I'm using a code generate by wizard and the ra display doesn't draw any graph, while ports, Ts, pH and lights are updated. Did I forget something?
Another question, can I print on ra display date and time in format: dd/mm/yy and 18:21:04 (i.e.)?
Stephy
No graph on RA display
stephy
Stephy
Re: No graph on RA display
It will strip out the graph if you enable some expansions.
Which ones do you have?
The time and date can't be displayed in military time
stephy
wifi and rf. Windows client works well, portal sometimes fails (I haven't configured dyndns yet).rimai wrote:It will strip out the graph if you enable some expansions.
Stephy
