed to send command and time out errors.
fatman
Re: WiFi Help
Post by fatman »
Here is the setup message I have been getting. This is after a factory restore.
* Please, select a serial port and click the "Connect" button
Opening Serial Port...
Verifying speed at 9600 baud
Connected to serial port COM4
> set u b 57600
> set s p 0
> save
> reboot
Removing connection to COM4
> set u b 57600
> set s p 0
> save
> reboot
Verifying speed at 57600 baud
< CMD
> reboot
< reboot
Wifi Attachment Connected to COM4
< CMD
< ls
< FL# SIZ FLAGS
< 2 20 3 WiFly_GSX-2.32
> ls
< 22 11 3 wps_app
< 33 1 10 config
< 34 20 3 WiFly_GSX-2.32
< 54 11 3 wps_app
< 65 1 10 user
< 190 Free, Boot=34, Backup=2
< <2.32>
< load user
< AOK
> load user
< <2.32>
< save
< Storing in config
> save
< <2.32>
< save
< Storing in config
> save
< <2.32>
> set o d ReefAngelWifi
< set o d ReefAngelWifi
< AOK
< <2.32>
> set w s dd-wrt
< set w s dd-wrt
< AOK
< <2.32>
> set w p
< set w p
< AOK
< <2.32>
< AOK
< <2.32>
< save
< Storing in config
> save
< <2.32>
> reboot
< reboot
< CMD
< show n
< SSid=dd-wrt
< Chan=1
> show n
< Assoc=FAIL
< Rate=12, 24Mb
< Auth=FAIL
< Mode=NONE
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=0
< <2.32>
> get i
< get i
< IF=DOWN
< DHCP=ON
< IP=10.1.10.101:2000
< NM=255.255.255.0
< GW=10.1.10.1
< HOST=198.171.134.6:80
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.32>
> reboot
< reboot
Found router router
< CMD
> ls
< ls
< FL# SIZ FLAGS
< 22 11 3 wps_app
< 33 1 10 config
< 54 11 3 wps_app
< 65 1 10 user
< <2.32>
< load user
< AOK
< <2.32>
> load user
< save
> save
< Storing in config
< <2.32>
> save
< save
< Storing in config
< <2.32>
< AOK
< <2.32>
< set w s dd-wrt
> set w s dd-wrt
< AOK
< <2.32>
> set w p
< set w p
< AOK
< <2.32>
< AOK
< <2.32>
< save
< Storing in config
> save
< <2.32>
< reboot
> reboot
< CMD
< show n
< SSid=dd-wrt
< Chan=6
> show n
< Assoc=FAIL
< Rate=0, 1 Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
< Boot=0
< Time=OK
< Links=1
< <2.32>
< get i
< IF=DOWN
> get i
< DHCP=ON
< IP=0.0.0.0:2000
< NM=0.0.0.0
< GW=0.0.0.0
< PROTO=TCP,
< MTU=1524
< FLAGS=0x6
< TCPMODE=0x0
< BACKUP=0.0.0.0
< <2.32>
> reboot
< reboot
Found router router
Port 2000 is now being forwarded to 0.0.0.0
Re: WiFi Help
< Assoc=FAIL
< Rate=0, 1 Mb
< Auth=OK
< Mode=WPA2
< DHCP=FAIL
That means it is not associating and not getting an ip from the router.
The SSID and passphase are case sensitive. Make sure that you type it just like it is setup in the router.
