Main Menu Light Option
fatman
Post by fatman »
Can someone explain to me how to add a light turn off and on feature the the main menu where I have Feeding mode and Water change mode?
I've hunted around the forum and can't find it.
Fat
Re: Main Menu Light Option
Custom menu.
http://forum.reefangel.com/viewtopic.php?f=14&t=311
Or if you have RA+, you can use the standard menu, which is a complete set of the menu system.
Use this in the setup() section:
  ReefAngel.AddStandardMenu();
fatman
Post by fatman »
Thank you so much. That did it. Now I can shut them off and turn them on when I need to. I appreciate the help.
Fat
