Relay Activity on Portal
Related to the Portal
Sebyte
Post by Sebyte »
The portal is working ok and retrieving the data on the relays. But I have noticed one anomaly on my system.
I only have one wave maker pump at this time which is connected to port5. I turn off the wave maker from 9pm to 10am, using this code.
  // Wavemaker not available 9 pm to 10 am
  if ( (hour() >= 20) || (hour() <= 9) )
    ReefAngel.Relay.Off(Port5);
When checking the Portal this morning I noticed that the relay activity seems to have been continuing during the "off period", when in fact the wave maker was definitely off. The code is what I used before moving to v0.9.0.
Should I be using a different code to ensure that port5 is not available during the 9pm to 10am time period, and the real relay activity is captured?
Many thanks.
Re: Relay Activity on Portal
If you have overridden the port to be always ON, then it will not shutoff. You should make sure the port is actually set to AUTO on the portal. Otherwise if it is forced ON or OFF, that forcing will override your other schedule.
The overriding is handled inside the Write function with this code:
    byte TempRelay = RelayData;
    TempRelay &= RelayMaskOff;
    TempRelay |= RelayMaskOn;
This has to be there, otherwise you could never override a port and turn it on/off at your desire.
Sebyte
Post by Sebyte »
All of the relay ports were set to Auto in the portal.
It would seem then that the Portal is reporting the logic state of the relay, and not the actual state as controlled by the override code.
Just to clarify so that I get the instructions right for the next version of my guide.
Am I right in thinking that the code you show has to be "hand coded" into the .ino file and is not auto generated. Also that it should be in the void setup() section of the code?
Thanks again.
The Portal should show the actual state of the relay.
The calculation is already done within the portal.
Let me investigate what is going on.
Sebyte
Post by Sebyte »
Roberto
Just had another look, and I don't see any activity on port2 which is my ATO. This is another port which I control when it can be available. I can send the code if you need it.
Here is the compromise I had to make. :(
I initially had the Portal sending data every 5 minutes.
Then, talking to Dave, Curt and John, we came to realize that it would be nice to have it send every relay toggle.
So, I made the changes and started monitoring.
This made the database grow immensely very fast and I would soon be battling space issues.
So, I had to decide to go back and only send data every 5 minutes.
At the present moment, the portal only receives data every 5 minutes, which means if the ATO event happens anywhere in between this 5 minutes, you won't see any activity on the Portal.
I'm still studying other options to get this problem resolved.
Seems like I'm getting the port5 toggle.
I get 33 (B00100001) and 49 (B00110001) over and over.
I also get ROFF=255 and RON=0, which means that the relay is on auto mode.
Did you confirm that the powerhead goes out at night?
Can I see the entire code?
Sebyte
Post by Sebyte »
The WM was definitely off, it went offline at last night as usual and when I checked this morning it was still off until 10:00. I also watched the ports on the RA controller and there was no activity on port5 until 10:00.
My .ino file is not complex as you will see.
// Autogenerated file by RAGen (v1.2.1.158), (02/17/2012 15:06)
// RA_021712_1506.ino
// This version designed for v0.9.0 or later
/* The following features are enabled for this File:
#define DateTimeSetup
#define VersionMenu
#define wifi
#define WDT
#define SIMPLE_MENU
#include <Globals.h>
#include <RA_Wifi.h>
#include <Wire.h>
#include <OneWire.h>
#include <Time.h>
#include <DS1307RTC.h>
#include <InternalEEPROM.h>
#include <RA_NokiaLCD.h>
#include <RA_ATO.h>
#include <RA_Joystick.h>
#include <LED.h>
#include <RA_TempSensor.h>
#include <Relay.h>
#include <RA_PWM.h>
#include <Timer.h>
#include <Memory.h>
#include <ReefAngel.h>
    ReefAngel.FeedingModePorts = Port6Bit;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.OverheatShutoffPorts = Port7Bit | Port8Bit;
    ReefAngel.Relay.On(Port1);
    ReefAngel.Relay.On(Port6);
    // Specific functions
    ReefAngel.StandardATO(Port2,1000); // ",1000" added to stop ATO after 1000 seconds because of slow fill rate (18-02-12)
    ReefAngel.StandardFan(Port4);
    ReefAngel.Wavemaker1(Port5);
    ReefAngel.StandardLights(Port7);
    ReefAngel.MHLights(Port8);
    ReefAngel.Portal("sebyte", "*********");
    // ATO available 6 times per day - 00:00 to 01:00, 04:00 to 05:00, 08:00 to 09:00, 12:00 to 13:00, 16:00 to 17:00, 20:00 to 21:00,
  if (hour() % 4 == 0 && ReefAngel.LowATO.IsActive()) //Rev made 19/11/11
    ReefAngel.Relay.On(Port2);
    ReefAngel.Relay.Off(Port2);
  // Kalk Reactor available 6 times per day - 01:30 to 2:00, 05:30 to 06:00, 09:30 to 10:00,
  // 13:30 to 14:00, 17:30 to 18:00, 21:30 to 2:00.
  if (hour() % 4 == 1 && minute()>30)
    pinMode(highATOPin,OUTPUT);
    digitalWrite(highATOPin,HIGH); // Turn on Solid State Relay
    digitalWrite(highATOPin,LOW); // Turn off Solid State Relay
     // Web Banner stuff
   // if(ReefAngel.Timer[4].IsTriggered())
   // ReefAngel.Timer[4].Start();
   // ReefAngel.WebBanner();
Ahhh.
You have to place the portal line after your checks or it won't pick up the changes.
The best is to place it above ShowInterface(). That way, you know it is getting the latest changes.
Sebyte
Post by Sebyte »
Ok, I understand. But that is the line generated by RAgen, so if it should be at the end of the loop, either RAgen needs to place it there, or we need to document this!
Perhaps a // Place holder for "your code goes here" // could be included in the auto generated code?
I will alter the code and see what happens later. As for the ATO, I now understand that short bursts will not be recorded because of the sampling time scale.
Thanks Roberto.
Yeah, totally agree on the documenting it :)
When RAGen generates the code, the Portal line is placed just above the ShowInterface().
The extra code was added manually by you.
So, what if we placed comment lines like this:
    // Place your custom code below
    // Place your custom code above
    ReefAngel.Portal("username", "key");
That would make it very clear for everyone where to place their custom code.
What do you think of this solution?
Should've read your post better before posting mine :(
Sebyte
Post by Sebyte »
That's the way to go ;)
Sebyte wrote:That's the way to go ;)
Ok, "twist my arm" to add it into RAGen. ;-)
Man, you guys are keeping me busy with all these additions. :geek:
Sebyte
Post by Sebyte »
More Kudos to you :P
Junior Dabul
Post by Junior Dabul »
sorry for jump in.
My relay activity on the portal shows "no data" and the dashboard doesnt show any activity too. unless i change to auto.
as far as i understood i have to set the RA to send data to it ,right??? or the client suit?. Once my client suit is not working properly by the expansion relay communication version (waiting the new 3.0), i may have to set the controller to send it.
this is my banner :
http://forum.reefangel.com/status/banne ... ?id=Junior Dabul&t=10 this is my banner code
how should be and where to place the code to send the data???
I will try this one below but its something wrong. its doesnt verify on Arduino. i havent upload yet.
#include <avr/pgmspace.h>
prog_char id_label[] PROGMEM = "junior";
prog_char probe1_label[] PROGMEM = "Water";
prog_char probe3_label[] PROGMEM = "light";
prog_char relay1_label[] PROGMEM = "ATO";
prog_char relay2_label[] PROGMEM = "Actinic & Daylight";
prog_char relay3_label[] PROGMEM = "Moonlight";
prog_char relay4_label[] PROGMEM = "Chiller";
prog_char relay5_label[] PROGMEM = "Wavemaker 1";
prog_char relay6_label[] PROGMEM = "Wavemaker 1";
prog_char relay7_label[] PROGMEM = "Heater";
prog_char relay8_label[] PROGMEM = "Return";
#ifdef RelayExp
#if InstalledRelayExpansionModules >= 1
prog_char relay11_label[] PROGMEM = "Sump Light";
prog_char relay12_label[] PROGMEM = "UV light";
prog_char relay13_label[] PROGMEM = "Skimmer";
prog_char relay14_label[] PROGMEM = "Wavemaker 3";
prog_char relay15_label[] PROGMEM = "Phos Reactor";
prog_char relay16_label[] PROGMEM = "Carbon Reactor";
prog_char relay17_label[] PROGMEM = "Dosing Pump";
prog_char relay18_label[] PROGMEM = "Always On";
#endif // InstalledRelayExpansionModules >= 1
#endif // RelayExp
id_label, probe1_label, probe2_label, probe3_label,
relay1_label, relay2_label, relay3_label, relay4_label,
relay5_label, relay6_label, relay7_label, relay8_label,
#ifdef RelayExp
relay11_label, relay12_label, relay13_label, relay14_label,
relay15_label, relay16_label, relay17_label, relay18_label,
#endif // RelayExp
// Initialize and start the timer
ReefAngel.Timer[4].SetInterval(120); // set interval to 180 seconds
ReefAngel.SetTemperatureUnit(1); // set to Celsius Temperature
ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On(Box1_Port2);
ReefAngel.Relay.On(Box1_Port1); //UV Lights
ReefAngel.Relay.On(Box1_Port3); //Skimmer
ReefAngel.Relay.On(Box1_Port4); //GFO Reactor
ReefAngel.Relay.On(Box1_Port5); //Carbon Reactor
ReefAngel.Relay.On(Box1_Port8); //Always On
ReefAngel.StandardATO(Port1,60); //Setup Port1 as Auto Top-Off function with 60s timeout
ReefAngel.StandardLights(Port2,9,00,17,00); //Actinic and Daylights schedule 9:00am - 5:00pm
ReefAngel.StandardLights(Port3,22,30,5,0); //Moonlight schedule 10:30pm - 5:00am
ReefAngel.StandardFan(Port4,250,246); // Setup Chiller to turn on at 25.0C and off at 24.6C
ReefAngel.Wavemaker(Port5,300);
ReefAngel.Wavemaker(Port6,300);
ReefAngel.StandardHeater(Port7,242,250); // Setup Heater to turn on at 24.2C and off at 25.0C
ReefAngel.StandardLights(Box1_Port2,22,30,14,30); //Refugium schedule 10:30pm - 2:30pm
ReefAngel.Wavemaker(Box1_Port6,60); //Wavemaker on 60sec cycle
ReefAngel.DosingPump1(Box1_Port7); //DosingPump1
ReefAngel.Portal("juniordabul", "XXXXXXX");
if ( ReefAngel.Timer[4].IsTriggered() )
that is the error:
alteracoes_17apr.cpp.o: In function `loop':
C:\Users\JUNIOR~1\AppData\Local\Temp\build9090624217643483980.tmp/alteracoes_17apr.cpp:114: undefined reference to `ReefAngelClass::WebBanner()'
Try this:
 ReefAngel.Portal("Junior Dabul");
The WebBanner function() you were trying to use is deprecated.
It has been replaced with the Portal() function.
Also, I noticed that your forum username has a space and your Portal() function had no space.
I'm not sure if it will work, but work a try. The space may cause issues.
The reason you are not seeing the relay expansion is because you have the Client sending data and it is not ready to send the expansion box data just yet.
My suggestion is disable the Client sending data and use only the controller with the Portal() function.
Junior Dabul
the difference on space and no space is because the Client no recognize with the space and i had to put the user with no space.
just to make simple i tried change on the portal to have no space but i cannot.
i will try with the space as i believe if that's the way set up .So that is the way should be. if don't work i will try with no space.
About the client i know i have to wait to the new version.
The gadgets stopped working. i don't know. Suddenly it lost the IP and now when i put back seems doesn't recognize. doesn't show any activity. it show all the ports in both relays to set up but before when was working was showing the main relay and didnt show any the relay expansion. :(
Junior Dabul
I tried all. with space, without....all the same.....the portal connects but no relay extension or relay activity data.
i already set the client to not send the data.
If you use without the space, your forum username has to be without space too.
It tracks by the forum username
Junior Dabul
ok...so do you think i have to use without space???? because if you say yes i have to chance my ID name at the portal.
if you say yes, .....any chance to change or do i have to create another one????
let me know
Just a thought about spaces, since it is web based, would the %20 work instead of a space? So you would do something like this:
ReefAngel.Portal("Junior%20Dabul");
Would that work? I think it would be worth a try at least.
Junior Dabul
Hi Curt....it looks kind of working now with the %20.
W am new in here and dont know much about it. when i access the banner it show the activity on both relays (one expansion) but at the portal page on dashboard and relay activity still showing only the standard relay and no data on relay activity.
Other thing is on dash board when i access i show on OFF and when i change for Auto it show if the port is on or off. is that right????
Cheers
Junior Dabul wrote:Hi Curt....it looks kind of working now with the %20.
I don't know much about the Portal and all the sections of it. I haven't used the Portal much at all and it's still relatively new. Roberto or somebody else will have to comment on this one.
Yes.
When you are looking at the relay status on the portal page (the same with the /wifi page on the controller), if it says ON or OFF, that means the port is overridden and forced ON or OFF. The port will not change automatically based on the code on the controller. When it's set to AUTO, the port is running on its normal schedule. The color will be RED for OFF and GREEN for ON.
rossbryant1956
Re: Relay Expansion in Portal
Post by rossbryant1956 »
I can no longer see my relay box 1 in the portal. Relay box 0 works fine but 1 is not there. I checked features.h, even ran the test utilities, and they work just fine on both boxes. Please let me know what I am doing wrong. I have libs 9.9
// AutoGenerated file by Reef Angel Wizard
 * Copyright 2012 Reef Angel
 * Licensed under the Apache License, Version 2.0 (the "License")
#define SIMPLE_MENU
#define RelayExp
#define wifi
#define VersionMenu
#define WDT
#endif  // __REEFANGEL_FEATURES_H__
// Autogenerated file by RAGen (v1.2.1.158), (02/17/2012 22:55)
    ReefAngel.FeedingModePorts = Port5Bit | Port6Bit | Port8Bit; // Turn off Port 5, Port 6, Port8 when feeding mode is activated
    ReefAngel.WaterChangePorts = Port5Bit | Port6Bit | Port7Bit | Port8Bit; // Turn off Port5, Port6, Port7 and Port8 when water change mode is activated
    ReefAngel.TempProbe = T2_PROBE;  // Set the 1st plug (which acts like the 2nd plug)
    ReefAngel.OverheatProbe = T2_PROBE;  // to monitor the overheat and temperatures
    ReefAngel.Relay.On(Port8); // Turn on Pump
    ReefAngel.StandardLights(Port2,8,00,23,00); // Regular Lights on at 8:00am and off at 11:00pm
    ReefAngel.StandardLights(Port3,00,30,03,30); // Moon Lights on at 12:30am and off at 3:30am
    ReefAngel.StandardLights(Port4,23,30,14,30);  //Refugium schedule 11:30pm - 2:30pm
    ReefAngel.Wavemaker2(Port6);
    // Randomize the Timer
	static time_t timer=now()+15;
	if (now()>timer)
		timer=now()+random(15, 60);
	ReefAngel.WavemakerToggle(Port5, Port6, timer);
    // turn on port 7 when temp falls below 76.0 and turn off when temp gets above 80.0
    if (ReefAngel.Params.Temp[T2_PROBE] <= 780 && ReefAngel.Params.Temp[T2_PROBE] > 0) ReefAngel.Relay.On(Port7);
    if (ReefAngel.Params.Temp[T2_PROBE] >= 791) ReefAngel.Relay.Off(Port7);
    if (ReefAngel.Params.Temp[T1_PROBE] <= 780 && ReefAngel.Params.Temp[T1_PROBE] > 0) ReefAngel.Relay.On(Box1_Port1);
    if (ReefAngel.Params.Temp[T1_PROBE] >= 791) ReefAngel.Relay.Off(Box1_Port1);
    // if the hour is 8a or 6p, minute is 55 and seconds is 0
	// start the feeding mode
		if ( ((hour() == 8) || (hour() == 18)) &&
		(minute() == 55) &&
		(second() == 0) )
		ReefAngel.FeedingModeStart();
    ReefAngel.Portal("rossbryant1956");
rossbryant1956
My second expansion box just turned up on the portal but not the labels are gone. Strange.
Please add this anywhere in your code:
//Box1_
It's the new auto feature selection I developed that is kicking in.
There is no more such a thing as features file.
Anything you do to that file will just end up being modified by Arduino IDE.
It's looking for specific keywords to enable the expansion relay box.
rossbryant1956
it shows up in this line of code:
is that good enough or do I need a
//box1
thx
rossbryant1956
also weird, look at the sig line...my labels are there but not on the portal and are not defined in the code.
rossbryant1956 wrote:it shows up in this line of code:
//box1
thx
That's good enough.
Do you have the Client running?
