I have this and mine is a hour slow, i could wait to the daylight savings to fix it or find out how.
I used the wizard to generate it.
Anthony
ReefAngel.LightsOnPorts = Port6Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port7Bit;
ReefAngel.StandardLights( Port3,11,0,15,30 );
ReefAngel.StandardLights( Port4,15,0,19,30 );
ReefAngel.StandardLights( Port5,18,0,10,0 );
ReefAngel.StandardLights( Port6,9,0,21,15 );
ReefAngel.StandardHeater( Port7,768,786 );
ReefAngel.StandardLights( Port8,21,0,9,30 );
ReefAngel.PWM.SetDaylight( PWMSlope(9,0,20,0,15,100,60,15) );
ReefAngel.PWM.SetActinic( PWMSlope(9,0,20,0,15,100,60,15) );
int x,y;
// Parameters
ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor( 15, 26, ReefAngel.Params );
// ORP
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,75,78, "ORP:" );
ReefAngel.LCD.DrawText( COLOR_PALEVIOLETRED,DefaultBGColor,99,78, ReefAngel.Params.ORP );
// Main Relay Box
ReefAngel.LCD.DrawOutletBox( 12, 112, TempRelay );
// Date and Time
Add time/date set up to my menu?
saltwaternoob
150g 1" Acrylic Reef 48x32x24
24g picasso clown tank
Re: Add time/date set up to my menu?
Try adding this just below ReefAngel.Init();
ReefAngel.AddDateTimeMenu();
saltwaternoob
Worked perfect thanks
