I just got the new board and I haven't popped it in yet, but I have a question about uploading code. I generated a new file with ReefAngel Generator, open Arduino and switch under tools>controller to "ReefAngel Plus"verify it and it is ok.
Then I open my current .INO file and cut and paste my custom code into the new ino generated by the RA Gen....But when I verify that, I keep getting errors I never saw before, ...it's long, too long to type, but starts with something like, "program files (x86) reefangel controller/hardware/tools/avr/bin etc"
What do I need to do to start the process of moving over to the RA plus board?
setting up ReefAngel plus
psyrob
Re: setting up ReefAngel plus
// Autogenerated file by RAGen (v1.2.2.171), (06/23/2012 21:48)
// RA_062312_2148.ino
#define DisplayImages
#define VersionMenu
#define DisplayLEDPWM
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MENU_ENTRIES 4
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define FONT_8x16
byte wmport=Port5;
boolean wmdelay=false;
#include <avr/pgmspace.h>
prog_char menu0_label[] PROGMEM = "Feeding Mode";
prog_char menu2_label[] PROGMEM = "ph calibrate";
prog_char menu3_label[] PROGMEM = "Clear Overheat";
menu0_label, menu1_label, menu2_label, menu3_label };
void MenuEntry1()
ReefAngel.DisplayMenuEntry("Item 1");
ReefAngel.FeedingModeStart();
void MenuEntry2()
ReefAngel.DisplayMenuEntry("Item 2");
void MenuEntry3()
ReefAngel.DisplayMenuEntry("Item 3");
ReefAngel.SetupCalibratePH();
void MenuEntry4()
ReefAngel.DisplayMenuEntry("Item 4");
ReefAngel.LCD.DrawDate(6, 120);
ReefAngel.LCD.DrawLargeText(COLOR_DARKTURQUOISE, COLOR_WHITE, 4, 4 , "ROB'S REEF ANGEL");
ReefAngel.LCD.Clear(COLOR_MAROON, 1, 13, 132, 13);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 75, 119, 75);
ReefAngel.LCD.Clear(COLOR_MAROON, 10, 59, 119, 59);
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, COLOR_WHITE, 8, 15, "Big Tank");
char text[7];
ReefAngel.LCD.DrawLargeText(COLOR_GOLDENROD, DefaultBGColor, 18, 30, text);
ReefAngel.LCD.DrawText(COLOR_RED, COLOR_WHITE,8,48,"Frag:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T3_PROBE], COLOR_RED, 40, 48, 10);
ReefAngel.LCD.DrawText(COLOR_DARKORCHID, COLOR_WHITE,70,48,"Room:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp[T2_PROBE], T2TempColor, 100, 48, 10);
ReefAngel.LCD.DrawLargeText(COLOR_MEDIUMSEAGREEN, COLOR_WHITE, 92, 15, "pH");
ReefAngel.LCD.DrawLargeText(PHColor, DefaultBGColor, 88, 30, text);
// Display arrows for Wavemaker
ReefAngel.LCD.DrawText(DPColor,DefaultBGColor, 5, 64,"WAVE FLOW:");
if (bitRead(ReefAngel.Relay.RelayData,Port5-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64,"----->"); //port 5 on
else if (bitRead(ReefAngel.Relay.RelayData,Port6-1)==1) ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64,"<-----"); //port 6 on
else ReefAngel.LCD.DrawText(APColor,DefaultBGColor, 67, 64," 00000 "); //port5 and port 6 off, wavemaker delay
//show the timer for wavemaker
int t=ReefAngel.Timer[1].Trigger-now();
if (t>=0)
ReefAngel.LCD.Clear(255,105,64,135,74);
ReefAngel.LCD.DrawText(APColor, COLOR_KHAKI,110,64,t);
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,79,"Actinic");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,89,"FragLt");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,99,"WM RT");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,10,109,"Fan");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,79,"ATO");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,89,"DayLts");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,99,"WM LFT");
ReefAngel.LCD.DrawText(COLOR_MEDIUMSEAGREEN,DefaultBGColor,80,109,"Heater");
ReefAngel.LCD.DrawCircleOutletBox(60, 81, TempRelay, true);
// Initialize the custom menu
ReefAngel.OverheatShutoffPorts = Port2Bit | Port3Bit | Port4Bit | Port7Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit | Port4Bit;
ReefAngel.Relay.On(Port1);
ReefAngel.MHLights(Port3);
ReefAngel.MHLights(Port4);
// ReefAngel.Wavemaker1(Port5);
//ReefAngel.Wavemaker2(Port6);
ReefAngel.StandardFan(Port8);
// PWMSlope based on Internal Memory values for Standard Lights
if ((hour() >= 21) || (hour() <= 8)) //from 9p-8a
if (wmdelay)
ReefAngel.Timer[1].SetInterval(60); // wm night delay
ReefAngel.Timer[1].Start();
ReefAngel.Relay.Off(Port5);
ReefAngel.Relay.Off(Port6);
if (wmport==Port5) wmport=Port6;
else wmport=Port5;
wmdelay=false;
ReefAngel.Timer[1].SetInterval(20); // short wave
ReefAngel.Relay.On(wmport);
wmdelay=true;
//8a-9p normal wave settings
ReefAngel.Timer[1].SetInterval(random(35,50));
if bitRead(ReefAngel.Relay.RelayData,Port5-1) ReefAngel.Relay.Off(Port6);
else ReefAngel.Relay.On(Port6);
// This sends all the data to the portal
// Do not add any custom code that changes any relay status after this line
// The only code after this line should be the ShowInterface function
ReefAngel.Portal("psyrob");
Wow man, that one is something else
It's a bug on the way Arduino is compiling the code.
You had it just right, I guess, to get that error
Murphy's law.
I couldn't figure out what the problem is, but the work around is to increase the size of your menu labels.
Anything should do.
I simply used "Water Change Mode" instead of "Water Changel" and the error went away...
Anything should do.
psyrob
Thanks Roberto, I made the change and it verified without a problem...
When I put in the RA+ board, do I just upload this code? Or do I have to upload an internal memory from RAGen first?
Best to upload an internal memory first to make sure you have all memory settings initialized.
psyrob
Roberto: I got the RA+ up and running, it booted up on its own with internal memory settings loaded...
I then uploaded my code and my wave maker is messed up....It was working to pick a random time between 35 and 50 seconds, then display the number counting down and an arrow to show which pump was running. At night there was an interval of no pumps running on the wavemaker and the screen would show "OOOO" as a result.
I added moonlights to this code and now the screen is showing the "OOOOO" constantly and there is a negative number showing that is only increasing as time goes on, it started at -160 and now is up to -223 and the wavemaker isnt working...what have I screwed up?
Here is the code...
Here is the code...
//This is the first try to upload to ReefAngel Plus Board, includes moonlights
#define VersionMenu
#define wifi
#define WDT
#define CUSTOM_MENU
#define CUSTOM_MAIN
#define COLORS_PDE
#define FONT_8x8
#define FONT_8x16
byte wmport=Port5;
prog_char menu1_label[] PROGMEM = "Water Change Mode";
void MenuEntry1()
void MenuEntry2()
void MenuEntry3()
void MenuEntry4()
char text[7];
if (t>=0)
// Set Actinic and Daylight off by default
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
if ( hour() <= 6 || hour () >= 22 ) // Moonlights on from 7PM to 7AM
if (wmdelay)
else wmport=Port5;
wmdelay=false;
wmdelay=true;
I think you need to initialize the timer 1.
Add this to your setup() section:
ReefAngel.Timer[1].SetInterval(1);
psyrob
