vortech/radion control
pilonstar
Post by pilonstar »
hi there folks!
i am really happy with my controller! 8-)
but i was thinking how cool would be have the control of the Ecotech Radion or Vortech in the app.
:oops:
cheers!
erick
Slow down to speed up
Re: vortech/radion control
Which app are you referring to?
I use Android app and it works awesome!!! :)
I can change modes and stuff from anywhere I get 3G signal :shock:
pilonstar
Post by pilonstar »
i can't do it with iphone app, the app it's awesome but the only parameters i can change is heater, standards lights and dosing pump :/
should i buy androi phone :P
I think the iPhone has a custom memory field that you can use.
The memory locations are:
Mode - 855
Speed - 856
Duration - 857
rimai wrote:I think the iPhone has a custom memory field that you can use.
Mode - 855
Speed - 856
Duration - 857
Yes, the iPhone does have a custom memory field. So you can use those locations.
pilonstar
Post by pilonstar »
thanks guys but i trying and the app keep crashing instead of update.. :|
pilonstar
Post by pilonstar »
just quick question:
it;s that code right?
//#define Constant      0
//#define Random1       1 // Lagoonal
//#define Random2       2 // Reef Crest
//#define ShortWave     3
//#define LongWave      4
//#define Smart_NTM     5 // Nutrient Transport Mode
//#define Smart_TSM     6 // Tidal Swell Mode
//#define Feeding_Start 7
//#define Feeding_Stop  8
//#define Night         9
//#define Slave_Start   97
//#define Slave_Stop    98
//#define None          99
  ReefAngel.LCD.DrawText(0,255,20,50,"Assigning Slaves");
  ReefAngel.RF.SetMode(Slave_Start,0,0);
  If you get a compile error similar to this:
  'class ReefAngelClass' has no member named 'RF'
  Please make sure that you enabled RF Expansion on your features file.
  Open RAGen and make sure you have RF Expansion checked under the Features tab.
  Or, you can manually edit the file.
  The file is located at "Documents\Arduino\libraries\ReefAngel_Features.h" file and has to include this line in it:
  #define RFEXPANSION
  InternalMemory.RFMode_write(855);
  InternalMemory.RFSpeed_write(856);
  InternalMemory.RFDuration_write(857);
  ReefAngel.Refresh();
  if (ReefAngel.Joystick.IsButtonPressed())
    ReefAngel.RF.SetMode(Slave_Stop,0,0);
    ReefAngel.LCD.DrawText(0,255,50,60,"Done");
wolfador
Post by wolfador »
pilonstar wrote:thanks guys but i trying and the app keep crashing instead of update.. :|
I will check it out. Make sure you are running the latest version. Just uninstall and re-download from the app store. Sometimes it doesnt update properly.
John
ReefAngel and ReefAngel-HD developer
If the RA iOS app has helped please consider a donation
pilonstar wrote:just quick question:
Yes, it is correct.
pilonstar
Post by pilonstar »
Thanks heaps! :)
I just received my Expansion and R+ with lots of memory! :P
I have really hard time to setup my vortech :?
Finished to swap over the new board and wondering how I can get control of my Radion and the
only code I have is:
ReefAngel.RF.RadionChannels[Radion_Intensity]=75;
  ReefAngel.RF.RadionChannels[Radion_White]=PWMParabola(12,0,18,0,0,100,0);
  ReefAngel.RF.RadionChannels[Radion_RoyalBlue]=PWMParabola(9,0,22,0,0,100,0);
  ReefAngel.RF.RadionChannels[Radion_Red]=PWMParabola(9,0,22,0,0,5,0);
  ReefAngel.RF.RadionChannels[Radion_Green]=PWMParabola(9,0,22,0,0,10,0);
  ReefAngel.RF.RadionChannels[Radion_Blue]=PWMParabola(10,0,21,0,0,60,0);
  if (second()==0) ReefAngel.RF.RadionWrite();
here is my silly questions:
Where to put it?
internal memory or RA code?
once it's upload, how i can setup storms from any app or java?
thank you so much for your time and help
Let's start with the vortech.
Did you sync them to the controller?
pilonstar
Post by pilonstar »
rimai wrote:Let's start with the vortech.
Hi Roberto:
Yes it does work and I can change the mode by wireless but the radion doesn't sync when I change the mode in the vortech memory :cry:
Your radions need to be restored to factory settings.
When you do that, they will pick up the signal from the controller and start adjusting accordingly.
pilonstar
Post by pilonstar »
give me o for awesome!
thanks for your fast reply, i will try tonight.
i am wonder if the storm mode is the same in vortech than Radion?
:o
pilonstar
Post by pilonstar »
I have changed to factory settings and does not sync when i change modes in my vortech :(
should I add a new chanel in the memory?
pilonstar
Post by pilonstar »
here is:
// Autogenerated file by RAGen (v1.2.2.171), (05/02/2012 22:36)
// RA_050212_2236.ino
#define wifi
#define SIMPLE_MENU
#define PWMEXPANSION
#define CUSTOM_MAIN
#define COLORS_PDE
#define ENABLE_ATO_LOGGING
#define RFEXPANSION
#define FONT_8x16
#define NUMBERS_8x16
// Globals Needed for Params on Custom Main
byte x,y;
// Globals Needed for RF Mode on Custom Main
byte vtechmode;
boolean bFeeding=false;
byte PWMChannel[]={
0,0,0,0,0,0};
int v;
            //Top Banner
        ReefAngel.LCD.DrawText(COLOR_BLACK, COLOR_SKYBLUE, 9, 2, " Erick&SooZ ReeF ");
               // Display T1 Header Text
        ReefAngel.LCD.DrawText(COLOR_CORNFLOWERBLUE,255,8,14,"Tank");
        // Display the T1 Temp Value
        char text[7];
        ReefAngel.LCD.Clear(255, 4, 21, 37, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE, 255, 4, 24, text, Num8x16);
        // Display the T2 Header Text
        ReefAngel.LCD.DrawText(COLOR_CRIMSON,255,52,14,"Room");
        // Display the T2 Temp Value
        ReefAngel.LCD.Clear(255, 52, 21, 75, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_CRIMSON, 255, 52, 24, text, Num8x16);
        // Display pH Header Text
        ReefAngel.LCD.DrawText(COLOR_INDIGO,255,108,14,"pH");
        // Display pH Value
        ReefAngel.LCD.Clear(255, 94, 21, 106, 37);
        ReefAngel.LCD.DrawLargeText(COLOR_INDIGO, 255, 94, 24, text, Num8x16);
        // Display Vortech MP40wES Mode Header Text
        ReefAngel.LCD.Clear(DefaultFGColor,5,39,127,39);
        ReefAngel.LCD.DrawText(0,255,18,42,"EcoSmart Vortech");
        // Display EcoSmart Mode Value
        ReefAngel.LCD.Clear(255, 1, 49, 128, 64);
        if (vtechmode == 0) ReefAngel.LCD.DrawLargeText(COLOR_LIMEGREEN,255,35,50,"Constant");
        else if(vtechmode == 1) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,42,50,"Lagoon");
        else if (vtechmode == 2) ReefAngel.LCD.DrawLargeText(COLOR_GOLD,255,25,50,"Reef Crest");
        else if (vtechmode == 3) ReefAngel.LCD.DrawLargeText(COLOR_CORNFLOWERBLUE,255,22,50,"Short Pulse");
        else if (vtechmode == 4) ReefAngel.LCD.DrawLargeText(COLOR_PINK,255,25,50,"Long Pulse");
        else if (vtechmode == 5) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,8,50,"Nutrient Trnsp.");
        else if (vtechmode == 6) ReefAngel.LCD.DrawLargeText(COLOR_MAGENTA,255,23,50,"Tidal Swell");
        else if (vtechmode == 9) ReefAngel.LCD.DrawLargeText(COLOR_WHITE,0,45,50,"Night");
         ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
    ReefAngel.SetTemperatureUnit(1);  // set to Celsius Temperature
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit;
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.On(Port3);
    ReefAngel.Relay.On(Port5);
    ReefAngel.Relay.On(Port7);
    ReefAngel.Relay.On(Port8);
    ReefAngel.SingleATOLow(Port1);
    ReefAngel.StandardLights(Port4);
    ReefAngel.StandardFan(Port6);
    ReefAngel.Portal("pilonstar", "whatupbrah");
//------------------------------ Start Feeding Mode Schedule (Start 1st Feeding at 9:55 AM and 2nd at 1:55 PM)---------------------
    // if the hour is 9a or 1p, minute is 55 and seconds is 0
    // start the feeding mode
    if ( ((hour() == 9) || (hour() == 13)) &&
       (minute() == 55) &&
       (second() == 0) )
      ReefAngel.FeedingModeStart();
      vtechmode = InternalMemory.RFMode_read();
//------------------------------------------------------ End of Feeding Mode Schedule ---------------------------------------------
//-------------------------------------------------------- Start RF Daytime Control -----------------------------------------------
  if (hour() >=8 && hour() <= 22)
    if (ReefAngel.DisplayedMenu==FEEDING_MODE) bFeeding=true;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && bFeeding )
      bFeeding=false;
      ReefAngel.RF.UseMemory=false;
      ReefAngel.RF.SetMode(Smart_NTM,155,5);
      ReefAngel.Timer[4].SetInterval(1800); // Timer for 30min
      ReefAngel.Timer[4].Start();
      vtechmode = 5;
    if (ReefAngel.DisplayedMenu==DEFAULT_MENU && ReefAngel.Timer[4].IsTriggered())
      ReefAngel.RF.UseMemory=true;
//---------------------------------------------------------- End RF Daytime Control -----------------------------------------------
//-------------------------------------------------------- Start RF Nightmode Control ---------------------------------------------
  if (hour()>=23 || hour()<7) // Defining "Nightmode" hours for VorTech = between 11 PM and 7 AM
      vtechmode = 9;
      ReefAngel.RF.SetMode(Feeding_Stop,0,0); //Temp fix for coming out of Night mode
//---------------------------------------------------------- End RF Nightmode Control ---------------------------------------------
//------------------------------------------------------ End Time-of-Day Based Functions ------------------------------------------
//--------------------------------------------------------------- End Loop --------------------------------------------------------
:? Confused.
What are you talking about?
The vortechs don't sync or the radions don't sync?
Did you sync the vortechs? Are they working as intended?
pilonstar
Post by pilonstar »
rimai wrote::? Confused.
Sorry I didn't mean to confused you. :oops:
What happened with my code, I can control the Vortech modes but the
Radion modes doesn't change, it looks like it send a signal to the radion but i doesn't change any
of the modes and i think is my PDE :(
So what I am trying to setup is a code i can change the radion modes like storm mode lighting mode or
day cycle.
Can you help with the modes please?
thanks for your time.
Erick
Is it dimming?
pilonstar
Post by pilonstar »
Unfortunately not, I'll trying to add radion.memory I the memory with no luck :(
The radion cannot be programmed to any mode.
You need to reset to factory settings and leave it like that. I think it's called basic mode.
If you have more than 1, you can't sync them together either, or they will just override the RA commands.
In basic mode, they will start accepting the commands from RA.
pilonstar
Post by pilonstar »
rimai wrote:The radion cannot be programmed to any mode.
Hi Roberto :)
I have updated my memory and it include radion section! Yay!
That means i can try to make the storm mode?
Any chance to copy the mode from the driver?
Storm mode would be amazing! :lol:
I'm working on that.
Apparently the storm mode is not avaialble the same way as if you were running the ecotech software.
pilonstar
Post by pilonstar »
awesome! you are the man with the master plan!
I was trying before fading the white/blue for seconds and it didn't work... just make it go crazy and just
freeze everything...I will keep trying with careful, but with the radion in the memory make the job much more easy.
thanks Mr Rimai! ;)
You will need to update firmware on your module.
  • Download and unzip the attached file.
  • Edit the file updateStorm.bat on notepad or your prefered editor.
  • Change the COM port to the same one you use to upload codes to RA.
  • Save and close the file.
  • Open the module
  • Remove the Ecotech RF module
  • Connect the USB-TTL cable like in this photo: http://i761.photobucket.com/albums/xx25 ... 144436.jpg
  • Double-click the file updateStorm.bat to execute it.
  • You will see the module blinking red just like you were uploading code to RA.
  • When done uploading, plug the Ecotech RF module back in.
  • Close the module
After you update the firmware, you can just change the mode of the module to 10 (Storm mode).
This will generate a unique mode, only available to RA users, which pulses the Vortech pumps differently and also will trigger lighttning effects on the Radion fixtures :shock:
pilonstar
Post by pilonstar »
Mr Rimai, you are a Genius! :shock:
thank you so much! Really appreciated! :D
If you ever want to go back to the original firmware, here it is.
pilonstar
Post by pilonstar »
rimai wrote:If you ever want to go back to the original firmware, here it is.
Excellent, I had a few issues with the modes and the firmware when I tried to install.
I am running windows in a virtual machine and I didn't have libusb0.dll. At the beginning
the Ms-dos windows just closed in two seconds so I add this to the .dat file:
@echo off
cmd
and then I could read the error.
Thank you so much Roberto again, I will post a video with the storm mode soon.
:D
Erick.
alexwbush
Post by alexwbush »
Is there a way to add more points on the light spectrum curves?
I am trying to recreate this:
